ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
Go Back   ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums > Tech & Modifying & General Repairs > Engine Modifications
Engine Modifications Flat-fours and turbochargers are what set the WRX apart from the rest. Talk about them and the latest aftermarket parts here. Sponsored by JSC Speed
Advertise On ClubWRX
Reply
LinkBack Thread Tools Rate Thread Display Modes
Old 03-28-2003, 06:38 AM   #1 (permalink)
Sunoco has race gas
Just walked past the Sunoco down the street from my house. They just started to sell 100 octane race gas from the pump!!
It's 4.39 a gallon, but they are the first I've seen selling it (other than the guy at the track). How would the WRX run if I were to splerge and get it one of these days?? Any negative aspects??
02WRX03060 is offline   Reply With Quote
Old 03-28-2003, 06:59 AM   #2 (permalink)
CustomS10's Avatar
Send a message via AIM to CustomS10
isn't 110 race gas?
__________________
-Ben-
Spark it or Park it!
CustomS10 is offline   Reply With Quote
Old 03-28-2003, 08:13 AM   #3 (permalink)
boostjunkie's Avatar
I think the sunoco around here advertises 104octane. It's still unleaded. 114octane gas is most likely the leaded kind.
__________________
1991 Turbo Legacy: 16.9psi of intercooled fun!!
boostjunkie is offline   Reply With Quote
Old 03-28-2003, 08:35 AM   #4 (permalink)
dark_rex's Avatar
Send a message via AIM to dark_rex Send a message via Yahoo to dark_rex
youre better off using toulene than the leaded stuff.
you can get it at your local paint store. instructions for mixing are listed here.
http://www.elektro.com/~audi/audi/toluene.html
dR
dark_rex is offline   Reply With Quote
Old 03-28-2003, 09:19 AM   #5 (permalink)
Send a message via AIM to Need4Boost
For the 100 octane in NJ, it costs me $3.99 a gallon which isn't too far off what you are paying.
I def. notice a difference between running 100 octane and 94 octane.
Need4Boost is offline   Reply With Quote
Old 03-28-2003, 09:24 AM   #6 (permalink)
dR
Have you tried this yourself? How much would be put in our WRX if I wanted to run a constant 100 octane. I know they said about 30% for a high 90's octane mixed with 92 octane. I usually run on 93/94 octane.
Old 03-28-2003, 09:25 AM   #7 (permalink)
thats the Sunoco CAM2 100 octane unleaded gas..it is awesome stuff. I used to be able to buy it at the pump where I live but the dealer went out of business
I would put in 3 or 4 gallons with every tank of 93 octane when I had my TTZ and it enabled me to up the boost 2psi ( from 460rwhp to 478rwhp ) without detonation even in the middle of S. Fl. summer heat.
__________________
IHI VF-34, ECUTEK Tuned
290whp@6300rpms@15.8psi
247tq@5200rpms@16.9psi
( Dynapack Hydraulic dyno )
twinz is offline   Reply With Quote
Old 03-28-2003, 10:23 AM   #8 (permalink)
aaronwillen's Avatar
on a wrx wouldnt you need to be running the 100+octane for several tanks before the ecu would recognize that it can advance timing?
aaronwillen is offline   Reply With Quote
Old 03-28-2003, 10:30 AM   #9 (permalink)
jedimaster's Avatar
Has anyone here actually used tolulene?
jedimaster is offline   Reply With Quote
Old 03-28-2003, 11:36 AM   #10 (permalink)
Quote:
Check out this link. The guy owns a turbo legacy but your results will be similar to his. Check out the links that he posts as well for a detailed description of how to use the stuff:
http://www.bbs.legacycentral.org/vie...hlight=toluene
__________________
Old 03-28-2003, 12:16 PM   #11 (permalink)
0db
Send a message via AIM to 0db
I used Xylene a couple of times on my turbo Integra (a lot like toluene, but 1 or 2 points higher octane, a little tougher to find but glass shops sometimes have it for use as a very serious glass cleaner... I think paint shops in california were phasing it out but it seems to show up every once in awhile still).
The difference was noticeable, and the Integra didn't even have a self-learning ECU. It did however have a J&S Safeguard that pulled timing in response to detonation. Running a gallon of Xylene in a tank (12g) of gas made the little red blinky detonation indicator go dark and made the car way more responsive without that timing pulled out.
0db is offline   Reply With Quote
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.1.0
Copyright 2001-2008 ClubWRX.net
