ATTENTION!!! - K&N, ITG, Perrin Drop-in Air Filter Users
Page 1 of 4 1234 LastLast
Results 1 to 15 of 54
This is a discussion on ATTENTION!!! - K&N, ITG, Perrin Drop-in Air Filter Users within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I was reading up on different intakes and air filters and such for our cars, and I stumbled upon quite ...
    Moderating U! KurleeDaddeeWRX's Avatar
    Mar 2002
    San Jose, CA
    I was reading up on different intakes and air filters and such for our cars, and I stumbled upon quite a few threads of people having low end throttle response problems. Their cars weren't responding at low rpms like they should. There was one common modification most of them had. They all ran air filters, be it foam or paper, that had dirt trapping oil on them from the factory. A lot of times, these filters come oil-soaked, and when they are installed, some of the excess oil gets sucked upstream and coats the MAF sensor. Since the MAF sensor is such a delicate and important tool used for measuring air, if it is dirty or is coated with oil, it will not be able to do its job effectively.
    I also run an ITG filter that came oiled. I have been having low end throttle response problems for as long as I can remember. I have tried to blame these problems on my tuning (UTEC), boost control being too slow(UTEC) so I tried an MBC, intercooler heat soak, intake not pulling in enough air at low speeds, and maybe even the Walbro fuel pump I have. Some of these are way out there, I know. But when I start to have a potential problem, I do sit around and think of every variable that could effect my car.
    So this last Thursday, after I was done reading about how a MAF sensor could become dirty, I tried to fix the problem. I took out the MAF on my car and attemted to clean it. This is how I did it:
    Take the MAF out of the car and make sure not to touch any of the sensors with your fingers.
    Get a plastic sandwhich bag and spray non-chlorinated brake cleaner into it. Enough to cover the sensor portion of the MAF.
    Put the MAF into the bag and shake it around.
    Take out the MAF and let it air dry.
    Re-install it after it is visually dry.
    The next morning I started up the car and the car seemed to idle even better than it did before. The low end throttle response was back and the car runs strong now from idle to redline. Mid range throttle reponse was also helped out.
    If you run an air filter that came with dirt trapping oil on it, try this MAF cleaning trick. Your car may run a little better than it did before. It worked for me.
    Registered User wake2snow5's Avatar
    Jan 2004
    Ellensburg, WA
    I will have to give this a try tomorrow. I am running a K&N filter.
    Registered User VetteVert's Avatar
    Nov 2001
    Boone, NC
    Is the brake cleaner safe to use on the MAF. I would've thought it to be too corrosive. shrug.
    Mar 2002
    San Jose, CA
    That's why you use non-chlorinated brake cleaner, or electronics contact cleaner. I beleive the non-chlorinated stuff isn't as harsh as the REAL stuff. I was hesitant to use it to. But I finally said, WTF, and tried it, and it worked.
    Mar 2002
    San Jose, CA
    Registered User BigRich's Avatar
    Aug 2001
    Lexington Park, Maryland
    I too am a bit nervous about spraying brake cleaner. That stuff can eat through certain plastics. If the goal is to remove oil and dirt from the MAF then would rubbing alcohol be a bit safer?
    Like you I have noticed the low end throttle hesitation and run a oiled K&N panel filter.
    -- Rich
    Mar 2002
    San Jose, CA
    You can go to an auto parts store or Radio Shack and pick up a can of Electronics Contact Cleaning solution and clean it with that if you are still hesitant to use the brake cleaner.
    Mar 2003
    lincoln, ri
    -- Rich
    the non Cl brake cleaner is fine, and doesn't harm anything.
    it's mostly tolulene, and xylene, fwiw.
    ken
    Moderator Integra96's Avatar
    Apr 2002
    Utah
    Knowing all of this about oiled filters and their effects on the MAF, would it be better to just use the stock paper filters or is there a performance penalty for that?
    "Did you sleep well?"
    "No, I made a couple of mistakes."
    -- Steven Wright
    Aug 2001
    Just cleaned the MAF during lunch with some non-chlorinated brake cleaner. It specifically said on the label it would not harm plastics. I forgot the name, but it was a green bottle. The red bottle is the harsh stuff.
    As suspected the MAF had a fair share of crud on it. After a few sprays and a 5 minute drying time it was re-installed. The metal pieces looked much better afterwards.
    Though my drive back to work was short things do seem a bit smoother.
    -- Rich
    Mar 2002
    San Jose, CA
    -- Rich
    I'm glad it worked for you. Donations can be sent to kurleedaddee@yahoo.com
    Nov 2001
    Boone, NC
    Didn't know the difference...that's why I asked.
    Mind explaining your ziplock bag idea? That better than just spraying them?
    VV
    Mar 2003
    lincoln, ri
    VV
    vv, the idea is that the direct spray from the can is a bit too strong, and can damage the fragile thin wire which is the actual maf sensor.
    i didn't use a bag, but i sprayed from a decent distance (1.5ft or so) to avoid too much pressure.
    ken
    Apr 2002
    Utah
    So...yay or nay for stock-type paper filters?
    -- Steven Wright
    Feb 2004
    Hickory, NC
    I used rubbing alcohol ant a q-tip. It worked fine.
    Mods
    Armed with a rotated Precision 6265 turbo at 35psi and a built 2.5 liter.
