"The BIG BOV thread" (Where all bov question threads get merged) - Page 87
Page 87 of 798 FirstFirst ... 37777879808182838485868788899091929394959697137187587 ... LastLast
Results 1,291 to 1,305 of 11961
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; if it is the lube from the BOV it is normal. My forge 100% was well lubed and it 'spat' ...
  1. #1291
    Moderator aussieinstlouis's Avatar
    Jun 2002
    S34 47.322 E138 29.131 (WGS84)
    if it is the lube from the BOV it is normal. My forge 100% was well lubed and it 'spat' a little grease out for awhile.
  3. #1292
    Registered User LukeWRX's Avatar
    Jan 2003
    Stafford, VA
    ahh ok. That is what this looks like. I am gonna clean it up today and see if it is getting better.
    thanks for your help
    2004 STi
    Blitz DTT-DCII
    COBB Stage 2
    Invidia Catless DP
    HKS Hiper Cat-back
    Greddy: EGT, Boost, Oil Press Gauges
    Perrin Oil Catch Can
  4. #1293
    Registered User 0260B4U's Avatar
    Feb 2003
    I rule
    BOV install
    I saw a nice picture intensive one on one of these sight but now I can't find it. Can somone help?
  6. #1294
    Moderating U! KurleeDaddeeWRX's Avatar
    Mar 2002
    San Jose, CA
    Here's a link that also shows how to install Samco Intercooler hoses, as well as a GFB BOV.
    http://www.scoobymods.com/forums/sho...&highlight=BOV
  7. #1295
    Feb 2003
    I rule
    sweet you da man, now what is the advantage of installing the hoses? i just spent the last hour looking for that thread again
  8. #1296
    Mar 2002
    San Jose, CA
    For one thing, the stock hoses, over time, will crack because of the high heat in the engine compartment. The Samco's won't crack. The Samco's also have a larger inner diameter, to flow more air. They are also made out of silicone, which is very smooth, and allows the air to glide through easier. And they also look good.
    If you follow that thread above, you will see the stock black Y shaped hose that connects on the back of the intercooler. It is has a super small inner diameter. Now check out the blue Samco hose. See how much larger it looks. If you did a comparison and held each one up, you would really see the difference.
    And the Samco's are supposedly good for a 8hp increase.
  9. #1297
    Feb 2003
    I rule
    whp?
    wish i had ordered them to go with it.
    Any site come to mind? Once you take it of once the 2nd time should be even easier.
    i heard that one hose is a ***** to get back on. Wonder if the silicons would make it easier
    Edit:never mind found a thread
    but is that WHP or crank
  10. #1298
    Registered User newbie967's Avatar
    May 2002
    westchester new york
    what kinda turbo do you have, cuz i've got the same bov, when the engines still a little cold, the thing is even louder, i made this woman jump i felt kinda bad cuz she grilled me hardcore afterwards lol oh well
  11. #1299
    : : J-Lovin Moderator: : PhreeZe's Avatar
    Mar 2002
    Gig Harbor, WA
    Originally posted by pondo
    how many washers did you put ontop of the spring?
    cheers!
    I am using the same amount of washers as it came from the factory of TurboXS. Also, I am running the stock turbo at 15.5PSI.
    Jason
    "It's not how you stand by your car, it's how you race your car. You better learn that." - Ja Rule
    Jason - Jasle@Centurytel.net
    Exterior & Appearance/Northwest Moderator
    Vendor of Choice: World One Performance
  12. #1300
    Registered User Murchie's Avatar
    Mar 2003
    socal
    Post For those who have hks ssq bov...
    Can someone who has the hks bov tell me exactly step by step what they did when installing it. I have my own but im not sure if i have it set up right. They give you an extra long tube plus alot of zip ties. Thanks!!!!!
    ~Mark
    Mods
  13. #1301
    Registered User BoostedBoxer's Avatar
    Mar 2003
    NOR*Cal
    Question Gfb Bov
    Anyone got the gfb BOV? what do you think--------- pros, con's? Hows it sound?
    My Car is 100% STOCK!
    Pics
    Originally posted by platano
    At 14???
    shoot , I'd hit it at current age, on roof of the car, with cousin driving , neighbor and town priest in the back seat, and that kid from "N.Korea" riding shotgun.
  14. #1302
    Registered User Sunkist's Avatar
    Mar 2002
    Tucson, AZ
    Pros: Sounds awesome has two modes 50/50, 100%
    Cons: hmmm.... some people have had problems running it at 100%
    Thats about it, I have not run it at 100% yet so I don't know if it will affect my car yet or not, I am gonna wait until I can tweak my air fuel mixture so I will not have any problems.
    My woman hates the money pit
    2002 WRX Hybrid 2.5L 16G
  15. #1303
    Mar 2002
    San Jose, CA
    Re: Gfb Bov
    I also had a GFB BOV and got rid of it. These BOV's are known to have idle problems. The piston in the main body of the BOV sticks open at idle causing the car to get a very low idle tone and feel like its almost about to die. You can remedy this by taking the BOV apart, and lubricating the piston with Slick 50 or Duralube, so it stops it from sticking.
  16. #1304
    Registered User 2003WRX's Avatar
    Aug 2002
    Utah
    I am running mine in hybrid mode and have not had any problems. Its makes a pretty cool sound, just a PSSSHT!!! It doesn't vent during normal driving from what I can tell. I posted some info in this thread:
    http://www.clubwrx.net/forums/showth...0&pagenumber=2
    Including a scan of the info page that came with the GFB. I believe they have updated the valve since the early models. I had heard of people having some issues early on, but not with any of the brand new ones... so far so good with mine... love it.
    2003 WRX Sedan
    2004 Nissan Xterra SE 4x4
  17. #1305
    Aug 2002
    California West Cost
    very nice a crisp sound...
    if u set it at 50/50 u can kind of anticipate the sound if u go over 4000rpms.... i also heard running at 100% will cause some problems, such as your car running to lean, etc.
    but this is the case in running any BOV 100%
