Re-Mapped ECU Learning Trick 10-20hp in 5 seconds :) - Page 3
Page 3 of 7 FirstFirst 1234567 LastLast
Results 31 to 45 of 102
This is a discussion on Re-Mapped ECU Learning Trick 10-20hp in 5 seconds :) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hey guys... my STOCK WRX only has around 1500 miles on it and I have been kind of sad because ...
  1. #31
    Registered User 2point0's Avatar
    Mar 2003
    Detroit, MI
    Hey guys... my STOCK WRX only has around 1500 miles on it and I have been kind of sad because after 1000 miles the car never got much faster... still kind of sluggish???
    Is this normal?
    So tomorrow I am going to try this trick and see if it works, could someone please tell me what 3-5PSI on the Subaru OEM turbo gauge would be??
    Thanks a crap load!
    Mike
  3. #32
    Registered User racerWRX's Avatar
    Jun 2002
    steeltown
    well.... .1 is about 14.5-7 psi soooo.... .02-.04 i think will be around that which you desire.....young jedi ?????
    have you ever been 4 bagged ???
  4. #33
    Jun 2002
    steeltown
    this link will help you out ....it will
    BOOST/VACUUM CONVERSIONS [Mpa, bar, atm, psi, inHg)
  6. #34
    Mar 2003
    Detroit, MI
    Thank You I Do
  7. #35
    Mar 2003
    Detroit, MI
    Okay yeah..... ITS HARD!!! About how fast should you be going in able to accomplish this???
  8. #36
    Registered User RLsChMiDt's Avatar
    Dec 2002
    Cleveland, Ohio
    It's not hard, you're making it hard. Read the directions again, and when you're ready to do it, maintain 2600RPM by BRAKING with your LEFT FOOT. I know it might seem awkward, but it's to maintain constant RPMs. Brake with your left, and gas with your right. Be in third gear cus it works best, like Shiv said.
    -Ryan |Dub-Yuh Our Ex Ess Tee Eye| My Car
  9. #37
    Mar 2003
    Detroit, MI
    Just tried again.... its hard to keep the RPMs at 2600 and the turbo at .02... its like trying to pat your head and rub your belly in a circle to me.
    I suck at driving I guess.
    Anymore pointers?
  10. #38
    Dec 2002
    Cleveland, Ohio
    Anymore pointers?
    No worries bra, you don't suck at driving cus you can't do this. Have you noticed that the harder you press the gas pedal, the harder the turbo works? It's controlled by the ECU. If you establish the .02MPa and 2600RPM, maintain that with the brake. Seriously, don't be afraid to use your brake. I guess just go out and practice before you go out and reset the ECU and mess up again. Remember, it only has to be maintained for about 5 seconds. THAT'S IT! Keep on trying, and if you're really having trouble still, PM me and we'll talk.
  11. #39
    Registered User PKer's Avatar
    at work
    Is this normal?
    This is for a Re-flashed ECU not stock.
  12. #40
    Mar 2003
    Detroit, MI
    Thanks RL.
    Damn PKer, Now I am really confused!
    Can this be done with a STOCK WRX with a STOCK ECU, STOCK EVERYTHING?
    Or are we talking about a re-flashed ECU?
  13. #41
    at work
    Thanks RL.
    We are talking about a re-flashed or re-programmed or re-mapped ECU, as the thread title says.
  14. #42
    Dec 2002
    Cleveland, Ohio
    It works with a stock car. Because the stock ECU is the same ECU as the reflashed one, right? And I'm assuming the stock ECU has the AIM. sooo....
  15. #43
    Registered User is2scooby's Avatar
    Jun 2002
    Honolulu, HI
    This works fine with a stock ECU. The stock ECU reverts to 0 knock correction when it gets "amnesia". This trick just ramps the number up at an artificial (increased) rate.
    Works the same on stock as well as re-flashed ECU's.
    Aloha, Richard...
    Retired Moderator
    TXS Stage 4 UTEC + TMIC + JoeP
    12.75 @ 105.67mph - 1.74 60'
  16. #44
    Registered User Kenshin's Avatar
    ok.. wheres teh ECU and how do i reset it?! i need to do this ASAP.. i hate getting crap mpg =) and want more speed..
    "All the auto WRXs I've driven (alot, I work at a dealership) give me enough time to make a peanut butter and jelly sammich before they hit boost." - Rancid
    SQC 120
  17. #45
    i didnt have my ECU reflashed/remapped or anything.. i have a dp, MBC, and a hks turboback.. if i do this learnin trick.. would it help me? or hurt me?
    SQC 120
