Grounding mod?
Results 1 to 13 of 13
This is a discussion on Grounding mod? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Can anyone help me out with this......... What is it, what does it do, and how do I do it ...
    Aug 2002
    Grounding mod?
    thanks
    mike
    Registered User SonicYellowWRX's Avatar
    Aug 2002
    its an improve ground wire kit. gives a better electrical ground and somehow makes power. (Dyno'd at 7whp on a WRX) Remove stock ground wires and grounding location, put in new ground wires and ground in new location.
    Yes, that is me in my avatar! Kid's don't try this at home.
    CLICKY to view My Extensive Mod List!
    Registered User 206WRX_GDA's Avatar
    Apr 2002
    : s e a t t l e :
    OEM Grounds
    Yup yup! I think people are starting to leave the OEM grounds and just doubling them now. Still highly debated though, but it's basically a 'why not' mod. Mine's gonna happen this weekend...I just need a pretty distribution block...
    B
    Banned dark_rex's Avatar
    Aug 2001
    The Hub
    there is only ONE OEM ground. the problem with this is most of your car's sensors use an electical charge signal to tell the ECU what's going on. so if there's only one ground, a charge of say +1 is a little different on one side of the engine bay than another. so the ECU is getting signals based on a fixed value, while every sensor thinks that value is a little different.
    the grounding mod runs a ground connection to A NUMBER of spots in the bay, bringing the overall charge of the car to equilibrium. njow the ECU is seeing what is REALLY going on, and it responds exactly as it was programmed to.
    it has been widely said that this mod returns NO horsepower gains. many on i-club called it a "smoothness" mod, as it was designed to remove some engine stuttering for those with varying levels of mods. many people with an MBC, and many with some of the staged kits complained that boost was hitting awkwardly. some even said that it helped with the stock setup.
    i'd like to see that dyno chart, sounds like a load of crap. is that the HKS claims for their circle earth product?
    dR
    Aug 2002
    no, its actually XS Engineering's claim that they dyno'd it and actually saw gains. they said an RX-7 made 10 whp on the dyno with the grounding kit. and yes, they were surprised as well.
    Admin - Scooby Hooligan
    Weasel 555's Avatar
    UK,NY,AK,FL
    my 0.01 worth
    go to auto store buy 1 braided ground 6-8"strap usually $2-4 bucks
    bolt from engine to negative terminal
    done
    Registered User WRXin''s Avatar
    Jun 2002
    Houston, TX
    If you're interested in this mod, you should check out this link http://www.scoobymods.com/forums/sho...p?threadid=422
    Fahd
    Floats like a butterfly and stings like when I pee!
    May 2002
    http://www.flashlightflux.com
    Here is how I have mine done. I used 8 Guage to the ground points around the engine bay and 4 guage to the battery.
    Aug 2001
    The Hub
    where's you get this cool little thingy?
    May 2002
    I picked it up from a local audio shop. It is a power-ground splitter. It uses a screw to tighten down the wire into the splitter. They have all kinds of cool stuff. Check out their web site. http://www.stingerelectronics.com/
    Aug 2002
    AaronC,
    What's the lowdown with your sunroof? I've been debating whether or not cutting a hole in my perfectly good roof is a smart idea or not. What are the pro's and con's from your P.O.V.? Maybe I'll start a new thread with this one, if there's not one already
    Sedona Red Wagon, Nicely Tinted
    Thule Bike RackS
    May 2002
    Might as well make a new topic on it. There will be people sitting in 2 different camps. Let me know where you will be starting it.
    Aug 2002
    I guess I'll start it in Exterior/ Appearance.....probably as good as any place to start
    Thule Bike RackS
