Uppipe Install??
Results 1 to 6 of 6
This is a discussion on Uppipe Install?? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; According to Perrin, you have to remove the downpipe to install the uppipe. Is this absolutely necessary? or is this ...
    Registered User Destros's Avatar
    Apr 2007
    Springfield, VA.
    Uppipe Install??
    According to Perrin, you have to remove the downpipe to install the uppipe. Is this absolutely necessary? or is this advised to make installation less difficult?
    Jan 2005
    Canada B.C.
    It's nessesery because there's one nut on the up-pipe/turbo you can't get at properly, so takeing off the down-pipe allows for the nessesary room...
    '02 WRX 4EAT, 311,000KMs/194,500Miles, Sold. Best car I ever had. '09 STi stage 1, hope this one will be good too...
    Registered User Business810's Avatar
    Aug 2006
    Pittsburgh, PA
    I didn't fully remove the downpipe, but I did have to unbolt it from the turbo to access 1 or 2 of the nuts on the uppipe studs. Theoretically, it might be possible to do it without unbolting the downpipe, but I think that would be way more trouble than it's worth.
    Even if you can find a way to do it without unbolting the DP, it will probably make your life about 27 times easier if you do unbolt it, IMO
    Registered User bcyb1029's Avatar
    Feb 2006
    Chicago
    You have to, but that is prob. on of the easier things to do, Have Fun.
    Tuned by Jorge at P&L, 240.83whp 239.60wtq at 14.8psi on 2.0L with stock td04 (But doesn't run)
    May 2005
    Phillytown, PA
    yes.
    Apr 2007
    Springfield, VA.
    well...looks like its coming off again...thanks for the input guys...
