Page 8 of 8 FirstFirst 12345678
Results 106 to 110 of 110
This is a discussion on Adjusting the wastegate arm within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by lundholm08 Would it be recommended to try this adjustment on say, a Stage 2 map if you're ...
  1. #106
    Moderator   Sasquatch's Avatar
    Apr 2004
    Southeastern PA
    Quote Originally Posted by lundholm08 View Post
    Would it be recommended to try this adjustment on say, a Stage 2 map if you're not hitting target boost rather than switching to the HWG map first? I imagine if you fix the boost issue with the wg arm adjustment, you would be better off with that than switching to the HWG map, no? Then again, I am at 8000ft elevation...lol
    See how old my post was?
    Try the HWG map first to see what a difference it makes. If you really want more boost install a 3 port boost control solenoid along with a Protune. I just did this two weeks ago and am getting 19 psi.
    Moderator for: Aftermarket Vendor & Installer Review / Detailing Forum / Engine Modifications / Exterior & Appearance
    New Member Hangout / Off Topic / Tri-State
    Mods & Pics
  2. #107
    Wrinklechops
    Quote Originally Posted by 04.SPT.WRX View Post
    Haha yes, I saw how old the post was, sorry. I sometimes find good threads and although they're old, I try to post there before starting my own. I should be dubbed the dead thread resurrector!
    I'm going to try the HWG map first. I had it on Stage 1 with no problems. We'll see with Stage 2.
  3. #108
    Apr 2004
    Southeastern PA
    No need to be sorry, it is a good thread.
    Mods & Pics
  4. #109
    Registered User 02Suby02's Avatar
    Jun 2009
    Kelowna, BC
    Hey, can someone plz give actual istrucions on how to 'turn' the wastegate arm? Because the arm is bent do you have to disconnect the arm from the C-clip before you turn it a full revolution and then reattach it?
    Quote Originally Posted by mourning_air View Post
    here is an image for reference
  5. #110
    Supporting Member yamaha_rider619's Avatar
    Jul 2009
    colorado is home, Kansas is the temporary home
    This post is 2 years old lol
    Josh
    2003 Subaru Wrx Vf39'd
    Bugeye mafia #300
    Sponsored By: WRXPro.com
