ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
Go Back   ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums > Tech & Modifying & General Repairs > Engine Modifications
Engine Modifications Flat-fours and turbochargers are what set the WRX apart from the rest. Talk about them and the latest aftermarket parts here. Sponsored by JSC Speed
Advertise On ClubWRX
Closed Thread
LinkBack Thread Tools Rate Thread Display Modes
Old 09-28-2004, 07:59 PM   #1 (permalink)
ebr0t's Avatar
Send a message via AIM to ebr0t
Engine Performance FAQ [[[READ ME]]]
first modification thread
first mod thread also
Most Popular Uppipe Poll
Facts about the WRX stock exhaust - Thanks WRC_obssed for the link
Great page for turbo basics - Thanks AJ for the link
Spark Plug Installation
Exhaust/uppipe combo thread
Stock EGTs by cylinder [Why not to MBC or intake a stock EJ]
Modification Path
In general, please do not skip modification steps. Do not try to add a new turbo to a stock car. Get rid of the catalytic converters, get some engine management. Get the neccessary fuel mods (injectors and fuel pump size depending on needs IHI turbos are fine with STI injectors) Then get the turbo and intercooler upgrade if you feel it neccessary and install that with the fuel mods together at the same time. Then get your car on the dyno or a road tune to get the most out of your mods, as the base maps are not very good. Note: Header is not normally included here
So How Do I get rio of all the catalytic converters (there are 3)
In most cases a downpipe will eliminate both the downpipe and the midpipe cat in one piece. Very few downpipes are only the downpipes (stroumung comes to mind that is only a downpipe) So if you get a new downpipe you will have gotten rid of 2 catalytic converters, so you have one left in the uppipe. Here is a diagram of the wrx exhaust system:
All these stages say turbo back exhaust. What if I want to mix and match brands, how do I then have a turbo back exhaust?
A turbo back exhaust is just that, the exhaust from the turbo-back. (see diagram) You can still make a turboback exhaust with a catback and a downpipe. (for instance, I have a tanabe catback with an invidia downpipe)
What is a "bellmouth" downpipe
That refers to where the downpipe meets the turbo. In most cases a non bellmouth will be fine unless you plan on upgradeing your turbo.
HKS NONbellmouth Downpipe
Helix Bellmouth Downpipe
Should I get a bov?
Quote:
Originally Posted by Trailboss
Blow off valve on a stock engine
Pros:
Cool sound
Cons:
Run rich between shifts
Could cause long term engine problems
Not necessary until you're running 20+lbs of boost
Decreased gas mileage
Blow off valve on a modified engine w/ turbo upgrade
Pros:
Ability to hold more boost (20+lbs)
Cool sound -- commonly reffered to as a "show off valve"
Give yourself some deserved bling bling for running an upgraded turbo
Cons:
Still might run rich, but with engine management you could help to tune that problem out.
Still could cause long term engine problems...but when you've done everything to upgrade your turbo, you're running that risk anyway.
Decreased gas mileage - due also to added fuel (larger injectors) w/ engine management to feed the upgraded turbo more air and fuel.
Things to think about....
What Are These "stages" Everyone keeps talking about?
Most people base their stages off of Turboxs's definitions which are (www.turboxs.com)
Stage 1:
Turbo XS UTEC
Stage 2:
Turbo XS turbo back exhaust (TBE)
Stage 3:
TXS TBE, Uppipe & TMI (top mount intercooler)
Stage 4:
TXS TBE, Uppipe, STI Injectors, and walbro fuel pump, VF3X (either a vf30 or vf 34 is normally used), & TMI
TurboXS UTEC Instructions READ THEM BEFORE EVEN TOUCHING A UTEC
http://turboxs.com/_images/UTEC/Updatewrx/UTEC User Manual 4.2.pdf
Cobb's stages www.cobbtuning.com
Stage 1- Acessport ECU
Stage 2- Acessport and turbo back exhaust
Stage 3- Under devlopment, coming out Fall 04. Though i belive they do have maps now for the vf30/vf34.
boost conversion for hkpa
PSI HKPA
14 0.966
14.25 0.98325
14.5 1.0005
14.75 1.01775
15 1.035
15.25 1.05225
15.5 1.0695
15.75 1.08675
16 1.104
16.25 1.12125
16.5 1.1385
16.75 1.15575
17 1.173
17.25 1.19025
17.5 1.2075
17.75 1.22475
18 1.242
18.25 1.25925
18.5 1.2765
18.75 1.29375
19 1.311
19.25 1.32825
19.5 1.3455
19.75 1.36275
20 1.38
IHI turbos from www.worldoneperformance.com
VF22:
This turbo has the highest output potential of all of the IHI VF series turbos and is the best choice for those who are looking for loads of top end power. The top end power however, does not come without a cost. The VF22 spools significantly slower than the rest of the IHI models due to the larger P20 exhaust housing and is much less suited for daily driving than some of the other models. Although the largest VF series turbo, the VF22 is not quite optimal for stroked engines or those who wish to run more than 20PSI of boost. The VF22 is best mated with the 2.0 block and in applications of 20lbs of boost or less.
