Water Injection Installed - Page 6
Page 6 of 7 FirstFirst 1234567 LastLast
Results 76 to 90 of 95
This is a discussion on Water Injection Installed within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally posted by aussieinstlouis It shouldn't you are not injecting water at idle or stop. start the car and confirm ...
  1. #76
    Aug 2001
    Marin County, CA
    start the car and confirm that the green 'fuel injector' light is flashing on the controller
    The fuel injector light does flash on the controller.
    Do I have to prime the pump also? Or will it fill the hose when water injection is working?
    I ran around the block real quick the red light turns on for the water injection. It just hasnt moved any water from the tank to the pump yet.
  3. #77
    Moderator aussieinstlouis's Avatar
    Jun 2002
    S34 47.322 E138 29.131 (WGS84)
    here is a quick check you can do with the car parked.
    unplug the connectors on the pressure manifold - the pump should start
    you may also want to 'prime' the pump by undoing the feed to the pump and sucking the water through before reattaching it
  4. #78
    Aug 2001
    Marin County, CA
    I unplugged the connector to the pressure manifold and the pump does not start. Must be wired wrong then, 12V ignition incorrect?
  6. #79
    Jun 2002
    yeah - it should start when you do that - check that 12V ignition (purple wire)
  7. #80
    Aug 2001
    Marin County, CA
    I tested the puple wire from the12V ignition all the way to the 40A relay and I have power all the way there. How is the relay suppose to work?
    I also used my tester to connect the circuit and the pump turns on so I know that works, it just does not work if I do not complete the circuit.
    I checked the power wire comming out of the 40A relay(right at the plastic relay piece) and it has no power. So I get power into the relay but not out of it to the pump.
    Any ideas? Do the wires comming off of the pressue sensor switch(806-162) have to be on a certain way? IE + and - side?
  8. #81
    Jun 2002
    Do you have 12V constant on the red wire and a good ground on the black that go to the relay?
    The red and black provide the power for the pump. THe purple simply closes the relay to apply that power.
  9. #82
    Jun 2002
    the pressure manifold and the pressure switch have no polarity
  10. #83
    Jun 2002
    Have you checked the 15A pump fuse?
  11. #84
    Aug 2001
    Marin County, CA
    I have a 12V constant on the red wire a rechecked the ground. It looks good also.
    On the relay itself, I have power comming into it on the red wire and purple wire, but there is no power comming out of the 15A fused wire. I checked the prong at the relay itself and there is no power comming out of the relay on the 15A fused wire. Could the relay be bad?
  12. #85
    Jun 2002
    have you got the relay properly seated in the connector?
    There is some possibility that the relay is bad - you should be able to hear the relay click when you apply power to the purple wire.
    Have you pulled the fuse out and checked it?
  13. #86
    Aug 2001
    Marin County, CA
    I reseated the connection to the relay a few times and still no power to the fused line. I pulled the fuse and it looks ok, I also checked for power where the fused line connects to the relay and no power.
    There is no click noise when power is applied to the purple wire. The only thing I do get is power out of the center plug off the 40A relay side. Not sure why since it does not appear to connect to anything.
  14. #87
    Jun 2002
    Contact Richard Lamb at www.aquamist.co.uk
  15. #88
    Aug 2001
    Marin County, CA
    Crap, finally got it working
    It was a bad relay. Replaced it and now everything works.
    Thanks for all the help
    Now to get it dyno tuned next week
  16. #89
    Jun 2002
    good to hear!
  17. #90
    Registered User Phat04WRX's Avatar
    May 2004
    Los Angeles
    did you get it dyno tuned? can you feel the difference?
