vf39 restrictor pill
Results 1 to 8 of 8
This is a discussion on vf39 restrictor pill within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; ok, the turbo just came in today, doesn't come with any hoses at all. just the turbo.. thats it. where ...
    Mar 2007
    ok, the turbo just came in today, doesn't come with any hoses at all. just the turbo.. thats it. where can i find the pill? is it on the turbo? I know I am a noob.
    Registered User Damien02WRX's Avatar
    Dec 2005
    California City, CA
    The restrictor pill would be in one of the vacuum lines connected to the turbo. If you say it did not come with hoses then you are going to have to find one. Here is a pic I found a long time ago that helped me in my quest to put my wasregate solenoid vacuum path back to stock:
    Mar 2007
    yeah, i have the pill, i found it. so what do i need to drill it too. where can i buy this bit at?
    Dec 2005
    California City, CA
    I assume you are going to use a COBB map correct? If so then there is a tutorial somewhere on their website that describes the whole process of drilling out your restrictor pill diameter. I am looking at a tutorial for a 2006 WRX MT with a VF39 and COBB says .043" +/- .001" (a #57 drill bit).
    Moderator
    Jul 2003
    Maryland
    I dont think you have to drill the pill on pre 06 setups...should just use the one from the vf-39 if I recall.
    Mar 2007
    i have a 03. I thought i needed to drill the pill
    Mar 2007
    I looked at cobbs note on the vf39 swap into the MY03, and it says nothing about drilling the pill?
    Moderator
    Jul 2003
    Maryland
    Quote Originally Posted by gasstationboi View Post
    Why dont you actually have the mechanic who is working on the car read up on the install.
    On pre 06's you dont drill anything. You need to figure out if you keep your stock TD04 pill or the vf39 pill.
    I THINK you keep the 39 pill from memory but I am not 100% sure.
