Fabricate a Bell-Mouth Opening on a Stromung Downpipe? Whaddya Think? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
This is a discussion on Fabricate a Bell-Mouth Opening on a Stromung Downpipe? Whaddya Think? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; russ, That's alot of clams for opening the mouth up. If the bellmouth design is important enough you might want ...
    Jul 2001
    Plains of Eastern Montana
    russ,
    That's alot of clams for opening the mouth up. If the bellmouth design is important enough you might want to consider the ScoobySport, it's more expensive than the Stromung, but not $250 more expensive. Then again like you said you may have no problems at all.
    I'm also curious when you get your FP turbo back- this sounds like a good way to go for someone who wants a little more performance and values a quick spooling turbo.
    Big Sky
    MisterX's Avatar
    May 2002
    Prague, Czech Republic
    But I already have the Stromung. As I understand it the 2.5" is better for low end torque.
    Their customer service is not great. I called to discuss this with Stromung and never received a return call as promised.
    Jul 2001
    ScoobySport is also a 2.5 " system (one of the reasons I've chosen their exhaust- the bell mouth design the other). You could always try and send it back- they may not be thrilled with that option however.
    When is your turbo due back? Did they give you any guesstimates on gains w/ it?
    Big Sky
  6. #19
    Registered User EIonJess's Avatar
    So Cal
    Originally posted by bedabi
    Thanks for your input, everyone! Yeah, I think you're right. I'll go with Stromung after all.
    I'll be getting mine from Teague's Auto. http://home.att.net/~teaguesauto/index.htm
    The Stromung downpipe with cat is $259. A catless downpipe is $199.
    Do you know if either of the Stromung downpipes with or without cat will give you a CEL? I already have an up-pipe installed.
  7. #20
    Jul 2001
    With cat no cel, w/o cat cel. The 2nd O2 sensor is after the 2nd oe cat in downpipe, when that cat is removed (via catless dp) the O2 sensor reading causes a cel- cat inefficiency code. There are a couple of ways around the cel- one is electronic fix-fools the ecu into thinking everything is AOK w/ the 2nd cat. The other is to relocate the O2 sensor downstream of oe cat #3. The third option is to have a cat in the downpipe- Stromung, Graham Goode, others. The fourth option is godspeed's downpipe, no cels by using a top secret "micro" cat. In all of the reading I've done the cel P0420 will cause no harm, just headaches.
  8. #21
    So Cal
    Thanx for the info, I am going with the Stromung downpipe with cat. I have enough headaches in my life.
  9. #22
    Registered User z3coupe's Avatar
    Dec 2001
    SoCal
    GUYS!!!!!!!
    With the PDE cat-LESS Up/Down pipes, I get NO cel's at all - except recently. And that is because the EGT has gone bad - ONLY that. And Ian has told me that these are know to go bad a lot. Other than that - his exhaust works GREAT! So, as Stomung don't give a rats ass about talking to anyone - GET THE PDE pipes!!!!!!!!!!!
    Rocky Zamarocy
    Cal Club #476
    SCCA #R 306533
    05 Blue Pearl WRX STi
    in the new STU class
  10. #23
    So Cal
    Question Downpipe install
    Just wondering....how difficult is it to install a downpipe? Anything like installing an up-pipe? Anything in particular I should watch out for during the install??
  11. #24
    MisterX's Avatar
    May 2002
    Downer is easy. I was told to watch out not to overtorque the bolts. I believe Vishnu might have the torque specs on his site.
  12. #25
    So Cal
    Any idea what the performance difference is between a non cat downpipe as oppsed to a one with a hi-flow cat?
  13. #26
    Jul 2001
    Torque specs for down pipe (top and bottom) 35 ft lbs. some are putting in a new gasket (top), others aren't- I am- part #44022AA150.
    Depends on the cat that is in the down pipe- a race cat (lots of $) won't be a lot of difference. Your "basic" high flow probably giving up a few ponies to decatted one. Either will be a vast improvement over the oe, which is pretty restrictive.
    Big Sky
