Water Injection Installed - Page 5
Page 5 of 7 FirstFirst 1234567 LastLast
Results 61 to 75 of 95
This is a discussion on Water Injection Installed within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally posted by aussieinstlouis yeah it came with it - you are sure it is not just tightened down a ...
  1. #61
    Aug 2001
    Marin County, CA
    yeah it came with it - you are sure it is not just tightened down a long way on the pump?
    It is what holds the tube to the pump....
    I took pics of it and sent it to the place I bought it from. They are sending out a replacement piece.
    How/where did you connect the purple wire from the 40A relay? It looks like it just wants a 12V+ connection but not from the battery.
  3. #62
    Moderator aussieinstlouis's Avatar
    Jun 2002
    S34 47.322 E138 29.131 (WGS84)
    It is a 12V ignition switched so that it is not trying to maintain 6 bar of pressure all the time. I used a 12V ignition source under the dash as there was already wiring running there.
    Like I said - the wiring is the biggest headache with this install.
  4. #63
    Aug 2001
    Marin County, CA
    Sorry for all the questions, by the time I have this installed you will have created one heck of a faq
  6. #64
    Registered User Bilkid's Avatar
    SO CAL
    I feel a sticky coming on.
  7. #65
    Aug 2003
    Guys, I just installed my System 2D but one question, I have the purple wire connected to the 12V ignition lead. Does your water pump constantly running?
  8. #66
    Jun 2002
    It does if you do not have the pressure manifold hooked up.
    The pressure manifold tells the pump to keep pumping until it sees 6 Bar of pressure. This ensures a constant flow rate on the nozzle.
  9. #67
    Aug 2003
    I got the pressure manifold connected but forgot to prime the system hence a hydro lock was evident. Had to remove one of the blanking plugs on the pressure manifold and let the system run until water exits the manifold. Thanks.
  10. #68
    Aug 2001
    Marin County, CA
    I have just about everything hooked up except for the puple wire off the FIA2. Not sure what it is suppose to hook up to? It says FL % monitor but I dont know what that is.
  11. #69
    Jun 2002
    The purple wire is an output and you do not have to hook it up. It gives a 0-5V output proportional to the mapped fuel injector. I hook it up to my SBC-iD so that I can monitor IDC.
  12. #70
    Aug 2001
    Marin County, CA
    from a 12V ignition source wire the LED and resistor in series and connect the float switch between that and a ground. That is it. Make sure the switch is mounted the right way so that it CLOSES when the level is low. You can get the LEDs with the mounting bezel like in my install for about a buck.
    I think this is my last question. I have everything else wired up except for the float switch.
    The float switch has 2 wires comming off of it. 1 wire is suppose to be grounded(to the chasis or black wire with the 2D system or to the ground side of the LED?) and the other wire connects to the 12v ignition then to the resistor and LED?
    Thanks for all the help
  13. #71
    Jun 2002
    here is a picture
  14. #72
    Aug 2001
    Marin County, CA
    Thanks
  15. #73
    Jun 2002
    No worries - this thing will blow your socks off!!
  16. #74
    Aug 2001
    Marin County, CA
    I turn on my car and the aquamist water pump does not run. Did I not connect it to a proper 12V ignition?
  17. #75
    Jun 2002
    It shouldn't you are not injecting water at idle or stop.
    start the car and confirm that the green 'fuel injector' light is flashing on the controller
