| Home | Forums | Gallery | Register | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
| Engine Modifications Flat-fours and turbochargers are what set the WRX apart from the rest. Talk about them and the latest aftermarket parts here. |
| Advertise On ClubWRX | |
| Welcome to the ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums. | ||
Thread Tools | Rate Thread | Display Modes |
#1 |
Joe P MBC install(hoses)
Just install my Joe P. They supplied a lot of hose. Should I trim to what I need or just leave it? Does it make it perform any different?
__________________
Stg 2 06STI 02/04 WRX MSPT Tuned - 18g(DEAD) "Never go in against a Sicilian when death is on the line!"-Vizzini Last edited by Needles; 04-29-2003 at 09:47 AM. |
#2 |
im getting mine this week.. was the install easy??? was the hose they gave you larger than the stock hose??? have you noticed a small or big difference???
__________________
<<<<<<<< LOOK AT MY NAME!!! lol COBB stg II |
#3 |
Install was easy,if you got small hands
It's a tight spot to get into,but no problems.The hoses are the same sizes,just very long.I'm going out right now to adjust it.Let you know.
__________________
Stg 2 06STI 02/04 WRX MSPT Tuned - 18g(DEAD) "Never go in against a Sicilian when death is on the line!"-Vizzini |
#4 |
make them as short as you can to lessen the time delay for the w/g to see the signal.
dR |
#5 | |
Just installed mine as well, and if you have bigger hands like I do, it's sorta a pain in the ass to get to a few spots, but nothing too much of a prob.
Going to go run it and see what it's like. I mounted my Joe P to the 2 metal bars in front of the IC, if that's a good/ok spot? Will be back in a bit
__________________
03 wrx - 300whp/270wtq Quote:
#6 |
I cut mine I would suggest it.
__________________
TJSUPE |
#7 |
so hows the performance??? what PSI are you guys setting them to???
is the boost higher in 5 gear than 1 gear??? should i set mine in 5 gear to max boost just to be careful??
__________________
#8 |
Just set my to @15.5.It took some time,but man
you can feel diff.I trim the hoses and used metal clamps instead of the ties for the hoses.In the booklet Joe P gives you they say"You want to set the MAX boost level with a load on the engine-third gear works well for this."
__________________
Stg 2 06STI 02/04 WRX MSPT Tuned - 18g(DEAD) "Never go in against a Sicilian when death is on the line!"-Vizzini Last edited by Needles; 04-29-2003 at 01:12 PM. |
#10 |
Heres another pic
__________________
#11 | |
MBC is on and working great.
I have mine set for 13.5psi in 3rd gear. A little low perhaps, but it is 75 degrees outside today and I don't have an up-pipe (up-pipe & down-pipe are my next mods) installed yet, so I wanted to keep the boost a little lower. 1st and 2nd gear are a world of a difference, which is what I was trying to get out of the MBC. Edit: Btw, I like the location you used Needles. Also, I saw a pic of someone mounting their MBC to the front metal bars on the IC, is this an ok place? - since it's where mine is.
__________________
#12 |
good to hear guys... im sure ill be happy with mine too... i was hopen for more power in 3 and 4 gear rather than in 1 and 2 gear....o well..... i think ill set mine to 15 max...
install pics look good and clean... think i might make my hoses alittle shorter though... but the shorter it is it doesnt look as nice
__________________
#13 |
Did you guys read any of the MBC sticky threads at the top of this forum? I dont mean to be an ass but please do, you will find a wealth of info! As for the hoses, cut one of the sections they send you in half, and use those two pieces only to keep the lines nice and short. Save the other piece in case you ever need a spare.
__________________
MY03 Sonic Yellow 5MT Sedan |
#14 | |
Quote:
__________________
have you ever been 4 bagged ??? |
#15 | |
Quote:
__________________
01 Black 325i |
| Thread Tools | |
| Display Modes | Rate This Thread |
