Put your thinking caps on- need to "fix" mounts for USDM STi IC - Page 4
Page 4 of 6 FirstFirst 123456 LastLast
Results 46 to 60 of 86
This is a discussion on Put your thinking caps on- need to "fix" mounts for USDM STi IC within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; good suggestion on the clamps!...
  1. #46
    Jul 2001
    Plains of Eastern Montana
  3. #47
    Sep 2005
    Houston, TX
    i'm curious why you went with an STi tmic instead of a bar and plate tmic. aren't STI's not supposed to cool as well? well, i'm weighing my options since i need a new i/c and trying to decide between STi or gigantic ebay. both have the bracket problem and a similar hose problem of not being long enough so y this one?
    btw, what would i have to do as far as my stock splitter and hoodscoop?
  4. #48
    Jul 2001
    There are pros and cons to finned vs bar/plate, a guy has to weigh them out. If the ebay IC's hold up that's great, I don't think anyone is worried on the STi ones.
  5. #49
    Sep 2005
    Houston, TX
    Quote Originally Posted by Big Sky WRX
    i read that there are pros/cons to each design but i don't know any of them. i know those ebay ones are something like 20+ pounds though, and i'm pretty sure mine is more like 8-10. maybe its just cuz its huge, but do you know how much the STi i/c weighs?
  6. #50
    Jul 2001
    It only weighs a lb or two more than the stocker IIRC
  7. #51
    GDR
    GDR is offline
    Registered User GDR's Avatar
    Apr 2003
    Corona, Ca
    SFS Hose
    http://www.aaroadracing.com/shop.net...d=377&catid=70
    I used the 48mm(1.889") size. There's plenty of length on the ends to trim off.
    The size was hard to find. Most places go from 1 3/4" to 2" and skip the 1 7/8" or 48mm size. Samco had this size but nobody in the US had it in stock.
    http://www.sporthoses.com/parts/FMPr...-max=all&-find
    Sporthoses carries the Samco line but didn't have the 48mm in stock when I checked a few months ago. I would call them direct to check stock. Its 3 weeks to get it from England if they don't have it here.
    I got the Samco after about 6 weeks. (I thought I canceled the order) The Samco has a larger raidus in the bend which looks better for flow. But by the time you trim the ends off to fit in this application you have very little straight sections left for your connections. Just by looking the SFS hose has equal or better construction. SFS is whats shown below.
    The TD04 is 1.890" with a 1.960" lip. I forgot the numbers but the cast Y is alittle larger than the TD04 outlet. 48mm fit tight on the Y and perfect on the turbo. I've heard of others recommend 2" which is too sloppy for me.
    Get rid of the stock hose clamp. It chewed up my sti hose. Get some T bolt clamps or the non preferated hose clamps.[/QUOTE]
  8. #52
    Registered User WRXreX's Avatar
    Mar 2002
    NY
    I ordered 2" ID hose from this place. I will find out if it fits too sloppy.
    http://www.stylinmotors.com/90Elbow.html
  9. #53
    Mar 2002
    NY
    if the brackets need to be bent, both D/P side brackets must be bent? Will TMIC be sitting noticeably angled due to bent brackets?
  10. #54
    GDR
    GDR is offline
    Apr 2003
    Corona, Ca
    Quote Originally Posted by WRXreX
    You don't need to bend anything. The only reason people are bending things is to get the sti y pipe and hose to fit up to the TD04. If you had a VF39 then all the Sti stuff would fit perfect.
    My bracket mod was mainly to get the V7 Sti splitter and seal to match the IC.
    You don't need to do that anymore. Just use the US STI seal.
    Bugeye JDM V7 scoop and splitter+US STI seal(bellows)
    04-05 Stock scoop( same height as V7 sti) +V7 splitter+US STI seal
    04-05 US STI scoop,splitter and seal
  11. #55
    Mar 2002
    NY
    I have found a way to install STi TMIC with Samco I/C hose. In terms of length, it's about the same as stock pipings. However, it's more elastic and allows you to bend it about 1" to create perfect fit. Here is how you do it.
    - When installing STi TMIC, turbo -> Y-hose must be connected FIRST. Otherwise you will encounter fitment problem (hose being too short). Once you tightened turbo -> Y-hose clamp, next step is to connect I/C to intake hose. You will find it extremely difficult to make the hose fit due to tight space. One way to resolve this issue is by putting the I/C -> intake hose on the intake manifold side first. Once you tightened the clamp on intake side, then you can slowly make hose fit on the I/C side. You may need to use a screw driver as a lever.
  12. #56
    Mar 2002
    NY
    Quote Originally Posted by GDR
    I have STi scoop with USDM TMIC.... do I really need STi seal?
  13. #57
    Jul 2001
    A couple of things- the aluminum Y pipe that comes w/ the STi is a dandy- I'd very much hate to give it up. Make sure there are no ristrictions/kinks w/ the Samco, yes it will bend easily, but that could be problematic as well (you need to check carefully).
    Yes - you NEED the STi seal- your oem seal is the wrong size and not sealing your IC correctly- having the intercooler sealed correctly is probably one of the most important things in insuring a efficiently running IC
  14. #58
    Mar 2002
    NY
    my installation is using stock samco I/C hose from WRX... when I got my STi TMIC, it came with stock y-pipe from WRX.
  15. #59
    Mar 2002
    NY
    Question for GDR, I have used Samco I/C y-hose removed from my WRX IC set up. In terms of hose diameter, etc are they equivalent? Unfortunately, mine didn't come with STi y-pipe.
    Thanks in advance,
    Tim
  16. #60
    GDR
    GDR is offline
    Apr 2003
    Corona, Ca
    Thanks in advance,
    Tim
    I'd say they are close enough in dismeter but just like you found out here
    http://forums.nasioc.com/forums/showthread.php?t=951527
    The hose is too short front to back which is pulling the IC forward and so it doesn't line up with the brackets.
    Somebody already did the "Samco Y" mod. Go search for it here or at nabisco. Basically they added a metal pipe extention in the straight section between the Y and 90 to get more length.
    Until you get the IC straightened out so it bolts into the brackets without bending or forcing don't bother with any of the factory rubber seals as it won't work with a cockeyed IC.
    What exactly do you have on top?
    Scoop
    Duct (splitter)
    Bellows (rubber seal)
    Like BigSky said don't use the WRX duct and seal. Its too small. The hot side over over your unshieled turbo and dp will get no cooling air flow at all.
