This is a discussion on SR*S Catback Exhaust from EBAY PICS and VIDS within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; hows the clearance with the ground? Does it fall low like some of the ebay catbacks or are they good? ...
hows the clearance with the ground? Does it fall low like some of the ebay catbacks or are they good? thanx
i'll be doing thet when i run out of warranty...
yup
I've read this whole thread but i don't know if i missed it but, with the stock downpipe do you use a donut gasket and the spring bolts or remove the donut gasket and just bolt it together with a flat gasket?
good question... i didn't even think of that... i used the stock donut gasket and used the spring bolts (stock DP) i had to use a crescent wrench to compress the springs enough to start the nut... casue the flange is thicker...
yup
well I just purchased the S*RS Up pipe, Down pipe and Catback from nissangtr guy on ebay last night..I'll post up results of my own.
04 Wrx Wagon Cobb Stage 2Just remember, capitalization and punctuation marks the difference between, "I just helped my uncle, Jack, off a horse." and, "i just helped my uncle jack off a horse"
Blobeye Syndicate #026
the stock donut gasket doesn't fit right with the catback. so i had to remove it and just use the flat flange gasket that the seller provided. it's a thin gasket and now i'm having leak / fitment issues there. should be an easy fix though. i'm just going to sandwich some gaskets in there and give it a good seal. i'm using the stock springs bolts.
Thanks, i ordered mine monday and was wondering if i should use the donut gasket or not. Hope it's an easy install.
Looks like I'm one of the only people getting the srs downpipe and up pipe as well as the catback, I hope all the gaskets are good enough quality.
Did you guys all buy it from the same guy? I paid for mine on Thursday, he said it would be shipped out Friday, I had to email him again on Sunday to get a tracking number, and now fed ex is saying its invalid...I hope everything is still being shipped...
