Why do alternators go bad?
Results 1 to 15 of 15
This is a discussion on Why do alternators go bad? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; It seems to be a common problem on cars that get a bit long in the tooth...just wondering cuz a ...
    Registered User QuickSilver's Avatar
    Bay Area, CA
    It seems to be a common problem on cars that get a bit long in the tooth...just wondering cuz a co-worker's honda needs a new alternator.
    anyone know what the issues are?
    Hg.
    '02 Plat. Wagon, Manual
    Apr 2003
    Yeah, I've had an alternator go bad on every car I've owned. always happens around 75,000 85,000 miles but it probably has more to do w/ age. A component in the alternator just dies, the diode. But there's more than one so it goes gradually.
    Registered User SonicYellowWRX's Avatar
    Aug 2002
    the alternator produces a magnetic field and the energy is converted from ac to dc... the current is picked up by two carbon brushes in contact with slip rings. typically over time the carbon wears out and loses contact with the slip ring. maybe the stator windings just get dirty and corroded and worn. (these are usually the reddish wires you can see inside)
    other than that, common alternator related problems are from the internal components failing, loose connections, the belt becomes loose or the battery is bad.
    Yes, that is me in my avatar! Kid's don't try this at home.
    CLICKY to view My Extensive Mod List!
    Zem
    Zem is offline
    Registered User Zem's Avatar
    Jul 2003
    Stalking Jay
    They are seduced by the power of the Dark Side.
    ...yeah, and as he said, the brushes that are forced to endure lots of friction eventually wear out. And, of course, just about anything can go wrong... things break. But that's a wearing down failure that eventually must happen.
    Let justice be done though the heavens should fall.
    -John Adams
    Administrator
    May 2003
    Honda alternators typically have bearing problems. They usually end up seizing, and snapping the belt in a blaze of rubber smoke. I've changed more Honda altarnators than I can count.
    Zem
    Zem is offline
    Jul 2003
    Stalking Jay
    How high can you count?
    -John Adams
    Administrator
    May 2003
    Quote Originally Posted by Zem
    I made it to 13 last time I tried
    Aug 2002
    really? how many miles were on these??? i usually change the belt when it makes noises, so i've never seen a "blaze of rubber smoke".
    Administrator
    May 2003
    Quote Originally Posted by SonicYellowWRX
    I've seen them go as early as 40k, and last as long as 150k. When it seizes, the belt lasts about 45 seconds.
    Registered User zoinks's Avatar
    Dec 2003
    Portland, OR
    It seems that GM, at least in the '90's, ran a bit too much tension on their belts causing the bearings to go prematurally. I know I replaced the one on my '94 *cough* firebird *cough* at least 5 times in 115k miles. My wife has a '97 Saturn which has had it replaced a few times as well. Actually I just replaced hers again a few weeks ago.
    Administrator
    May 2003
    Quote Originally Posted by zoinks
    From 1987 to 1994 GM's bearing/tensioner design left a little to be desired. From about 1989 to 1993 (approx) Ford had a problem with their internal voltage regulators, and connectors that regularly melted, and sometimes caught fire.
    Aug 2002
    yeesh, talk about bad engineering with ford and gm! i never had an alternator go on me... and i've had honda's with 100k miles or at least 80k+ miles. so honda alternators seem to be fine for me.
    Bay Area, CA
    cool info fellas...anyone know the status of our suby alternators?
    anyone replace theirs yet? and if so, was it a simple DIY or a time to shell out the cash?
    Hg.
    Zem
    Zem is offline
    Jul 2003
    Stalking Jay
    The only alternator I had die on me was in an 87 Sentra. The thing came with 2 speakers and a cassette player. Well, I was stuck with the damn thing, but I had some money to add a CD changer and upgrade the speakers. Since the power from the head unit was almost nil, I had to have amps for the speakers. Fortunately, my brother had spare sitting around. Anyways, I had all this professionally installed (I was in high school, unaware that my future would turn me into a car guy)... they never bothered to mention what would happen. About 4 months later I was driving home and I noticed my lights were dim... then the head unit turned off.... I managed to get home but it wouldn't start again. The mechanic was very nice while explaining to me that I was a dumbass.
    Long, pointless story. I'm still at work, wanna go home.
    -John Adams
    Registered User ShotgunTC88's Avatar
    Nov 2002
    Ky
    I can do 8x7=56!
    Only because that ***** of a grammer teacher made me wear that goofy flashcard for a day cause I missed that one
    Please, Let's not do speelllings
    I lost an alternater in my Berretta because of the stereo set up.
    Shotgun
    "Speed Kills......But so do Strokes,...Sign your donar card"