VF30:
The VF30 is commonly considered the best bang for the buck turbo in the IHI VF series line. A relatively new model the VF30 features the the same exhaust housing as the VF24 but a larger compressor side similar to the VF22. The combination of these two parts results in increased output potential without the lag associated with the VF22. Although it doesn't offer the top end supremecy of the VF22, the VF30 is a great compromise between these unit and the quicker spooling models.
VF34:
The VF34 is nearly identical to the VF30, with the same exhaust housing and compressor. However the VF34 goes back to the ball bearing design, and in doing so achieves full boost approximately 500RPM sooner than the comparable VF30. The VF34 is the most recent IHI design and as such costs slightly more than its counterpart. Top end performance and maximum output are identical to the 30.
Provided by Dark Rex (*Information was derived from many sources including NASIOC, MRT website, PPMotorsports website, clubwrx.net, scoobytech.net, WorldOne and Rallispec website.)
VF23
This turbo is considered a great all-around turbo. Like the VF22 it utilizes the largest P20 exhaust housing. This housing is mated with a smaller compressor housing of the of the VF24 for fast response and excellent low and mid-range performance. It does not have the same top end power of the VF22, but spools up significantly quicker. Standard ball bearing center section. Excellent bolt-on replacement for the standard WRX turbo on cars without any other major modifications. Expect flows around 430 CFM at 18 PSI.
VF24
This turbo shares its compressor housing with the VF23 however, this housing is mated with a smaller (P18) exhaust side. The smaller characteristics of this turbo allow it to provide ample bottom end power and quick spool. This turbo is very popular for Imprezas with automatic transmissions and Group N rally cars. Not recommended for stroker engines or engines with high boost as turbo is small and can over speed. Best turbo for cars that want the best bottom end and least lag. Expect flows around 425 CFM at 18 PSI
VF28
This turbo came standard on the STi Version 5. In terms of overall size, it is smaller than the VF22, VF30 and VF34, and about same size as the VF23. Expect flows around 425 CFM at 18 PSI
VF29
This Turbo is nearly identical to the VF24, with the same compressor and exhaust housings. However the compressor wheel in the VF29 is has been changed slightly. The changes made to the compressor wheel in this model are generally viewed as improvements, and as such this unit is typically chosen over the VF24. Has a different location for the pressure hose on the waste gate actuator Expect flows around 425 CFM at 18 PSI
VF35
The VF35 utilizes the same compressor housing as the VF34 however it also features a divided thrust or offset ball bearing design. The smaller P15 exhaust housing for quicker spool up and a slightly more limited top end. The compressor inducer size is the same as a VF30/or 34 turbocharger.
VF35Thread Discussion
VF22 Vs 18g
VF34 Vs VF22
18g thread with more results within
daily driven turbo discussion
VF34 VS 18g
maybe ill add more later, but this should be plenty to get you started. enjoy
__________________
Quote:
Originally Posted by DTR rex
Peter North > *
ebr0t is offline
Old 09-29-2004, 10:25 PM   #2 (permalink)
ebr0t's Avatar
NEWBIE THREAD EVERYONE READ edited 9.30.04
Much Props to Tan And Kurlee For This Post
Basic Information
Pressure Conversion
The basics of turbocharging
Resetting the ECU
Turbo Information (Compressor Maps, Flow, etc)
OBDII CODE LIST
BOOST/VACUUM CONVERSIONS [Mpa, bar, atm, psi, inHg)
MAF Cleaning Procedure May Help Hesitating Performance
TURBO INFO [compressor maps, flow, volume etc.]
Subaru Warns All Dealers to "Void" Warranties for Specific Mods
Basic Mods
Manual Boost Controller (MBC) install #1
Manual Boost Controller install #2
Manual Boost Controller install #3
Blow off Valve (BOV) install
Uppipe, downpipe, & Muffler Install Guide
Boost Gauge install
Big Sky WRX's boost gauge install instructions
Spark Plug replacement
2.2k Ohm Resistor Mod
Turbo Timer Install(Blitz DC TT)
EXHAUST INFO [HP Ratings, Price, etc.] [Turbo Magazine Exhaust Shootout.]
What's The Best BOV Poll
TURBO INFO [model discussion, benefits, drawbacks, details etc.]
Manual Boost Controller (MBC) General Q/A
Manual Boost Controller (MBC) Concerns/Problems
Lightened Crank Pulley Discussion
EGT Probe Install and Location
Exhaust Video/Sound Clips
Troubleshooting Engine Problems
Crank Position Sensor Woes
More mods
Samco Intercooler Install
Fuel Injector installation tips
Aquamist Install (Intercooler sprayer)
Turbo Timer Install
__________________
Peter North > *
ebr0t is offline
Closed Thread
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
READ FIRST: AccessPORT Overview, Authorized Tuners and FAQ WRC_Obsessed Tuning: Electronic Engine Management 3 08-14-2005 06:40 AM
Engine Performance FAQ tan Engine Modifications 2 07-22-2004 12:49 AM
Engine performance mods John775 Engine Modifications 9 04-08-2002 09:16 PM
Best bang for the buck engine performance mods dark_rex Engine Modifications 13 02-14-2002 10:26 AM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.1.0
Copyright 2001-2008 ClubWRX.net
