Takin intercooler off. Help
Results 1 to 2 of 2
This is a discussion on Takin intercooler off. Help within the Engine Performance forums, part of the Tutorials & DIY category; hey im tryign ot take my intercooler off to do a greddy type S recirc BPV. i took the 2 ...
    Registered User airsofter69's Avatar
    Mar 2005
    new jersey
    hey im tryign ot take my intercooler off to do a greddy type S recirc BPV. i took the 2 bolts for the mount off. The 3 bolths for the hard lins and took off the hoze clamp closest to the throttle body. It still wont come up. i believe its attached to the Y pipe and im just wonderin if i should just release that hose clamp or take off the 2 bolts holding that flange in place? Thansk alot guys
    Pete
    2002 black wrx BuGeYe
    Smokey the bear "Protect our friends damn it"
    Registered User Hybrid-X's Avatar
    Feb 2002
    WA for now, but CA will always be home
    Here u go...
    Remove Intercooler
    Remove two bolts for intercooler brackets(12mm I beleive)
    Remove three vacumn lines on the pipes connected to the I/C
    Remove vacumn line and two bolts for BOV(do not disconnect BOV from return hose though)
    Loosen throttle body/IC clamp( on the T/B side)
    Loosen turbo/intercooler pipe clamp
    Wiggle intercooler off
    Remove left intercooler bracket(while facing car). Two 12mm bolts I believe.
