Why did I get a P0546?
Results 1 to 15 of 27
This is a discussion on Why did I get a P0546? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; So why would I get a P0546 (high EGT)? I have a feeling but tell me if I'm right. Mods ...
    Registered User PKer's Avatar
    at work
    I have a feeling but tell me if I'm right. Mods are: gutted OE uppipe, catless turbo-back, Samco I/C hoses, and STi hoodscoop.
    OK here's my theory. When I put the STi scoop on I didn't reset the ECU. It was a cool night and I was cruising on the freeway in 5th I started going up a pretty steep grade but left it in 5th. Under a high load/boost situation, the ECU didn't compensate for the extra cool charge air and I ran lean.
    I didn't think the STi scoop would make a difference. Am I on target here?
    Registered User CKxx's Avatar
    Feb 2003
    Pennsylvania
    Are you sure it wasnt "High Input?" Because that would signify a lower EGT, which is correct.
    I created my avatar.
    cnk
    cnk is offline
    NJ
    Your EGT sensor in the uppipe is not reading correctly due to the catless uppipe. The fix is to disconnect the EGT sensor and put a 2.2kOHM 1/2W resistor in to the ECU side.
    Calvin
    at work
    Well according to the book it is "P0546 Exhaust Gas Temperature Sensor Circuit High (Bank 1)"
    Registered User BlkWRXWag's Avatar
    Jan 2003
    Trabuco Canyon, CA
    Seb,
    Your stock EGT probe in the uppipe has burnt thru - this happened to me as well. You need the EGT resistor mod - so simple even I was able to do it. For $1, it's worth a shot anyway!
    -Max.
    Registered User AjIsDope's Avatar
    Aug 2002
    SoCal
    Calvin
    That's what I did and I have not had a problem thus far. PKer, I have some extra resistors lying around if you want to pick one up. I can even install it for you.
    03 Cobra
    566whp/515wtq
    Pics
    & Dyno
    Pics
    Registered User Wade-0's Avatar
    Dec 2002
    Southern Orygun
    Originally posted by BlkWRXWag
    Seb,
    And if you don't get it out of there soon, it could fall apart and destroy your turbo. Do the resistor mod ASAP and plug the EGT bung!
    Jan 2003
    Trabuco Canyon, CA
    Really - I had not heard of that. Mine has been sitting in there burnt out for 11,000 miles!! Should I be very concerned?
    Aug 2002
    SoCal
    What size plug will fit in the EGT bung?
    Dec 2002
    Southern Orygun
    EGT Bung replacement bolt size...
    Aug 2002
    SoCal
    Thanks
    at work
    So is it really is a false reading? I don't want to cruise around with no EGT sensor and not know if there is an actual problem.
    I don't have an EGT gauge and didn't plan on getting one anytime soon since I don't plan on upping the boost.
    I had a resistor on my old car since the Autospeed flex uppipe has no bung.
    Aug 2002
    SoCal
    at work
    Aj: are you going to South Coast or Rallycross on Sat.?
    Aug 2002
    SoCal
    Nah, I have to work. :-/
