Can anyone scan and email the instructions on installing this BOV. I bought it used on Ebay, but the instructions weren't included. Any help will be appreciated. Thanks,
joeyvaz@earthlink.net
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; My HKS sounds louder and longer at mid RPMs than at high RPMs. I'm pretty sure it's normal....
Fahd
Floats like a butterfly and stings like when I pee!
Here you go:Originally posted by joeyvaz
http://www.scoobymods.com/forums/sho...?threadid=1410
I also emailed them to you.![]()
God I love Bov's. I want the HKS too. So I can switch my RFL and HKS weeklyBTW, my car does the same. No worries man
Just your bov souding different from different pressures.
Jason
"It's not how you stand by your car, it's how you race your car. You better learn that." - Ja Rule
Jason - Jasle@Centurytel.net
Exterior & Appearance/Northwest Moderator
Vendor of Choice: World One Performance
Hey, with your GFB venting a 100% to the atmo do you hear noise coming from the right side of the car under slight boost when you shift around 2.5k-3k rpms?
2003 WRX 5spd Sedan
~Stage 4+ 20g~
Have you heard the HKS, Jason? If you want I can post a short vid clip of my car and you can hear it...let me knowOriginally posted by PhreeZe
Jason![]()
Fahd
yeah, that's the wastegate fluttering.
autobahn storming scooby
I believe I have all 4 vids of your carOriginally posted by WRXin'
Have you heard the HKS, Jason? If you want I can post a short vid clip of my car and you can hear it...let me know![]()
Jason
P.S. Unless there is a new one let me know. I want it![]()
HAHA...I've posted those same vids on so many threads...I was assuming you've already seen them, but thought I'd ask anywaysOriginally posted by PhreeZe
I believe I have all 4 vids of your car![]()
Jason
I don't have any new ones. They're the same ones
Fahd
just got this installed on the WRX its an awsome kit bolts in back of intercoller
here is a pic of it installed
wondering if you guys can give me some insight on this. i installed it last night, first time i've heard it, sounds great! well sounds great when i shift in the higher RPM's like 6000... but when i shift lower.. 3000- and gives this whistling sound at the end of every PSSSHHH... does anyone know what that is? and what to do to get rid of it? is it leaking?
Interesting. What takes up the space on the front of the intercooler where the OEM bypass valve was? Do you just leave it hooked up and disconnect the vacuum signal line?
How does the SARD sound?
Aloha, Richard...
Retired Moderator
TXS Stage 4 UTEC + TMIC + JoeP
12.75 @ 105.67mph - 1.74 60'
I am very interested in the setup as well. Please elaborate.
-joe
'02 WRB Sedan
Removed silencer w/ Akimoto Velocity Stack, Blitz Dual TT, Autospeed Prototype Up-pipe w/ Flex-joint, Autospeed Crank Pulley, Autospeed OEM Dead Pedal, Samco IC Hoses, Axxis Pads, Goodridge Lines, Neo Synth Brake Fluid, Speedbleeders, Eibach Pro-Kit, Perrin Endlinks and Rear Sway, 17" Sub Zeros w/ 225/45 ES100s, Crucial Racing Thermostat and 1.4bar Radiator Cap, Autometer Sport-Comp Oil Pressure, EGT, and Voltmeter on the A-Pillar, STI Hoodscoop.
the kit comes with a cover plate for the stock blow off valve flange it uses the same vacume line as the stock did and it has a plug for the dump tube it has a clasic whoosh sound with a whistle after
im thinking of getting thta too. Copy! J/K... anyways... have you had any experiences with other bov's... can you compare the sard to others, in terms of sounds, how loud it is... and boost hold...
Battle! How fast are you really???
