"The BIG BOV thread" (Where all bov question threads get merged) - Page 784
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Fair enough. I know that some people have patched mismatched injectors with MAFv adjustments, which will change all other IPW ...
  1. #11746
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Fair enough. I know that some people have patched mismatched injectors with MAFv adjustments, which will change all other IPW compensations.
    However, changing JUST the intake maybe not so much a challenge.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  3. #11747
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    If the tune is verified BEFORE intake install, and the intake is a known good brand, and then the MAF v is adjusted after... Then, I'd agree with you. Just not the way most people work unfortunately.
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  4. #11748
    Nov 2013
    Honolulu, Hawaii, United States
    BOV tuning on stock car?
    My car only has the invidia N1 Catback exhaust, it has no tune. Can I add a bov and keep it tuneless still?
  6. #11749
    Dec 2011
    Pottstown PA
    yes
    but the stock bov is perfectly fine and doesnt need changing out, a good use of your money would be handling/braking upgrades such as sway bars, endlinks, SS lines, brake pads.
    if you really want the pshh sound save up for an intake, downpipe and a good tune.
    you want to look for a full recirc valve if you do want to change it out to get a little more pshh. stay away from Vent to atmosphere. ive ran the turbo xs 50/50 b.o.v. before with no problems but they are prone to leaking air which would be considered a boost leak.
    Orrrrr why don't you try Fat Burger from now on? You can get yourself a cheese and fries for 2.95, ******
    but i assume you like the tuna here.
    Marky Mark
    My bugeye build
    MinoskePhotography
  7. #11750
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by Dwata808 View Post
    You can. I'd rather see you do a short ram intake though. It'll give you the sound of the blow off valve, the sound of the spool up, and a little more power. A blow off valve will just give you the pshhh and it might make you run poorly. Look at my BOV faq to get you some basic info on BOVs.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  8. #11751
    Nov 2006
    Denver Metro Area
    Blowoff Valve (BOV) FAQ
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  9. #11752
    Dec 2012
    Running the old Greddy Type-S recirc on a Cobb intake......no need to go 50/50.....plenty of noise....giggling chipmunk under low boost and fully loud PSSSHHHHTT at 16 psi. $30 adapter and pulling **** off the old parts shelf worked perfectly.
    Holds boost much better with quicker response over the stocker. I would definitely upgrade stock valves as a primary upgrade.
  10. #11753
    Registered User Sal.LV93's Avatar
    May 2014
    Las Vegas
    So by "stock" that means no motor or turbo work has been done. Intake headers and the like don't apply?
  11. #11754
    Registered User SubiEj255's Avatar
    Jul 2012
    Baltimore
    Quote Originally Posted by Sal.LV93 View Post
    Stock means how it comes directly from the factory.
    A car is only as good as its driver
  12. #11755
    May 2014
    Las Vegas
  13. #11756
    Aug 2012
    Tucson, AZ
    No stock means stock. A stock car is not molded where a stock engine means just the engine isn't tampered with yet but can have headers
    Sent from my SCH-I545 using Tapatalk
    Hawkeye Alliance 520
    Previous cars:
    2010 Mitsubishi Lancer (sold)
    2009 WRX (sold )
    2013 Scion tC (sold)
    2008 Audi A4 (Totaled)
    Photographer/storm chaser
    https://www.facebook.com/kevinrimphoto
    IG - kevinrimcoski
  14. #11757
    May 2014
    Sydney AU
    Question, I have a FMIC with a blow off valve and I want to put a plumb back on (emission laws here mean I need one and I bought the car with the existing one) How do I install the plumb back one? I understand one end plugs into the existing hose where the BOV is but where does the other end go? (its a 99 WRX wagon)
    Sorry, Pictures would be helpful as I am male
  15. #11758
    May 2014
    Sydney AU
  16. #11759
    Apr 2014
    blow off valve questions!
    So I've been looking for a blow off valve for my 2014 wrx. I see a bunch of them around but I don't know if they are make and model specific. Or can I just use any one in particular seeing as how it's just a bolt on part? I'm still new to all this car stuff so I'm just wanting to make sure I don't get anything that's going to hurt my car instead of help.
  17. #11760
    Jan 2012
    New Jersey
    Please dont get it no need for a BOV if you want the noise just buy a different intake and get a tune for your car.
    CFLip2x 2012 WRB WRX Build
