SR*S Catback Exhaust from EBAY PICS and VIDS - Page 12
Page 12 of 35 FirstFirst ... 2345678910111213141516171819202122 ... LastLast
Results 166 to 180 of 521
This is a discussion on SR*S Catback Exhaust from EBAY PICS and VIDS within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; it will sounds nice on the wagon ,i have friends brought it and installed it , sounds just the same ...
  1. #166
    Oct 2007
    it will sounds nice on the wagon ,i have friends brought it and installed it , sounds just the same on the sedan smooth and deep rumple sound
  3. #167
    Registered User Ditch64's Avatar
    Apr 2007
    Detroit
    Quote Originally Posted by Oldfart Racer View Post
    I am more worried about the sound in car. The wagon will drone more than a sadan.
    u sound exactly like i did before i bought it. get it i promise you will like it.
  4. #168
    Jul 2007
    I hate the South, GA
    anyone have pics of how this exhaust stands the test of time?
  6. #169
    Registered User ryan2.5's Avatar
    Apr 2007
    South Bech, OR
    well, I live RIGHT on the ocean and it still looks great with no rust at all. Have had it for like 6 mo. Still looks as good as when I bought it. Just keep it clean.
    358 awhp/430 tq.Tuned by PRE
    stock turbo
    DIFFERENT STROKES.
    Blobeye syndicate #101
  7. #170
    Oct 2007
    yep just buy it ,you won't be regret
  8. #171
    Oct 2007
    Silencer
    Well. I got my ERZ cat-back in the mail today. Looks good. Even came with a flex piece in the mid-pipe that I was unaware of. It's installed and ready to go. But, my worst nightmare has come true... I cant get my silencer out . What do I do? I went to my local body shop and tried to get it out with a slide hammer, and that didn't work (this was pre-installation). I also tried a bit of WD-40 but that didnt seem to do much, although that combined with the slide hammer it might. What do I do guys. Will driving it a bit expand my muffler and make it a bit easier to take out? Get it real hot after driving it for a while then try? I really want to take this thing out. It looks so much better without it IMO. Any suggestions would be appreciated. Other than that, the exhaust is fine. I just want that deeper rumble (and to take that stupid thing out of my exhaust tip).
  9. #172
    Registered User Black Pearl's Avatar
    Jul 2007
    Eugene/Roseburg, Oregon
    Quote Originally Posted by SSSWRX04 View Post
    try and vice grip and the rim of the silencer and pull
    Quote Originally Posted by BigB007 View Post
    For the first time this week the crappy neon thats been stalking me didn't find me and rev at me.
  10. #173
    Oct 2007
    By 'rim' do you mean the inner circle where the exhaust comes out? Take a vice grip to the opening and pull hard?
    I just don't know if that would work if a slide hammer didn't. Also, if it doesn't work I don't want to drive around with a dented silencer. I don't care if it gets ****ed up but comes out though, I just want it out in any condition.
    EDIT: The guy I bought it off ebay from (nissangtrpower) said to try using 91 octane around the tip as lubricant, and then try. Will this work? I already tried WD-40, is there any difference?
  11. #174
    Jul 2007
    well I took mine out right away, it didnt want to come out at first but if you just wiggle it back and forth for a while it will eventually come out, and yes but rim I mean the circle where the exhaust come out. Or try something with a hook at the end and stick it down the exhaust, it will catch the end of the silencer, and keep on hitting towards you, hope that helps.
  12. #175
    Oct 2007
    Tried
    Yeah I tried that with a slide hammer. And if anything is going to get it out from the back with a hook its a slide hammer. I also tried pulling a bit around the rim with a vice grip and it doesn't even budge 1 bit. I don't wanna bend my silencer too much if I'm going to be driving around with it for a while.
  13. #176
    Registered User jfolland's Avatar
    May 2007
    Sykesville/Westminster MD
    i did the vise grip and wiggle method...took a while but got it out eventually
  14. #177
    Apr 2007
    Detroit
    drive around for like 15 minutes or so, go run some aarons and then go and grab a bag of ice, put it ONLY on the silencer that worked for me, its shrank it enough to get it outta there with a little help from my best friend, channel lock. :-P
  15. #178
    Oct 2007
    I think my friend Mr. Vice Grip can compete with the channel lock, but I guess I can try that ice thing. But will it really cool the silencer that much and the outside of the muffler still be hot?
  16. #179
    Apr 2007
    Detroit
    idk i may have gotten lucky. im sure dryice would do the trick.get the inside cold so then it starts to shrink but then as its happening ur yankin on it and pop! thats how i did it
    also once u get it out, try sanding down the parts that contact the muffler tip so that way its a little smaller nexttime and u can get it out easily but not to a point where its letting air through the sidewalls.
  17. #180
    Oct 2007
    Question
    This is for anyone who has the ERZ cat-back and has successfully removed the silencer.
    How many plates are there on the silencer tube? Is it just one outer plate and then the tube? Or is there an inner plate also, that is hidden by the outer plate.
    Reason I ask is because I am thinking of cutting a circle on the outer plate AROUND the tube, so that I can just pull it out. And then somehow just wedge that plate thing out from there, which should be VERY easy with that middle tube and part of the plate out of the way. But if there are 2 plates, that would be very difficult to get access to cut the inner plate.
    Anyway, please let me know what your ERZ silencer looked like.
