Po546 Egt High Input
Results 1 to 10 of 10
This is a discussion on Po546 Egt High Input within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; P0546 Exhaust gas temperature sensor circuit high input Okay dosent this mean the EGT sensor is reading too cold? I ...
    Registered User Biaxin's Avatar
    Detroit,MI
    I dont want to keep resetting my computer now that I have a UTEC...
    The only time I get this cell is when im crusing down the freeway at +50 mile drives. It seems it always kicks on when im driving between 70-75mph..
    Is the just quenidence? Or does it take a while for the EGT sensor to trigger a cell?
    My upipe is a godspeed. (I never got this cell in autum) it started as soon as it got in the below 30 degrees, I must of reset my ecu 10 times already!
    I Can turn off my check engine light with my UTEC now...But I wanna be able to see if I throw any other codes.
    Moderator aussieinstlouis's Avatar
    Jun 2002
    S34 47.322 E138 29.131 (WGS84)
    Essentially - yes. Or your EGT prode is trashed.
    I have TXS Stage 4 and have got it a few times, but not all the time. I checked the shop manuals on it and it calls a check of the sensor.
    I think that the Cat in the up-pipe is a bit of a furnance and keeps the EGTs relatively higher than without.
    I would get yourself an OBD-II scanner that lets you reset the codes without resetting the ecu. I hate driving around with the CEL on - you never know if there is another code 'lurking'
    Cheers,
    Andrew
    Detroit,MI
    Do you know where I can find a RS-232 To OBD-II cable? I already have a laptop.. and i have seen software for like 30 bucks..
    Hey it beats $150.00-$200.00 for a stand alone OBD-II scanner.
    Registered User is2scooby's Avatar
    Jun 2002
    Honolulu, HI
    Have you thought about performing the 2.2kohm resistor mod for the P0546? Worked for me!
    Aloha, Richard...
    Retired Moderator
    TXS Stage 4 UTEC + TMIC + JoeP
    12.75 @ 105.67mph - 1.74 60'
    Registered User tuca33's Avatar
    Aug 2002
    Brazil
    The resistor mod will be my solution if my EGT fails.
    is2scooby,,i have a scoobysport full exhaust and i have a black box they call the cell fix,,but they say its for the downpipe,,they say the uppipe will not throw a CEL.
    is that correct?
    thanks
    tuca
    2002 Black Wagon WRX
    315HP With the PM-ID
    Jun 2002
    Honolulu, HI
    Not sure. I have a PDE uppipe that didn't throw the p0546 for ~3 months. Then it showed up one day - I threw the 2.2k ohm resistor in there and haven't looked back since.
    Aloha, Richard...
    Retired Moderator
    Registered User PlatinumWRX's Avatar
    Jul 2001
    PA
    Just throw a bolt in sensor bung and a resistor in the sensor connector. The sensor is registering high EGTs, but it's nothing to worry about.
    -Jim
    Registered User pace's Avatar
    Sep 2001
    Brook Forest, Colorado
    Re: Po546 Egt High Input
    Indeed. A high input means low EGTs, and as Andrew said this is probably due to removal of the pre-turbo cat having reduced temps a little.
    I would try the resistor mod if I were you..
    -Pace
    May 2002
    ILP performance No weld EGT kit also solves this problem.
    thanks
    Jeff@ilp
    Moderating U! KurleeDaddeeWRX's Avatar
    Mar 2002
    San Jose, CA
    Here is a thread I wrote on the 2.2k ohm resistor mod. Hope this helps.
    2.2K Ohm Resistor Mod
