"The BIG BOV thread" (Where all bov question threads get merged) - Page 98
Page 98 of 798 FirstFirst ... 48888990919293949596979899100101102103104105106107108148198598 ... LastLast
Results 1,456 to 1,470 of 11961
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I would keep the stock BOV unless you swap for a bigger turbo. The OE one vents back to the ...
  1. #1456
    Registered User spacemanspiff's Avatar
    Apr 2003
    Austin it is
    I would keep the stock BOV unless you swap for a bigger turbo. The OE one vents back to the turbo and actually helps keep it spooled when you get off the gas.
  3. #1457
    Registered User RLsChMiDt's Avatar
    Dec 2002
    Cleveland, Ohio
    I've put at least 75 miles on it, and I'm still having the same problems. It seems like I'm losing power because of it. It seems as if it's bleeding while in boost....if I got the red spring, do you think it'll still vent!? I'm running stock turbo with 15.5 psi from a JoeP.
    -Ryan |Dub-Yuh Our Ex Ess Tee Eye| My Car
  4. #1458
    Registered User WRC_Obsessed's Avatar
    Jan 2002
    Boston/NNJ
    i was running into the same problem...give it 25 more miles...if you are still running into problems give forge usa a call and explain the problem and they will send you the correct spring...i have not heard of anyone having so many problems that they have had to take the forge off....
    i think the red spring may work...
    -Brian
    Twisty Monster - 335 ft/lb of torque @ 3600 rpm on a stock turbo. Is that possible? Yes it is.
  6. #1459
    Registered User 03REX's Avatar
    Feb 2003
    Overland Park, KS
    01 Black 325i
  7. #1460
    Jan 2002
    Boston/NNJ
    again...i would suggest that you give forge usa a call...they are a great help and will send you exactly what you need to fix the problem...
    great customer service
    -Brian
  8. #1461
    Registered User stilesg57's Avatar
    Oct 2002
    Denver, CO, & Walla Walla, WA
    Hey cohlineman -
    Where did you get the blue Forge? I've heard of these a little bit but haven't been able to find any. Did you buy it that way or do it yourself? If you did it, how?
    Thanks
    <----- Finally found an avatar I like!
  9. #1462
    Mar 2003
    tennessee
    installing my HKS bov???????
    should i grease the seals or anything extra while installing my HKS bov??? and is there any catches to doin it easyier???
    2003 Aspen White WRX
    Mods: HKS turbo timer, HKS SS BOV, Progress springs, gauge pod & gauges, 17" Konig Holes "graphite"
  10. #1463
    Registered User Hybrid-X's Avatar
    Feb 2002
    WA for now, but CA will always be home
    Nope. It's pretty straight forward. Some people took off the intercooler for the intake return plug, but I didn't. Good luck.
  11. #1464
    Registered User WRXin''s Avatar
    Jun 2002
    Houston, TX
    Originally posted by stilesg57
    Hey cohlineman -
    Thanks
    Read his post again buddy: www.stratmosphere.com
    Fahd
    Floats like a butterfly and stings like when I pee!
  12. #1465
    Mar 2003
    santa rosa , ca
    That's it.
    WRXin' said it all, go to their link and you can even listen to a clip.
    Forge is a UK company specializing in billet products.This BOV was anodized at the factory.It is 100% VTA and is mysteriously one of those 100% BOVs that do not seem give any of their owners grief other than changing the springs to accomodate non stock boost applications.Forge Motorsports will answer all your questions and supply replacement springs.
    I do not know if anything has changed , but when I purchased mine , Stratmosphere said they were no longer stocking parts for Subarus , only Audis. Call them up.
  13. #1466
    Jan 2003
    South Florida
    Just got BOV!!!
    I just got my Forge BOV and I installed it and it is cool, but it is pretty quiet inside the car..outside the car it is loud and sounds great...it might just be me...it is nice and it looks great...I am happy
  14. #1467
    Registered User scrapy2's Avatar
    Mar 2003
    belleville,ill
    dose it come with evey thing to bolt it on or do you have to buy an adapter.
  15. #1468
    Jan 2003
    South Florida
    It came with everything that is needed...bolted right on..even came with a plug for the return line form the factory bov
  16. #1469
    May 2002
    so cali
    definitely do that. they are great guys to ask, especially about their own product. oh yeah, and my forge keychain looks killer i sold the bov in favor of an hks unit, but not for any mechanical reason. it simply wasn't the sound i wanted.
    if you don't call them, at least send them an email. now where's that keychain... *scrounging through desk*
    05 STi...not stock
  17. #1470
    Oct 2002
    I read the post, I was just hoping that he gave stratmosphere as a recomendation and got it somewhere else - stratmosphere doesn't carry WRX BOV's any more since like 6 weeks. Just really wanted a blue one but Forge doesn't list one and Stratmosphere ain't sellin' 'em. oh well, thanks for the replies.
    As for the description, thanks but I've heard plenty about this valve - I've been browsing these boards for over a year and have yet to come across a negative post about Forge's valve or their customer service. The same can't be said of the others...
