"The BIG BOV thread" (Where all bov question threads get merged) - Page 76
Page 76 of 798 FirstFirst ... 26666768697071727374757677787980818283848586126176576 ... LastLast
Results 1,126 to 1,140 of 11961
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; i just installed the gfb bov at 100%, runs perfect no idle problem no sign of riches, maybe their was ...
  1. #1126
    Nov 2002
    i just installed the gfb bov at 100%, runs perfect no idle problem no sign of riches, maybe their was a ecu fix for the 03's, cause i know the 02s had problems with 100% atmo....
    2003 WRX 5spd Sedan
    ~Stage 4+ 20g~
  3. #1127
    Registered User ManguWRX's Avatar
    Nov 2002
    Raleigh, NC
    I also have a GFB 100% Vent. No Problems either.. 03 WRX !
    Aspen White 2003 WRX
    COBB STG 2
    SQC #076
  4. #1128
    Registered User WRC_Obsessed's Avatar
    Jan 2002
    Boston/NNJ
    there are a couple of really good thread in the Engine Performance forum on BOVs...here are a few...
    PhreeZe's TurboXS RFL BOV (video inside!)
    Has there been a conclusion made about 100% atmosphere BOV's?!
    TXS RFL or HKS BOV which is louder?
    Forge 100% BOV
    i'd say that the forge 100% atm and gfb 50/50 BOVs are two of the more popular BOVs on this site...
    -Brian
    Twisty Monster - 335 ft/lb of torque @ 3600 rpm on a stock turbo. Is that possible? Yes it is.
  6. #1129
    Nov 2002
    Just installed GFB BOV & MBC
    Just installed my GFB Bov at 100% yesterday and it works good and no rough idle or anything.
    I have 1 question though, when i dont boost hard, only like .03 or .04mpa and i let up off the gas i hear a fluttering sound, is that my wastegate, and is it okay?
    I also installed my MBC, and set it for just a hair past .1mpa in 3rd, 4th, 5th gears.. Guessin around 14.7psi. I also used the zip ties onto the tubes, those tubes are gonna shoot off the wastegate and the turbo from the pressure are they.. Are those zip ties good enough to hold them on.
    My car is bascially stock except for these 2 mods i just did and the intake silencer is removed, do you think that is a good boost setting to be on?
    2003 WRX 5spd Sedan
    ~Stage 4+ 20g~
  7. #1130
    Registered User blackshadow's Avatar
    Apr 2002
    Milan, Italy & Arnhem, Netherlands
    that fluttering noise is the blow off valve, mine does it too. It's fine.
    autobahn storming scooby
  8. #1131
    Registered User RexMobbin''s Avatar
    Nov 2002
    zipity here, zipity there, i'm zipity everywhere...
    obcessed, its been 5 days since your last post, how's it working out? and how does one go about "reflshing" the ecu?
  9. #1132
    Jan 2002
    Boston/NNJ
    i didn't use the zip ties...i went to the hardware store and got some of the screw type clamps instead...
    -Brian
  10. #1133
    Nov 2002
    Hey, do you notice the sound coming from the right side of your car though... it does it all the time when i shift with low boost, kinda worries me...
    2003 WRX 5spd Sedan
    ~Stage 4+ 20g~
  11. #1134
    Nov 2002
    I put my gfb bov on yesterday set it for 100% no problems, no backfire, rough idol or anything.. Only thing i noticed was a fluttering when i let up off the gas after low boost, comes from the right side of the car.
    2003 WRX 5spd Sedan
    ~Stage 4+ 20g~
  12. #1135
    Jan 2002
    Boston/NNJ
    it still hasn't come yet ...
    they lost the P.O. in the warehouse,....it should be here monday or tuesday though...i'll keep you informed...
    as far as reflashing the ECU...it is ECUtek...you can get some info in the engine management forum on it...lots of stuff there..
    -Brian
  13. #1136
    Jan 2002
    Boston/NNJ
    sounds like the wastegate...
    -Brian
  14. #1137
    Feb 2003
    Kansas City
    Describe the sound a little better. If it's what I think it is, it is just when you don't build enough boost to overcome the BOV and it's the existing pressure exiting the stock air box. It's kinda like a turbo "fart" I can't really describe the sound, but it's a very fast on-off type pressure realease sound.
    Later,
    Eric
  15. #1138
    Nov 2002
    yes, could be a fart
    2003 WRX 5spd Sedan
    ~Stage 4+ 20g~
  16. #1139
    Registered User 02WRX82's Avatar
    In YOUR closet
    like i said in my posts on the linked thread, I have the forge and i am completely happy with it. It is loud enough to be heard, but not too loud. The car runs EXACTLY like it did stock, if not a teeny bit better inbetween shifts.
    I had the turboXS- RFL before. It ran terribly, Stumbled at idle, ran rich, and hesitated while running. It was WAY Loud!
    you will be happy with the forge 100 percent. IT has a dual valve system. it makes it work very well.
    "Long separated by cruel fate, the star-crossed lovers raced across the grassy field toward each other like two freight trains, one having left York at 6:36 p.m. travelling at 55mph, the other from Peterborough at 4:19 p.m.at a speed of 35mph."
  17. #1140
    Nov 2002
    these "pro-forge" posts are very encouraging. i think im gonna get one very soon, as soon as i get this suspension thing under wraps. thanks to all who have posted
