Help! Can't get the I/C back on
Results 1 to 15 of 26
This is a discussion on Help! Can't get the I/C back on within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I am finishing my ScoobySport Stage 1+ install, and we can't seem to get the stock intercooler back on. The ...
    Nov 2003
    I am finishing my ScoobySport Stage 1+ install, and we can't seem to get the stock intercooler back on. The problem is the small plastic hose DOES NOT want to go back on to the turbo. We hit up the turbo with a little grease to help it slide on, even hooked some chord onto that strange plastic hook to pull the hose onto that metal port. No luck, we even removed that big diameter but short rubber hose into the intake manifold so we have a straight shot. My silicone hoses may come soon, but I need to drive this thing tomorrow! Thanks for your time.
    Registered User MtnWRX's Avatar
    Dec 2002
    Amongst the trees & boulders
    Take a heat gun (a hair dryer may do) and warm up the end of the Y pipe until it's good and flexible (don't melt it). It will flex a lot easier when you push it over the turbo, that way. Also, lubricate the inside of the Y pipe and ourtside of the turbo with some soapy water. It's slick, evaporates away and won't weaken the plastic later. Good luck.
    Leo
    "Stupid should hurt."
    Registered User NJwrbT-WRX's Avatar
    Apr 2002
    One Square Mile, NJ
    Not that this will help (the heat gun should) but I would suggest getting some silicone IC hoses (Perrin or Samco). They give a small HP increase, smotth the car out a bit, make uninstall and install of the IC so much easier, and they are much more durable than the plastic stock hoses. A great mod for $130 or so.
    -joe
    '02 WRB Sedan
    Removed silencer w/ Akimoto Velocity Stack, Blitz Dual TT, Autospeed Prototype Up-pipe w/ Flex-joint, Autospeed Crank Pulley, Autospeed OEM Dead Pedal, Samco IC Hoses, Axxis Pads, Goodridge Lines, Neo Synth Brake Fluid, Speedbleeders, Eibach Pro-Kit, Perrin Endlinks and Rear Sway, 17" Sub Zeros w/ 225/45 ES100s, Crucial Racing Thermostat and 1.4bar Radiator Cap, Autometer Sport-Comp Oil Pressure, EGT, and Voltmeter on the A-Pillar, STI Hoodscoop.
    Registered User skoobywrx's Avatar
    Nov 2002
    Seattle
    gets some rope and put it around the intercooler hose and pull it towards the turbo.......
    doing it by hand, its really hard to get the hose back on the turbo, and your not at the right angle to put it on
    so loop around the hose, pull it straight inline with the turbo and it should fit good...
    Registered User PKer's Avatar
    at work
    I think the hairdryer is an excellent idea.
    Good luck!
    Registered User Shard's Avatar
    Jan 2003
    Houston TX
    The best way to do this is to use a screwdriver to pry it on. They provided a bracket on the stock hose for this sole purpose, it works like a charm. If anyone has a pic you'll see it.
    skidpad kid: you're the BOMB
    Shard of me: i know
    Joshiscookin: Hey fragment.
    Jan 2003
    Houston TX
    It's at the top of the hose in this pic.
    (IMO silicone hoses are harder to put back on that stock [using a screwdriver and bracket])
    You will need a long screwdriver or metal pole or something.
    Shard of me: i know
    Nov 2003
    two new problems
    Yeah, I ordered those silicone hoses 3 days ago, I just wanted to get everything else back in first.
    Well, turns out my friend got it on while I was posting so thanks for the help anyways. Now I have 2 more problems to troubleshoot with my UP/DP install.
    1) I have an exhaust leak between the DP and Midpipe. This is without a doubt caused by the fact that I am using an old gasket and also I don't have the bolt in (the stud is in). I cannot for the life of me get that dumb bolthole to line up. I tried pressing and even jacking up the flange on the midpipe but it will not align with the downpipe. I thought maybe I could drive to a muffler shop and see what they could do for me- but I don't want to.
    2) No boost! Up on jackstands and ramps, I turned on my car just to see what would happen. Mind you, I have a leak at the bottom of the DP. But when I rev it up to 5k, it doesn't get any positive boost pressure, and it almost whistles like a BOV or something. And also strangely, when it revved it up to 3k it would not rev back down at 2k it hung there for 2 sec.... doesn't make any sense.
    Despite all this I do not have a check engine light, and I don't hear anything that sounds like an UP or DP/turbo leak (whatever that sounds like). Any ideas? Thanks.
    Zem
    Zem is offline
    Registered User Zem's Avatar
    Jul 2003
    Stalking Jay
    No load, no boost.
    Exhaust leak in the low pressure? Fuhgeddaboudit.
    Let justice be done though the heavens should fall.
    -John Adams
    Registered User BlkWRXWag's Avatar
    Jan 2003
    Trabuco Canyon, CA
    I'm not sure you'll see boost just revving the car on the jackstands. The engine needs to be under load to produce boost. Take it for a spin and see if you still have no boost.
    Nov 2003
    Originally posted by Zem
    No load, no boost.
    Hey Zem, not trying to be a smart-azz but I'm pretty sure that I have seen boost just revving the engine in neutral.
    Is your second statement supposed to mean that the DP to MP leak would be the source of my lack of boost? Please elaborate, I am confused and slightly frustrated right now.
    If it weren't for the sweet sweet sound it makes when it idles I would be a mess right now...
    Moderator aussieinstlouis's Avatar
    Jun 2002
    S34 47.322 E138 29.131 (WGS84)
    You won't see boost in neutral (maybe 1psi) but not any more than that.
    Nov 2003
    Really? Maybe all that time I saw boost while revving the engine I was in 1st gear with the clutch in. I forgot the new "smart" manuals monitor what gear your in and tell it to the ECU. Thanks for the tip, I still need to fix that leak however. Maybe I can post up a pic to show how close it is. Dang it. I used a hydraulic jack to lift the flange of the midpipe and that didn't even help. Maybe loosening the motor mount???
    Registered wrxinthehouse's Avatar
    Nov 2001
    awdpirates.net
    +1.
    Catalytic converters are for hippies.
    Registered User tubbytreats's Avatar
    May 2003
    I agree, you won't see ANY boost increase over 0 until you place load on the engine.
    This confused the snot out of me during my boost gauge installation. Taking it for a spin solved the issue.
    2002 WRX Mods:
    AP Stage2/93, ScoobySport Up, Dp, & Muffler, SS AutoChrome TMIC, Hawker PC680T Battery, Injen CAI, ACT Stage2 Clutch, Gruppe-S 13.8lb Flywheel, Mobil1 and Redline oil, NGK BKR7EIX plugs, Goodridge SS Lines, Motul RBF600, Hawk HPS pads, 35% 3M tint, Koji Headlight Mod, SilverStar Bulbs, Blaupunkt MP3000 headunit, Infinity BassLink Sub, Kenwood KFC-1689ie speakers (6.5"F / 5.25"R), Rota Downshift (Black), Yokohama AVS ES100 (225/45/17)
