Safe Boost level?
Results 1 to 13 of 13
This is a discussion on Safe Boost level? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Anyone know whats the safe boost PSI i can raise it to without damaging the engine? Only mods I will ...
    Registered User hakira's Avatar
    May 2004
    Slidell, La
    Safe Boost level?
    Only mods I will have atm is : Helix turbo back, CAI , Turboxs manual boost controller.
    any links or anwsers would be appriecated!
    02' WRX OSECUROM STG 2 93OCT on 91OCT map -13.708 SEC / 097.84 MPH / 1.86 60 ft @ No Problem Raceway
    02' WRX OSECUROM STG 2.5 93OCT- 12.9 SEC @ No Problem Raceway
    Mods
    Registered User SubieStyle's Avatar
    Mar 2004
    Redlands, CA
    if you want to play it safe, you really shouldn't mess w/ the boost if you're not going to compinsate in the other necessary areas (for example FUEL). You should really lose the boost controller, it may cause more "cons" than "pros". But if really must use it, I wouldn't set more than 14.5-15 lbs. But I still say you should just wait, save up if you have to & get some kind of engine management. Hope any of this helps.
    May 2004
    Slidell, La
    ah okay thanks, could you point me to some links about fuel management or upgrades to help out?
    thanks
    Mods
    Administrator
    May 2003
    It also depends on what your altitude is. (If I don't say that Zem will yell at me )
    Registered User cheeseybacon's Avatar
    Jul 2004
    Chambersburg, PA
    Yeah, ditch the boost controller, and lose the CAI while you're at it. If I were you I would get a catless uppipe first, then look at some type of engine management.
    ΜOΛΩΝ ΛΑΒΕ
    Dec 2002
    You'll be ok with a manual boost, I used one for a long time and so have many other owners of turbo cars. I think running another psi or 2 will be ok, but you wouldn't want to push the turbo to far. The nicest thing is that the boost wont taper off.
    But, one thing to be very carefully with the throttle. See the downside to the MBC is it will allow patial throttle full boost, witch can be bad. I would always keep a eye on my boost gauge, and would let the boost go above about 7 psi at patrail throttle. If it went over seven I would let off just a bit, or just go WOT.
    But, your next mod should be engine manament. The utec's are great. I don't know how I lived without it.
    As I said many turbo cars have used this with good results, but I also want to add that many motors have been lost thanks to them also. Be carefull and don't get boost happy and you'll be ok.
    edit: also, it's easier to avoid partial throttle full boost with a bigger turbo
    May 2004
    Slidell, La
    ah okay thanks racin for the info.
    Cheesy i have complete catless exhaust system
    From various post i have read i some people think vf34's are better than vf22 and vice versa? Can anyone supply a link to the difference of these two?
    Mods
    Registered User ShotgunTC88's Avatar
    Nov 2002
    Ky
    After 16psi/1bar the TD04 is just gonna push hotair and the "gains" past that are only gonna raise possibility of bustin something.
    I wouldnt run mine any more than 16.
    .02
    Shotgun
    "Speed Kills......But so do Strokes,...Sign your donar card"
    May 2004
    Slidell, La
    Thanks train for the info!
    one last question: stock psi for wrx is 13psi?
    Mods
    Registered User Steve-o's Avatar
    Aug 2002
    Quote Originally Posted by hakira
    I think its 14.5psi
    Currently with my UTEC and turbo back I'm spiking 17-18psi.
    WRB WRX: Super 16g Equipped
    www.BrotSpec.com
    Administrator
    May 2003
    Anytime
    Aug 2012
    Greeley
    hey guys, to everyone in the post i took out my tdo4 and threw in a tdo5 16g, thus it spools more air but both turbos ran 12psi, considering the compressor wheel is bigger on the 16g, is it just as equal to my stock turbos AFR or does it spool more air, and my friend ran 16 psi in his 02 wrx and a piston melted because of to much boost mine is a 2002 with 3' turboxs downpipe and catback, and i baby it and try not to ride my turbo, as i am afraid of doing the same not knowing my afr
    Jan 2005
    Eh, whaaaaa?
    Wow back from the dead.
    Dude you need tuning. Changing out a turbo without tuning is just asking for a blown motor. You also need new injectors, higher flow fuel pump, and a better intercooler to go along with your exhaust mods. That's probably why your idiot friend melted a piston, no tuning/proper modifications with an increase in boost pressure/air flow.
    I take it you didn't research this before purchasing your 16G... This information is available on every Subaru forum out there.
    Cody
