"The BIG BOV thread" (Where all bov question threads get merged) - Page 91
Page 91 of 798 FirstFirst ... 4181828384858687888990919293949596979899100101141191591 ... LastLast
Results 1,351 to 1,365 of 11961
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally posted by ravenwrx the Greddy blow off valve is not suppose to be loud. Look at the design. You ...
  1. #1351
    Registered User Hybrid-X's Avatar
    Feb 2002
    WA for now, but CA will always be home
    Re: here is your answer
    the Greddy blow off valve is not suppose to be loud. Look at the design. You should be using the top nipple only, the bottom one is for dual B.O.V. install.
    HTH
    Well, not like super loud, but it should be a little audible. I hear next to nothing. Anyways, I'm gonna put it on another WRX to see if it's the same.
  3. #1352
    Registered User ryland's Avatar
    Apr 2002
    NY
    Re: Re: Re: Which BOV is "better"?
    Originally posted by driverj
    Told you so....
    2004 Black WRX Sedan
    Mods = yes
  4. #1353
    Registered User spool_up's Avatar
    Mar 2003
    Chicago, IL
    Re: Gfb Bov
    Originally posted by BoostedBoxer
    Anyone got the gfb BOV? what do you think--------- pros, con's? Hows it sound?
    I have not run any other BOV's, but I notice a definate difference in the reduction in lag between shifts. It is also controllable, in that you can drive it normally without the BOV letting out air. Only during WOT at 4-7K RPM's does it vent, and it is just loud enough to hear, but not caouse problems. IMHO, this is an excellent compromise for someone wanting the "sound" of a turbo (which I did) but did not want the bad effects of a too-rich situation.
  6. #1354
    Official ClubWRX arms dealer SOUTHPAW's Avatar
    Feb 2003
    CT
    Thumbs up
    Got it
    *1969 Camaro - Kickin' It Old School
    PICS & MODS
    *2005 Corvette C6 - A few APS bolt-ons
    PICS & MODS <- Built by XX Tuning
    *2003 Subaru WRX - 332 AWHP - SOLD
  7. #1355
    Registered User BamBooI's Avatar
    Oct 2001
    Milky Way Galaxy
    I have the turboxs rfl and I have 0 problems. I like it. I know a dealer that sells txs rfl bov bolt on KITS for wrx for 169....
  8. #1356
    Registered User Flat_four's Avatar
    Feb 2003
    Norfolk, VA
    I love my blitz DD Something about that low rpm studder that gives me the chills...
    FF
    04 WRB/GOLD WRX STI
    Blitz SUS intake
    Blitz DD BOV
    Blitz NUR Spec R Cat-back
    Blitz SBC ID @ 17.0 PSI
    Buschur Racing Down pipe
    Exedy Clutch
  9. #1357
    Registered User is2scooby's Avatar
    Jun 2002
    Honolulu, HI
    just got a forge two days ago and it sounds amazing, if you have ever watched wrc or even are remotley interested in rally then go with the forge.
    Just FYI - if you are hearing that "chirping" noise most recognizable from WRC that is compressor surge and that is *not good*.
    Just installed a Forge BOV on my car - and I'm getting TONS of compressor stall. I think I need a lighter spring.
    Aloha, Richard...
    Retired Moderator
    TXS Stage 4 UTEC + TMIC + JoeP
    12.75 @ 105.67mph - 1.74 60'
  10. #1358
    Registered User WRC_Obsessed's Avatar
    Jan 2002
    Boston/NNJ
    i was also in the beginning when i just put it in...after the spring got broken in the sound went away...give it a week...
    -Brian
    Twisty Monster - 335 ft/lb of torque @ 3600 rpm on a stock turbo. Is that possible? Yes it is.
  11. #1359
    Registered User 0260B4U's Avatar
    Feb 2003
    I rule
    That's why I got the StealthFX, might not be the best sound, but with total adjustment between 100% atmosphere. And the spring load can be adjusted and there are 12 full turn in between, so you put it right where you want it, so you wont have stumble and compressor surge. IMO sound is not gonna be a deciding factor. But I am ordering that experimental trumpet and will record a movie clip when I get it.
    --Little John--
    Straights are for fast cars...
    Turns are for fast drivers...
    --Colin McRae
    "Power is nothing without control"
    http://static.howstuffworks.com/gif/engine-flat-4.gif
    "Are you OK to drink?"
  12. #1360
    Jun 2002
    Honolulu, HI
    Thanks... I did take the valve off and lube the piston and depress it 100's of times (brass punch and lintless rag) and the valve seems to blow off a little sooner - but I'm still getting some pretty bad surging.
    Aloha, Richard...
    Retired Moderator
  13. #1361
    Registered User FASICZKA's Avatar
    Mar 2003
    Orland Park, Illinois
    bov flange?
    does any1 know if the flange adaptor for the turbo xs bov type h also fits the hks bov?
  14. #1362
    Oct 2002
    St. Paul, MN
    hks bov help
    how the hell do you get the ring or clip to go inside of the adapter with the bov. the pos wont go in.
  15. #1363
    Mar 2003
    tennessee
    What BOV to get ????
    i want a BOV that is loud, but yet is very reliable and has no problems, i've heard that the GFB is good, but is it loud???? what do u think would be best for me?
    2003 Aspen White WRX
    Mods: HKS turbo timer, HKS SS BOV, Progress springs, gauge pod & gauges, 17" Konig Holes "graphite"
  16. #1364
    afpdl's Avatar
    Sugar Land(houston), TX
    Just get a bull horn and blow it out the window whenever you want some noise
    Alex
  17. #1365
    Registered User Shard's Avatar
    Jan 2003
    Houston TX
    I think the stock one is really reliable and has no problems and works better than some aftermarket ones. Granted it's not loud but so what, and also, search!
    There is even a sticky at the top of this forum with information you need. Look around please.
