ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
Go Back   ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums > Tech & Modifying & General Repairs > Engine Modifications
Engine Modifications Flat-fours and turbochargers are what set the WRX apart from the rest. Talk about them and the latest aftermarket parts here.
Advertise On ClubWRX
Reply
LinkBack Thread Tools Rate Thread Display Modes
Old 09-29-2003, 01:53 PM   #1 (permalink)
My Twin Walbro 255 Fuel Pump Set up. Pictures and Info
I was tossing around the idea of either one 310 fuel pump or 2 walbro 255 fuel pumps. With alot of talking and researching i decided to go with two fuel pumps. Its cheaper, flows more, and is something i wanted to see if i could do. I talked with a few supra tuners and they told me how to do it. Basically this is it. I drilled a hold for the fuel feed and welded a tube to a fitting. Then sandwiched the fitting with a special washer, a nut, and some chemical proof silicon. I ran the wires through another hole and used silicon on both sides to seal it. The power Wires are relayed and hardwired to the battery. Each fuel pump is fused with a 20 amp fuse. The relay trigger switch is run off ignition with a switch inline to kill the power if need be. This set up will be pushing an extremely large amount of fuel. I have switch the fuel return line with the fuel feed line. Now the fuel returns to the tank using the larger feed line. The fuel pressure will be increase alot due to the small return line, but i can fine tune it with the fuel pressure regulator. I am sure some of you will have doubts, but i just tested it and it works.
STEALTH-WRX is offline   Reply With Quote
Old 09-29-2003, 01:54 PM   #2 (permalink)
another
Old 09-29-2003, 01:56 PM   #3 (permalink)
3 more
Old 09-29-2003, 01:56 PM   #4 (permalink)
2 more
Old 09-29-2003, 01:57 PM   #5 (permalink)
last one
Old 09-29-2003, 01:57 PM   #6 (permalink)
Mili727's Avatar
Send a message via ICQ to Mili727 Send a message via AIM to Mili727
Nice job, when are you getting tuned?
Mili727 is offline   Reply With Quote
Old 09-29-2003, 06:20 PM   #7 (permalink)
BoarderEight's Avatar
Send a message via AIM to BoarderEight
WoW. You never cease to amaze me. Say bye bye to gas mileage!
__________________
BoarderEight
BoarderEight is offline   Reply With Quote
Old 09-29-2003, 06:32 PM   #8 (permalink)
I honestly dont think my gas milege will be that bad. I bet with low boost and a good tune i can pull 20+miles/Gallon. I am sure on high boost like 10miles/gallon
Old 09-29-2003, 10:11 PM   #9 (permalink)
BoostedBoxer's Avatar
Send a message via AIM to BoostedBoxer
that is a very nice setup. My hat is off to you for your skills. How much psi are you expecting?
__________________
My Car is 100% STOCK!
Pics
Quote:
Originally posted by platano
At 14???
shoot , I'd hit it at current age, on roof of the car, with cousin driving , neighbor and town priest in the back seat, and that kid from "N.Korea" riding shotgun.
BoostedBoxer is offline   Reply With Quote
Old 09-30-2003, 10:03 AM   #10 (permalink)
CKxx's Avatar
Send a message via AIM to CKxx
Shouldent the pressure be the same? Its just going to have a much higher volume...
Stealth, will both pumps be running full time? How is it wired? Im sure you already know to make its own curcuit so that if power is cut, they both die instead of underfulling on one pump.
Also, are you going to use some sort of fuel cooler? Are you worried about fuel temps rising since its going to be recirculated so much?
Sorry for so many questions, im just modding vicariously through your cool ass project.
__________________
I created my avatar.
CKxx is offline   Reply With Quote
Old 09-30-2003, 11:36 AM   #11 (permalink)
I was thinking that the pressure would go up because the fuel would have a harder time to return since there is about 4 times as much as stock. As far as the fuel cooler: I have no idea.
Old 09-30-2003, 07:15 PM   #12 (permalink)
CKxx's Avatar
O ok, I never thought about the fact that the return would bottleneck it. Cool stuff.
__________________
Old 09-30-2003, 07:28 PM   #13 (permalink)
MJU1983's Avatar
Send a message via AIM to MJU1983
cool set up... this is the one that was used in the project car i posted about earlier...
For high horsepower EFI applications making up to:
1600 HP - Naturally Aspirated
1100 HP - forced air induction
-mike
MJU1983 is offline   Reply With Quote
Old 10-01-2003, 01:11 AM   #14 (permalink)
I actually wanted to go with that one but for the money you cant go wrong. With all the lines, fittings and pumps I spent about $150 total. The aeromotive is $400. Plus the aeromotive only produces around 40lbs/hr more at 12v then my walbro's. I love the aeromotive pump though. I just need to budget my money.
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertise On ClubWRX -->
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.1.0
Copyright 2001-2008 ClubWRX.net
Inactive Reminders By Icora Web Design
