"The BIG BOV thread" (Where all bov question threads get merged) - Page 761
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; you guys are definitely cracking me up....
  1. #11401
    May 2007
    behind the wheel
    Rogan o_0
  3. #11402
    Registered User GarrettKoonsman's Avatar
    Apr 2009
    CO
    I think I am going to punch a baby
    2003 Midnight Black Pearl WRX Sedan
    200.7 AWHP Protuned Stage 2 at 5400ft above sea level
    Bugeye Mafia Member #225
    Mods
    Pics
  4. #11403
    May 2007
    behind the wheel
    LOL
    ok, back on topic here, guys
    Rogan o_0
  6. #11404
    Palmyra, NJ
    LOL
    In that case, I actually said something smart!!!! This was in regards to Mike193's question in another thread:
    Quote Originally Posted by Mike193 View Post
    Mikie, not sure if you know the answer to this, but if the BPV is more effective then the BOV (i've read all the threads, the summary I understand is, the BPV re-uses the pressure and has it available for the engine quicker, and the BOV gets rid of it, causing the turbo to have to create more) Basically my question is, in what situation is the BOV better then the BPV? i was thinking the BPV would be better no matter what situation. But I guess maybe like a quick spooling turbo, it doesn't matter? I'm lost, please explain if you know.
    In most instances a BOV won't be better, period. Usually they are only used in much higher horsepower situations where boost will be raised significantly higher. The stock BPV on 02-07 models are good to about 20-22psi before they run into a possibility of leaking boost. And on the 2008-2012 models, the BPV is actually known to be a lot weaker from what I've read. Replacing with aftermarket recirculating BPVs aren't a bad idea for an upgrade if you start pushing Stage 2 power levels, which usually is higher than 19psi in STIs (17psi or so in WRXs I believe).
    BOVs can be run if the intake metering is changed from MAF, (which we currently have which pre-meters the air, accounting for the recirculated air pushed in from a BPV) to a MAP set up, which is manifold absolute pressure (aka Speed Density). The ECU would read the air already in the manifold as opposed to the air being metered in from the intake, in which case it wouldn't matter if the recirculated BPV charge was in there or not.
    The BPV generally doesn't have anything to do with the spooling of the turbo...only with the discharging of excess pressure during shifting.
  7. #11405
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Poor Garr Bear
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  8. #11406
    Registered User gaspricessuckk's Avatar
    May 2012
    Putnam, CT
    I am trying to get my b.f to sell her after market bov, what would be best, go back to the stock bpv or i have seen go fast bits, i want her to gain a lil hp here and there, she wants to do a catback exhaust.
  9. #11407
    Palmyra, NJ
    Quote Originally Posted by gaspricessuckk View Post
    BOVs and BPVs do absolutely nothing to provide any power gains. Stock BPV is best on any application generally under 20psi of boost (which you aren't anywhere near). What year/model/mods to begin with anyway?
    And for that matter, Catback exhausts don't do anything for power gains either.
  10. #11408
    May 2012
    Putnam, CT
    Yeah that is what I thought, I have been reading a few threads, check my thread in the new member forum.
    Stock 2002 bugeye as they call it, wrx impreza 5 speed 151k.
    I should say she wants to do a exhaust and wanted intake but convinced her to do uppipe.
  11. #11409
            MainFrame's Avatar
    Austin, TX
    I wouldn't say that's entirely true. It really depends on your mod level. I'm running an OEM STi axleback on my car and when I was talking to my tuner the other night about the next round of work we're about to start on my car he said the muffler was going to be a major restriction. I'm going to open the cutout for part of the tune, but he said it would be a big enough difference that I will need a different map for with the cutout open, and one for with it closed.
  12. #11410
    Registered User lytlec's Avatar
    Jan 2009
    Central PA
    Does anyone actually use a blow off valve?
    <-------- Taylor Swift.
    Hawk-Eye Alliance #137
    First Mods...what to do.
    Subaru Guide
  13. #11411
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by lytlec View Post
    I hear them all the time at the track on WRXs running 15 second 1/4 miles..
  14. #11412
    Palmyra, NJ
    Well yeah, but the OP is assumedly starting at a "stockish" level given a BOV, low level of knowledge (prompting for research and questions), and the fact they are asking about a CBE...
    You're near or above 400whp, which I know that's when a CBE really can become a restriction, cause at that point it will be the bottle neck in your exhaust
  15. #11413
            MainFrame's Avatar
    Austin, TX
    Should be 470-490whp by the end of the month.. fingers crossed.
  16. #11414
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Holy bajeesus. It never ends, does it?
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  17. #11415
            MainFrame's Avatar
    Austin, TX
    no...
    I'm really hoping everything goes well with this build and that I'm satisfied for a good amount of time.. I can't afford to keep doing this, lol.
