"The BIG BOV thread" (Where all bov question threads get merged) - Page 77
Page 77 of 798 FirstFirst ... 27676869707172737475767778798081828384858687127177577 ... LastLast
Results 1,141 to 1,155 of 11961
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; What do you guys think of Turbo XS blow off valves?? I'm thinkin about getting the Type-H....
  1. #1141
    Feb 2003
  3. #1142
    Registered User 02WRX82's Avatar
    In YOUR closet
    i think you'll have the same problem with the type-h as the RFL. They are a single valve, push type. so they will have a tendancy to leak unless you jack up the spring pressure so high that it doesn't release air until you really get on the gas., trust me , i had the rfl, i know.
    "Long separated by cruel fate, the star-crossed lovers raced across the grassy field toward each other like two freight trains, one having left York at 6:36 p.m. travelling at 55mph, the other from Peterborough at 4:19 p.m.at a speed of 35mph."
  4. #1143
    Feb 2003
    Which one would be my best bet to get then??
  6. #1144
    Registered User jutus's Avatar
    Winnipeg, Manitoba, Canada
    I have a type-H, it does not leak. It flutters under low boost like the gfb but no biggie.
    The blowoff sound is longer at moderate boost with the type H than with the other bovs.
  7. #1145
    Moderator aussieinstlouis's Avatar
    Jun 2002
    S34 47.322 E138 29.131 (WGS84)
    The 100% Forge that I have does not flutter.
    Another point that should be made about the Forge is that they are a completely rebuildable item and Forge supports with all spares. I needed to get the 'blue' as opposed to the 'yellow' spring and they sent if for free in 3 days from their US distributor.
    Very happy with it!
    Another point to note - it is a lot smaller that some other BOVs
  8. #1146
    Registered User WRC_Obsessed's Avatar
    Jan 2002
    Boston/NNJ
    aussie can you please further explain...
    is this something that i will need to order?
    -Brian
    Twisty Monster - 335 ft/lb of torque @ 3600 rpm on a stock turbo. Is that possible? Yes it is.
  9. #1147
    Jun 2002
    The colour is the way they differentiate the 'stiffness' of the spring. I found it was opening venting too easily for my tastes and called them - they said 'no worries' you need a stronger spring - call George at Forge Motorsports USA and he sent it to me the next day.
    To clarify the venting issue I had - I do not like the BOVs that open when you are in neutral and rev to 3000 rpm and open when you release the throttle - that is where a lot of the problems occur (IMHO).
    I get slight venting in neutral only if I rev over about 5500 rpm.
    I good exercise when you get your BOV is to take it apart and understand HOW it works.
    THere are two springs in the Forge - If I get the urge this weekend - I may pull mine off and photograph the insides and post here - although it is Mardi Gras this weekend, I may be too distracted by all the beads and titty action!!
    Cheers,
    Andrew
  10. #1148
    Jan 2002
    Boston/NNJ
    hahahahah....
    thanks aussie...
    i should be receiving my forge either today or tomorrow so i will be sure to take it apart (no special tools required is there?) and then install it to see how i like it...
    i agree i probably don't want the thing going off at 3000 rpm...more like the way you have it set up....in the 5000 rpm range...
    -Brian
  11. #1149
    Jun 2002
    You just need an allen key.
    It is a metric - so make sure you use metric - the imperial is close, but could damage the screws.
  12. #1150
    Jan 2002
    Boston/NNJ
    cool...thanks
    -Brian
  13. #1151
    Moderating U! KurleeDaddeeWRX's Avatar
    Mar 2002
    San Jose, CA
    Cheers,
    Andrew
    I undertook this disassembly when I had my GFB BOV. So I took some pictures for this very occasion. And for those that want to know how a BOV works. And the Forge BOV is probably very similar.
    Enjoy<
  14. #1152
    Jan 2002
    Boston/NNJ
    thanks for the pic kurlee...
    -Brian
  15. #1153
    Jan 2002
    Boston/NNJ
    ok...so i finally go my Forge 100% atm BOV today and installed it....
    the install was pretty easy...even in 20 degree weather...
    so i took it out for a drive and it really is just like everyone says....
    when sitting at idle there are no problems what so ever...runs just like stock...
    when you are into boost it lets off a nice solid pssshhhhh....very nice...though i think i am going to go the route that aussieinstlouis went and get a stiffer spring so that it is not letting off as easily...
    to give you an idea of how loud it is...when i had a cd playing at vol level 6 you could just hear it over the music...when i turned it up to 9 you really had to listen for it....
    i am very pleased...when i get my ecutek in a month or so i will be sure to flash the ecu with 100% atm bov and there should be no worries...
    so now everyone should run out and buy one
    it runs just like stock....if not a little better...
    -Brian
  16. #1154
    Jan 2002
    Boston/NNJ
    here it is...
    -Brian
  17. #1155
    Jan 2002
    Boston/NNJ
    here it is apart...
    -Brian
