SR*S Catback Exhaust from EBAY PICS and VIDS - Page 22
Page 22 of 35 FirstFirst ... 121314151617181920212223242526272829303132 ... LastLast
Results 316 to 330 of 521
This is a discussion on SR*S Catback Exhaust from EBAY PICS and VIDS within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Well I emailed Nissangtr asking about the combo of all 3 and he sent me these links Up Pipe: http://cgi.ebay.com/ebaymotors/Flex-...7567QQtcZphoto ...
  1. #316
    Registered User rotorocker's Avatar
    Mar 2008
    Manalapan NJ
    Up Pipe:
    Downpipe
    http://cgi.ebay.com/ebaymotors/SR-S-...1354QQtcZphoto
    The down pipe is listed as ETS and not S*RS? and the Up Pipe isn't listed as any brand?
    Just remember, capitalization and punctuation marks the difference between, "I just helped my uncle, Jack, off a horse." and, "i just helped my uncle jack off a horse"
    04 Wrx Wagon Cobb Stage 2
    Blobeye Syndicate #026
  3. #317
    Mar 2008
    Manalapan NJ
    Anyone know any more about whether those are all the correct parts? When I google the ets downpipe I am getting Tseudo as the brand...
  4. #318
    Oct 2007
    yea those are correct ,the seller might have used a different picture ,but those are the SR*S brand
  6. #319
    Mar 2008
    Manalapan NJ
    great, thanks for the response. I just wanted to make sure it was all cool. I couldnt find any reviews of the srs up pipe but I'll assume its the same as most and hopefully fits good. I just ordered the AP which will be here tomorrow, so this is my next step soon.
  7. #320
    Registered User efaroh's Avatar
    Jan 2008
    OC
    leakage confirmed
    okay so its been about 3 months and 7,000 miles since I installed the SR*S cbe on my sedan. I always suspected theres a leak between the rear cat and the resonator pipe, but could never confirm it until recently.
    the leak noise is clearly audible now. i had a friend check the connection while i gave it a lil gas. he saw some dust shoot out of the seam.
    has anyone else suspected leakage?
  8. #321
    Mar 2008
    Manalapan NJ
    Did you reuse an old gasket or a new one?
  9. #322
    Jan 2008
    OC
    Quote Originally Posted by rotorocker View Post
    the stock donut gasket does not fit with the SR*S resonator pipe. I replaced it with the gasket that the seller supplied, which i always thought was kinda thin
  10. #323
    Apr 2008
    Big Favor Wanted
    Hi,
    Next time someone install this exhaust, can you do me a huge favor and see if the factory muffler will bolt up to the new 3 inch intermediate pipe?
    Or, if you can just post a picture of the factory intermediate pipe side by side with the new one that would be great.
    I'd like to get this exhaust but kind of worried about it being too loud and/or attracting un-wanted attention from the police so I want to know if it would be possible to use the factory muffler with the intermediate pipe.
    If someone could do that for me that would be awesome.
    Thanks
  11. #324
    Registered User wrxwalsh's Avatar
    Sep 2007
    Spring/ Arlington
    Quote Originally Posted by pwu_1 View Post
    Hi,
    Thanks
    the easy answer is no this wouldnt work... simply because your stock exahust is 2.5in and the SR*s is a 3in as you stated... also most manufacters build all of the pipes to only fit thier exhaust dont really know why but they do... however find a reputable muffler shop modify either the SR*S Exhaust midpipe or make you a new one... but it you want to do that then why dont you just have a muffler shop make you a new mid pipe and if its too quiet then go with the SR*s.. the midpipe is pretty easy so it shouldnt be much more than 50-100 bucks
    Matt
    UTA FSAE FTW!!!!
    Cars
    1993 MR2 Turbo- SOLD
    2004 WRX - SOLD
    2008 Civic Si
  12. #325
    Apr 2008
    I realize that its a 3 inch flange vs a 2.5 inch flange. There is a vendor on nasioc.com that sells an adapter plate to make this work. I have the plate already so as long as the length is correct it should work(in fact some of you folks with the stock downpipe might want to look into this adapter plate if you have leak issues).
    I guess I can take my car to a muffler shop but seems like muffler shops will just weld everything together...I want flanges so I can take it apart if I want to.
    Besides, for 250, I get full stainless steel tubing and mandrel bends and have the option of running the loud muffler if/when I want...
    Quote Originally Posted by wrxwalsh View Post
    Matt
  13. #326
    Sep 2007
    Spring/ Arlington
    the muffler shop by my house told me theyd be building a 3in mandrel bent with flanges exhaust for 200 for me i guess it depends on the muffler shop.. i would imagine the lengths are close but there might be a little you have to add on either the stock muffler pipe or you could take the stock midpipe, lop of the flange that bolts onto the muffler and have the muffler shop weld that flange, a small pipe, and that adaptor flange together so that you could have a simple adaptor system
    Matt
    UTA FSAE FTW!!!!
    Cars
    2004 WRX - SOLD
    2008 Civic Si
  14. #327
    Apr 2008
    Matt
    Yeah I guess that might be a good idea. I might just take it to the muffler shop and have them hack up my intermediate pipe and replace it with a 3 inch flange on the side that connects to the cat(I have a 3 inch downpipe) and use a 3 inch pipe to the back and then taper down to the factory 2.5 inch flange...seems like a lot of work though, haha
    Maybe I should just get this exhaust and be done with it.
    If someone can compare the length of the factory intermediate pipe vs the sr*s intermediate pipe that would be awesome.
    Thanks
  15. #328
    Jan 2008
    OC
    whats the name of that vendor. i can't sleep at night knowing theres a leak. wouldnt hurt to just check it out.
  16. #329
    Registered User natedawg9640's Avatar
    Apr 2006
    Fox cities, WI
    I'll be ordering the CBE early next week... anybody have any last minute input or relaibility, audibility... or any other -ility?
    yup
  17. #330
    Registered User Findus11's Avatar
    Nov 2007
    Ketchum, Idaho
    Quote Originally Posted by natedawg9640 View Post
    Me too
    Hawk Eye #1991
    Dirty Crew #11
    Military Militia #1991
    I still don't know how I got this car...
