knock?
Results 1 to 9 of 9
This is a discussion on knock? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; i just installed my Vf34,fuel pump,injectors. and im getting some knock! im running the base stage 4 map on my ...
    Registered User black's Avatar
    Dec 2002
    grand junction co
    knock?
    i just installed my Vf34,fuel pump,injectors. and im getting some knock! im running the base stage 4 map on my uteck and was getting about 18psi so i closed the abc and now im getting about 15.5psi but i still get knock. im about 5000 feet up and only get 91 octane gas, so what can i do to get ride of the knock,maybe octane boost or colder plugs? i cant do any tuning on the map because my laptop took a crap on me and i don't have money for a new 1.
    also i will be installing a FMIC as soon as the where gets nice here!
    any help would be nice!
    Feb 2004
    Buffalo, NY
    A tune .
    SMC
    SMC is offline
    Registered User SMC's Avatar
    Nov 2003
    KY
    knock
    Two words......Alcohol Injection. Plenty of GN's running 20+psi on pump gas, no problem. It just hasn't been pushed in this market....YET.
    MisterX's Avatar
    May 2002
    Prague, Czech Republic
    Just turn the boost down before. Then get a tune.
    Banned hippy78's Avatar
    Jun 2003
    I third the tune. If you can change the maps though, a good place to start would be retarding the whole timing map 3 degrees(since you're on 91 octane).
    peace
    SMC
    SMC is offline
    Nov 2003
    KY
    timing
    I shouldnt have even said anything.......soon enough you will understand.
    Registered User qoncept's Avatar
    Oct 2003
    Montgomery, AL
    Re: timing
    I haven't seen much for good results with alcohol injection, but one thing is for sure -- if he doesn't have enough money fo ra computer, he can't afford alcohol injection. My dad put water injection in his truck for under $100 and now runs 91 octane pump gas instead of 5 gallons of 104 octane race gas + 93 for the rest per tank.
    I've looked and looked and I haven't found any concrete evidence. I'd like to do water injection myself, but I don't have the means to tune it or plan to spend the money on a UTEC and whatnot. In a big block Chevy like my dad's you don't need to do much tuning, but that's not the case in a WRX.
    Dec 2002
    grand junction co
    i will get a tune soon but i have to wait until the weather is good. so what can i do in the mean time to get rid of this knock. i took my computer in to a shop to get it fixed after my first post and it will be done in about a week after that i can do some tuning, so what would i need to do to have it run right no 91octane? just retarding the whole timing map 3 degrees? thanks for all the help!
    ryan
    SMC
    SMC is offline
    Nov 2003
    KY
    water....no thanks!
    Screw water injection.......
    Has maybe 1/6 the potential of the alcohol.
    Whatever you can do tune & boost wise on 104 octane you can do with pump gas & alky. Don't worry...an upcoming "Sport Compact Car" issue will show you the way.
