ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
Go Back   ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums > Tech & Modifying & General Repairs > Engine Modifications
Engine Modifications Flat-fours and turbochargers are what set the WRX apart from the rest. Talk about them and the latest aftermarket parts here. Sponsored by JSC Speed
Advertise On ClubWRX
Reply
LinkBack Thread Tools Rate Thread Display Modes
Old 12-07-2004, 12:50 AM   #1 (permalink)
Moderator
Silver Supporting Member
MidKnight's Avatar
Send a message via AIM to MidKnight
Latest Dyno results(XS450/EJ207)... 360/302
So I went to the Dyno on friday and here's what I got on my xs450/avo400... 360whp, 302 ft-lbs @ 23psi on 93 octane
I had a few problems holding me back from making more power.
1) I had a huge leak at the flange to my external wastegate from my uppipe (probably due to blowing out the gasket on my way to the dyno ) This is without a doubt why my turbo is spooling so slowly right now (~700 rpms later than what I was getting before) After doing some reading apparently the gaskets that are supplied with the Tial wastegate are garbage (so i noticed). Tial themselves says to use the gaskets from the turbonetics unit, so i ordered those already.
2) I need colder plugs. Junior was pretty adamant about the fact that with 1 step colder plugs I could run more timing and pick up some big power up top aside from the power I would get from fixing the leak I have. The ej207 loves a lot of timing and I can't run it with the plugs I have. I ordered a set of NGK Iridiums in the 8 heat range. Should have those in soon.
Over all, I'm pretty happy as far as how things have progressed thus far. Having over 300whp at 8k rpms is rediculously fun. I can't wait to get my issues worked out and my ra gearset in!!
__________________
Moderator: Engine Performance, Powertrain, Vendor For Sale
'03 WRX
'01 2.5RS
MODS | PICS | Dyno
"Stuff sold by the gram is always going to be more exciting than stuff sold by the pound." - Jeremy Clarkson
MidKnight is offline   Reply With Quote
Old 12-07-2004, 12:55 AM   #2 (permalink)
AwdTurboWrx's Avatar
WOW..congratulations!!! looks good.....you and 13secwrx keep going bigger and bigger...but it looks like he might sell his
so how big of a difference will the fixed leak make as far as hp goes??
__________________
The Ghosts of Zooph and Sarcasmo Will haunt CLUBWRX forever!!!
AwdTurboWrx is online now   Reply With Quote
Old 12-07-2004, 12:59 AM   #3 (permalink)
Moderator
MidKnight's Avatar
Yea, it's sad to see Will selling his baby!!
As far as power form the leak, it's reall hard to tell. It's very audible. I had walked in there aiming for 375whp and afterwards Junior was more than confident that I would easily get that when all was fixed up. We will see...
__________________
'03 WRX
'01 2.5RS
MODS | PICS | Dyno
Old 12-07-2004, 01:26 AM   #4 (permalink)
wow 375whp ..nice!!! ..and better spool up once leak is fixed nice...are you planning on upgrading tranny?
__________________
Old 12-07-2004, 01:42 AM   #5 (permalink)
Moderator
MidKnight's Avatar
Last sentence in my first post....
__________________
'03 WRX
'01 2.5RS
MODS | PICS | Dyno
Old 12-07-2004, 01:56 AM   #6 (permalink)
ooops sorry...loooks good than
__________________
Old 12-07-2004, 02:24 AM   #7 (permalink)
WillMX's Avatar
Location: Albany, NY (school) -- Long Island, NY (home)
congrats on the dyno . too bad will is selling his car
__________________
'02 PSM WRX -- turboxs turboback w/ magnaflow muffler, perrin up-pipe, helix tmic, ecutek
LISC #13
WillMX is offline   Reply With Quote
Old 12-07-2004, 10:27 AM   #8 (permalink)
ebr0t's Avatar
Send a message via AIM to ebr0t
nice #s are the RA's really going to hold that power though. esecpcially since youll be making even more then this soon.
__________________
Quote:
Originally Posted by DTR rex
Peter North > *
ebr0t is offline   Reply With Quote
Old 12-07-2004, 01:16 PM   #9 (permalink)
Timdog1650's Avatar
Send a message via AIM to Timdog1650
Were you getting detonation or any kind of misfiring up top with this tune? Seems like you should have been running more boost than just 23lbs on that turbo. Bummer about the plugs though, it must drive you crazy to be ALMOST there when once again a few little things hold you back.
The 8k powerband is awesome though, isn't it?! I could spend all day and night above 6krpm and never feel a drop off....it's amazing!
PS your AFR's look super safe! How are your injectors doing, any idea what kind of duty cycle they're at?
Timdog1650 is offline   Reply With Quote
Old 12-07-2004, 02:03 PM   #10 (permalink)
Moderator
MidKnight's Avatar
Quote:
I've gotten my stock gears to hold at 341whp for quite a while, so I'm pretty sure I can manage to get the ra's to hold. People usually say the ra's are good for about 350whp so I'm not too far past that.
Quote:
I was getting some knock up high in the powerband, which is most likely a result of my plugs. That's on eof the reason I need colder plugs. I wanted to advance timing at least another degree before I started adding more boost. Once I get the issues sorted. I'll throw more at her.
It does suck being almost there, but even in this state the car absolutely rips! I get great pull from 5k to 8k (I need about 500 more rpms down low to really be happy), and the external wastegate holds boost very solid and boy does it sound mean!
__________________
'03 WRX
'01 2.5RS
MODS | PICS | Dyno
Old 12-07-2004, 02:43 PM   #11 (permalink)
Timdog1650's Avatar
You think this new gasket will give you 500rpm more to play with? I figure it should be good for a bit more boost down low....*ordered new plugs just now*
Old 12-07-2004, 02:46 PM   #12 (permalink)
Moderator
MidKnight's Avatar
Fixing a leak like that can definitely give me back 500 rpms and some more torque down there. Like I said, we'll see!
__________________
'03 WRX
'01 2.5RS
MODS | PICS | Dyno
Old 12-07-2004, 04:20 PM   #13 (permalink)
XxScoobYxX's Avatar
Send a message via AIM to XxScoobYxX
wow great numbers man goodluck with reaching your goal..
XxScoobYxX is offline   Reply With Quote
Old 12-07-2004, 04:22 PM   #14 (permalink)
UURX02's Avatar
Send a message via ICQ to UURX02 Send a message via AIM to UURX02
Quote:
Originally Posted by MidKnight
300whp at 8k rpms is rediculously fun. :
I BET!! very impressive numbers man....
__________________
02 WRX - MODS
Bugeye Mafia > *
UURX02 is offline   Reply With Quote
Old 12-10-2004, 11:20 PM   #15 (permalink)
Boosted4's Avatar
Send a message via AIM to Boosted4
Werd. Very nice, is the ej207 built or did those come with forged internals?
__________________
'02 PSM Wrx
Boosted4 is offline   Reply With Quote
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Dyno Results - The End of the Great Intake Debate? Geekqualizer Engine Modifications 20 10-24-2004 04:50 AM
STi AccessPORT Dyno Results cnstman Mountain States 34 06-30-2004 03:53 PM
STi dyno results... V8VENOM STi Technical Forum 3 11-19-2003 10:03 AM
Latest dyno results...but where'd the torque go? Verdugo Engine Modifications 21 02-20-2003 08:07 PM
Dyno Results Stage4tmi txs utec vs ecutek WRX-Hellfire Engine Modifications 27 01-16-2003 12:28 AM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.1.0
Copyright 2001-2008 ClubWRX.net
