SO does this mean I should get an 18g instead of a vf34?![]()
This is a discussion on Stock WRX turbo is not a 13G it is a 13T within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; well put! i got a vf 30 when back in 02, i was under the impression that it was gonna ...
well put! i got a vf 30 when back in 02, i was under the impression that it was gonna be a decent upgrade and it was far from it. yeah i did pick up some power but an extra 30 or so at the wheels was not worth the $1300 that they were going for at the time, if you could even find one. i had much more fun w/ the stock turbo tuned to the max and if I could do it over i would have jumped right onto a big turbo.
--Chris
04 WRX wagon - 304whp Mods - SOLD
2008 DGM Impreza 2.5i sedan - STi Grille, GTspec cf lip, CTspec cf trunk chrome cover, Perrin shorty antennae
LISC #3
www.longislandsubaruclub.com
Not necessarilly, but you ought to look into the 16G certainly. Those are nice turbos.
Also, I repeat a previously posed lame question (by me again): Does anyone know of a 14B fitment for our cars? That'd yield just a bit over our current theoretical, somewhere in the low 400 CFM (I think). 1G DSMs had the TDO5-14b and I, for one, liked it.
Anyone?
The flange on the turbine housing would not match I believe. It would be too much work for little gains.
'02 PSM Wrx
Well basically we don't have any "information" only guesses at the moment.So how would you compare this "new" information to a VF35? I am looking "very" closely at one.
We know the stock turbo flows slightly more than was widely thought, up from the 360 CFM of the 13G to some where near or at 400 CFM range. That means all the small IHI turbo's are pretty much the same as the stock.
I'm not sure how the VF35 ranks with the VF30 and 34, but they are both useful improvements over the stock at about 460 CFM.
I have a 16G (subaru pattern housing) and like it, and it is rated at about 505 CFM more or less. It should be good for 12's in the 1/4.The flange on the turbine housing would not match I believe. It would be too much work for little gains.
The 14b also flows in the neighborhood of 500 cfm.
Then you move into the large turbos like the 20G and the GT30's etc.
Larry
13.239@102.85 -- 5800 ft altitude
on the stock TD04L-13T turbo
Also, a MHI listing of stock turbos seems to agree that the stock WRX turbo is in fact a TD04L-13T-6. http://www.melett.com/pdfs/MHI/Mhi%20TD04.pdf (page 4)
This PDF sets the 13G dimensions as -
Inducer - 41.50mm
exducer - 56.00mm
tip width - 5.00mm
hub length - 22.0mm
number of blades - 12
And the 13T dimensions -
inducer - 40.64mm
exducer - 56.01mm
tip width - 4.98mm
Hub length - 26.2mm
Deliberating enclaves of like-minded people are often a breeding ground for extreme movements - Cass Sunstein
Law for Small Businesses - The D. J. Marcus Law Firm
Wow, the 14b actually flows that much? I know that 1g dsm's have gone 12's on it but I didnt realized it was capable of 500cfm's. So what are the benefits of getting a 16g over a 14b? If it doesnt flow any more than the 14b and people are basically giving them away, it seems like a moot point.Originally Posted by hotrod
'02 PSM Wrx
Take a look yourself, the 14B is a little less capable than the 16G, falling just around the low to mid 400 CFM range where the 16G's run in the mid to high 400's for practical max flow and reach low 500's. if you go to choke flow.
http://www.stealth316.com/2-turboguide.htm
http://www.stealth316.com/images/td05-14b-raw.gif
Larry
Great info Larry!![]()
-Brian
Twisty Monster - 335 ft/lb of torque @ 3600 rpm on a stock turbo. Is that possible? Yes it is.
Even if it is a 13T with more capable airflow, I've found that trying to get that power out of the turbo results in a quick death. The stock turbo doesn't like to push enough air to match those numbers for very long before you spun out an oil seal. It might be capable of it, just like a VF22 could probably squeeze out 23 PSI on a 2L motor but it just aint worth it in terms of turbo reliability.
Exactly, capable and desirable are probably not going to match up too well.
When I pulled mine down to measure it, it looks like it has a fair amount of shaft play, so probably would not have survived long as hard as I was flogging it.
Used day to day near the stock boost settings with an occasionaly high boost period would probably work okay. I flogged the daylights out of mine for the better part of 38,000 miles but it was probably not going to put up with that for much longer.
Larry
I guess that explains some of the 12.7 timeslips on stock turbo I keep seeing around these days![]()
It'd be interesting to do a stock for stock comparison of the vf35 versus the stock turbo, totally stock cars, stock boost levels, programming. Fuel mods would be amust for any major gains, but it would seem like the vf35 would be a cooler running turbo on a stock car since it's got the larger compressor but the relatively small turbine.
What kind of setup are you running now Larry?
By the way, I'm the guy that sold you a set of stock struts/springs about a year ago.
Try not, do or do not. There is no try. - Yoda
Mods
i don't know if you guys know but Volvos have TD turbos too
my friend pulled his off of Volvo 940 Turbo and it was etiher TD033 or TD05 i don't remember now
