Water Injection Installed - Page 2
Page 2 of 7 FirstFirst 1234567 LastLast
Results 16 to 30 of 95
This is a discussion on Water Injection Installed within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; THe 2D is inbetween. It maps the water injection rate off the fuel injector. check www.aquamist.co.uk for full details. Richard ...
    Moderator aussieinstlouis's Avatar
    Jun 2002
    S34 47.322 E138 29.131 (WGS84)
    THe 2D is inbetween. It maps the water injection rate off the fuel injector. check www.aquamist.co.uk for full details. Richard Lamb is very responsive to all tech inquiries.
    Registered User driggity's Avatar
    Aug 2002
    Renton, WA
    Aha, I forgot about that one Are you running some form of engine management or was that extra power just due to a cooler charge temp?
    Big pimpin' in a Legacy GT Wagon
    R.I.P. WRX Wagon
    Registered User is2scooby's Avatar
    Jun 2002
    Honolulu, HI
    VERY slick! *drool*
    Aloha, Richard...
    Retired Moderator
    TXS Stage 4 UTEC + TMIC + JoeP
    12.75 @ 105.67mph - 1.74 60'
  6. #19
    Registered User AjIsDope's Avatar
    Aug 2002
    SoCal
    So basically this just cools down the aire charge to allow cooler air into the intercooler?
    03 Cobra
    566whp/515wtq
    Pics
    & Dyno
    Pics
  7. #20
    Registered User tuca33's Avatar
    Aug 2002
    Brazil
    How does that thing work?
    Tuca
    2002 Black Wagon WRX
    315HP With the PM-ID
  8. #21
    Registered User WRXG0blin's Avatar
    California
    Looks like a nice clean job.
    Would it be a good idea to combine this with a mister system for the top mount IC?
    -1986 RX-7 GXL
    -2002 Blue WRX Wagon (given up)
    -2001 Prelude, (sold)
    -1989 Accord, (sold)
    -1984 Dodge RamCharger (Sold)
  9. #22
    Jun 2002
    Honolulu, HI
    Yes, the system introduces water (which is excellent at absorbing heat) to cool the intake charge and lower peak combustion temperature. This allows for a denser intake charge (somewhat) but is most useful in controlling pre-ignition and detonation allowing one to run higher boost and/or ignition timing. You can also lean out your air/fuel mixture to a more optimum ratio because the rich mixture you normally need to run to cool the cylinder is no longer necessary...
    Aloha, Richard...
    Retired Moderator
  10. #23
    Aug 2002
    SoCal
    I kind of figured it would create a denser intake charge since it will introduce more oxygen into the intake. Thanks Richard.
  11. #24
    Jun 2002
    I have done nothing to take advantage of the WI yet - I have a unichip so the ECU has some self learning it can do. I will be changing to a TXS v2 TMIC in a couple of weeks and in July should be able to get my car on a new dyno here in St Louis. THere is a unichip tuner here at Axis Motorsports who are getting the dyno.
    Then we see what we can do!
    Another guy here in St Louis running a WI system and a UTEC is getting excellent gains - that is after he already dyno-ed at 310whp!!!
  12. #25
    Registered User BobbyD's Avatar
    Apr 2002
    Indiana
    wow sweet!!
    that is a sweet setup man...if you dont mind me asking...how much did you pay for the system and how much did u pay or how much time did it take you to install it?? Thanks
    -Bobby D
  13. #26
    California
    it looks like its connected after the intercooler, you could probably use it for more than just water.
    -1986 RX-7 GXL
  14. #27
    Jun 2002
    Re: wow sweet!!
    -Bobby D
    I paid $500 for the 2D from PPE Engineering under the group buy on NASIOC. The total install time would be around 3-4 hours with lots of head scratching on where to put stuff.
  15. #28
    Jun 2002
    No nitrous for this little black duck! I am only after the WI to allow me to go over the 300whp and have the ability to deal with lower octane gas if need be.
  16. #29
    Moderator fengshui's Avatar
    New Jersey
    Congrats man. Now you can reliably up the power and have a real road monster on your hands. Good pics as well for anyone interested in this mod.
    chris
    Moderator: Retired
    2002 Subaru Impreza WRX Sedan 5MT - Road Rally - Best 1/4mi: 13.954 @ 97.36mph (3448 lbs)
    2001 Mazda Miata 5MT - AutoX #99 (NNJ Region SCCA 2005 CStock Champion)
    1988 BMW 325 (2.7L "i" conversion) Sedan 5MT - Daily Driver (AutoX soon!)
    "If you can't drive this car fast you can't drive fast." --British Magazine, CAR, on the WRX
  17. #30
    Jun 2002
    I had the intercooler water spray before I went with WI!!
    I have the MRT water spray controller. I triggers based on boost and the temp of the air after the intercooler.
