"The BIG BOV thread" (Where all bov question threads get merged) - Page 93
Page 93 of 798 FirstFirst ... 438384858687888990919293949596979899100101102103143193593 ... LastLast
Results 1,381 to 1,395 of 11961
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; www.turboxs.com And it only makes the sound when there is a sudden release of the throttle after being in boost, ...
  1. #1381
    Registered User Shard's Avatar
    Jan 2003
    Houston TX
    www.turboxs.com
    And it only makes the sound when there is a sudden release of the throttle after being in boost, such as shifting.
  3. #1382
    Registered User WtuRboX's Avatar
    Mar 2003
    Allentown, PA
    A friend of mine said he knows this kid with the TXS H-RFL... I haven't heard it, but he said it's super loud... he told me I should definately get it. The only thing stopping me is the HKS SSQV since I heard that one can't leak boost
  4. #1383
    Registered User Oo DaRk StAr oO's Avatar
    Apr 2002
    Long Beach, CA
    on www.nasioc.com
    contact richard
    modified toys is screen name...
    tell him Matt Lee sent you and he will guarentee you the best price.
    BRS Autodesign | Sportmax Racing | Falken Tyres | Seibon | C2 Power
    http://www.socalspyders.com/gallery/files/1/sig.jpg
    2001 Toyota MR2-S | So Cal Spyders | Car Domain Site
  6. #1384
    Mar 2003
    tennessee
    does the TXS RFL bov leak boost?
    i just ordered it caouse i like the sound better than the hks, but some people say that the RFL leaks boost, is that true? or is it very relaiable? thanks
    2003 Aspen White WRX
    Mods: HKS turbo timer, HKS SS BOV, Progress springs, gauge pod & gauges, 17" Konig Holes "graphite"
  7. #1385
    Registered User SpideyWRX's Avatar
    Mar 2003
    Canada
    I have the turbo XS type H BOV, and it doesn't leak.
    It says in the manual that it might leak at idle, and they supply you with some pack washers to put inside the BOV to prevent it from leaking at idle. (if this is what you meant by leaking)
    Mine was fine when I got it, didn't need to do anything to it,
    SPIDEYWrX
  8. #1386
    Mar 2003
    Dallas, TX
    uhoh.. cut BOV hose - help please!
    Alright, so I screwed up last night. I installed a Blitz DTT and everything went smoothly until I got to the boost gauge piece. I mounted it behind the glove box and ran the vacuum tube through the same grommet as the AC drain hose on the passenger size, and the install looks very clean ...
    Unfortunately, I didn't read here on the problems with the T connector that came with the DTT. I cut the hose coming out of the BOV, and when I realized my error, tried to jury rig it by wrapping the connector with electrical tape and attaching the hose with zip ties - which worked for about half of the commute to work this morning.
    I popped the hood when I got to the office and the tubes had come apart.
    I have about 50 miles to drive this afternoon before I'm near a pepboys (where I can buy the CORRECT T-connector), and my question is this : What kind of risks am I running with a possibly cut BOV hose? If I stay off boost, am I in danger of breaking my car?
    That'll teach me to install something without reading ALL the posts ...
    Thanks
    03 silver sedan...stock
  9. #1387
    0db
    0db is offline
    Mar 2003
    Ventura, CA
    Damn, boy, don't you know to keep a roll of duct tape in your car? You could do a quick splice of the original line back together and it would actually hold for awhile if you had some.
    But if you can keep out of boost you should be fine, it's just very hard to keep completely out of boost on this engine. It would help to avoid suddenly taking your foot off the gas - rapid throttle closing is the worst for compressor surge. Slow, gradual throttle reductions are easier on the turbo.
    Remember, there are cars out there that don't run BOVs at all. You're not going to KILL your turbo, but it won't be GOOD for it either.
  10. #1388
    cnk
    cnk is offline
    NJ
    You can use telfon tape and wrap it around the t-connector. I did this on my Blitz SBC-ID as well as for my Greddy boost gauge and have never had a problem. Just use some zip ties to hold everything down tight.
    Calvin
  11. #1389
    Mar 2003
    Dallas, TX
    I know, I should have duct tape. I really thought it was going to be fine - I built the connector up pretty well, but it just didn't hold. My biggest fear was having to drive 50 miles before I can fix it for real - I plan on buying replacement hosing and a PROPERLY SIZED T tonight.
    What kind of teflon tape are you using? I have standard vinyl electrical tape that is almost as good as useless...
  12. #1390
    0db
    0db is offline
    Mar 2003
    Ventura, CA
    I dunno, I can't imagine any way to make an undersized tee work with teflon tape. Electrical tape should be better, but still that stuff gets slippery when it's pulled in shear. Only way I've ever managed to get undersized fittings to work in a pinch is to use a hot glue gun to build up some extra material on the fitting and then slip it in when it's nearly set.
  13. #1391
    cnk
    cnk is offline
    NJ
    The teflon tape that you use is the same that you would use on pipe threads. It conforms to the T-fitting. I just wrapped it around the T until it was a little larger than the opening in the hose. Then just squeeze it on and zip tie it. The teflon tape will seal the T to the hose as that's what it's meant to do. I've never had a boost leak and never had any leaking hoses. I've got over 20k miles on the car and run a Vishnu Stage 1 with Ecutek that routinely boosts up to 17psi.
    Calvin
  14. #1392
    Oct 2002
    Hks Bov.
    I got one. It doens't come with the adaptor.
    Am I supposed to use the stock adaptor? grrr...
    If not, where can I get the necessary parts?
  15. #1393
    Registered User WRXin''s Avatar
    Jun 2002
    Houston, TX
    Where did you order it from and how much?
    When you got it, you should have gotten the one with the WRX kit, and you should've paid around $225. If these things don't add up to what you got, then you probably got it as a universal BOV. If that's the case, then all you have to do is buy the WRX kit for this BOV. Let me know what happens
    Fahd
    Floats like a butterfly and stings like when I pee!
  16. #1394
    Registered User chobits's Avatar
    Oct 2002
    you need flange <- i might be wrong
  17. #1395
    Jun 2002
    Houston, TX
    No you're absolutely right. That's what I meant by the WRX kit. It's the flange that allows the BOV to fit in our cars.
    Fahd
