Check out my clean mod
Results 1 to 15 of 15
This is a discussion on Check out my clean mod within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; For those of you who have not yet done the intake resonator mod. Here is a recommended suggestion. This is ...
    Registered User Nexus6's Avatar
    Jun 2002
    O.C., Ca
    Post Check out my clean mod
    For those of you who have not yet done the intake resonator mod. Here is a recommended suggestion. This is the way I did it and gained results. Check the pics below.
    La Fee Verte
    Subaru 2002 Impreza WRX Sedan
    Jun 2002
    O.C., Ca
    Re: Check out my clean mod
    And then I cut off a piece from the resonator box, using tools like a soldering iron and a saw. and heated the plastic piece to the bottom of the upper piece hence:
    La Fee Verte
    Jun 2002
    O.C., Ca
    Re: Re: Check out my clean mod
    Another view
    La Fee Verte
    Moderator GV27's Avatar
    Jun 2002
    Green Mountain, Colorado
    I hate to say this, since you obviously took some time to plug up the hole where the resonator was. But........do you realize that if you left that open - or replaced the entire piece with a velocity stack in the airbox opening - that you'd have a presurized CAI and eliminate the 180deg kink in the intake track?
    Chris
    1990 Alfa Romeo Spider Veloce
    1993 Honda CBR600F2
    2002 WRX SportWagon *sold*
    Jun 2002
    O.C., Ca
    ya I was thinking about leaving it open but I wanted to use the intake ram so, I dont think it really makes that much of a difference.
    La Fee Verte
    Registered User Flyboy's Avatar
    Mar 2002
    9200' Golden, CO
    I would leave the hole open if I were you, that way you will pull air from the ram air scoop and the fenderwell. I cut mine the same way only a little higher up near the inlet/outlet.
    2011 SWP Premium Hatchback
    Flapatax Mud Flaps
    Kartboy STS with front and rear bushings
    Cobb AP Stage 1 (for now)
    Aug 2001
    Buffalo
    Nexus6,
    Glad to see your old avatar is back.
    I'm hypnotized!!
    Mar 2002
    9200' Golden, CO
    Originally posted by bedabi
    Nexus6,
    I'm hypnotized!!
    Wasn't it BAMBOOI that used to have that avatar?
    Flapatax Mud Flaps
    Jan 2002
    Re: Re: Re: Check out my clean mod
    Originally posted by Nexus6
    Another view
    You have not seen through my eyes you have only seen me with your own. - blu_ru
    Registered User Mad WRX's Avatar
    Apr 2002
    Denver
    Ha ha ha!
    Seems like you went thru all that trouble for nothing, by closing the opening on the bottom.
    Jun 2002
    O.C., Ca
    Originally posted by Mad WRX
    Ha ha ha!
    Not really, it only took about 5 min to do, although It was very hot in my garage If you look, there is a small hole at the bottom of my mod. So I guess that would draw in some air from the lower fender. Anyways, the results are the same either way open or closed.
    La Fee Verte
    MisterX's Avatar
    May 2002
    Prague, Czech Republic
    I left the stock "ram intake" in place where it may blow some cooler air. Who knows?
    Then removed the air box, cut out the nylon gasket, and took a 3.5 ID rubber elcbow from Home Depot. There was a lot of cutting, snipping and trimming of the hose, but it fits well into the fender and seals to the air box.
    You can hear it sucking at WOT and the stock BOV can be heard.
    I use an ITG filter panel.
    Banned dark_rex's Avatar
    Aug 2001
    The Hub
    yeah, it was bamboo
    May 2002
    Sacramento
    Yeah i did the same thing, except with Duct tape instead of getting all fancy like you did.
    MisterX's Avatar
    May 2002
    Getting "all fancy" cost me about $5.00 and 1/2 hour of time. Maybe less. (Time and Money).
