Need help!!!! with a MIL Eliminator
Results 1 to 6 of 6
This is a discussion on Need help!!!! with a MIL Eliminator within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I have a catless exhaust and my sti ( 05 sti) has it's check engine light on, I read that ...
    Registered User Lord_Alucard's Avatar
    Mar 2007
    Unhappy Need help!!!! with a MIL Eliminator
    I have a catless exhaust and my sti ( 05 sti) has it's check engine light on, I read that if you bought a MIL Eliminator and hooked it up you can fix it and erase all the false codes the ECU is putting out. I did that and for yesterday it was ok, but today after driving it for 30 miles, my check engine light came back on, I checked the ECU and its putting a BANK ! LEAN code. how can I fix this problem?????
    Registered User Drifting02WRX's Avatar
    Jul 2006
    NE Ohio
    go to autozone, advance auto parts etc and pick up a sparkplug anti fouler. they come in packs of 2 located in the help section. i dont remember the exact part number but maybe someone can chime in on that one. drill one out to half inch and insert it into the other. then insert your
    o2 sensor into that, and problem fixed for under $3
    member of teh sex... i mean bugeye mafia (#92)
    Moderator
    Jul 2003
    Maryland
    Or you can do the right thing and get some sort of EM on the car to control Boost, Fuel, Timing, and delete the CELs.
    Registered User project_skyline's Avatar
    Mar 2006
    Silt, Colorado
    Your probably getting boost creep with your catless exhaust....
    Oct 2005
    California
    Quote Originally Posted by 302@12psi View Post
    +1
    I might be back in the market for the new STI sedan!
    Registered User AwdTurboWrx's Avatar
    Mar 2004
    Sun Valley,CA
    Quote Originally Posted by project_skyline View Post
    this is probably true, did your CEL come on when you were on it? It kinda felt like you hit a wall? Or were you just driving normal?
    also forget mil eliminator, listen to the guy who said go to autozone. My brother did that to his catless wrx and no CEL ever.
    The Ghosts of Zooph and Sarcasmo Will haunt CLUBWRX forever!!!
