"The BIG BOV thread" (Where all bov question threads get merged) - Page 756
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Mikie13 It will. Or even more so with an SRI or just a snorkus delete to the ...
  1. #11326
    Gold Member lokey's Avatar
    Jan 2011
    Crofton, MD
    It will. Or even more so with an SRI or just a snorkus delete to the airbox (which you can't do with your generation WRX from what I understand).
    That's why we always suggest if you really want the sound, you're better off getting an Intake and tuning for it.
    +1. An intake will give the sound. Tune for it, of course. Until your boost gets over 18ish, the stock BPV is reliable and plenty loud with a SRI. Beyond that, you risk leaks.
    Greg
    Build Thread
    ProTuned Stage 3ish '11 WRX Ltd HB (SWP) ~ 354 awhp 404 ft-lb tq on E85
    Friends don't let friends drive Mitsubishis.
  3. #11327
    Dec 2011
    Ft. Bragg
    blow off valve
    A friend of mines gave me his NGR blow off valve off his AE86 and i was wondering since my sti has a wastegate would it be smart to put a blow off valve on it.
  4. #11328
    Registered User irvin787878's Avatar
    Jun 2009
    Milesburg / Near State College PA
    Your Sti already has one one it. Is your Sti basically stock? If so, Stick with OEM its more reliable. Just my 2cents.
    HAWK-EYE ALLIANCE #7878
    2007 WRX TR
    My work in progress. http://www.clubwrx.net/forums/off-to...ld-thread.html
  6. #11329
            MainFrame's Avatar
    Austin, TX
    Aftermarket blow off valves cause problems. The stock one that came with the car is the best (unless you're running a huge turbo with a built engine).
  7. #11330
    Dec 2011
    Ft. Bragg
    hey im moving to ft hood texas im not sure if your familiar with the area but are there any good shops out there because i am looking to rebuild the engine
  8. #11331
            MainFrame's Avatar
    Austin, TX
    Most of the Ft. Hood crew take their cars to AWDTuning in Flower Mound.. there's actually quite a few guys down there with some pretty expensive built Subies.
  9. #11332
    Jan 2011
    Crofton, MD
    If you're on even an OTS stage 2 tune, you should replace the stock BOV, which is prone to leaking at >18 psi.
    Greg
    Build Thread
  10. #11333
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by lokey View Post
    I guess it depends on the year model. Mine never leaked. The pressure differential between the the two sides of the BPV keeps the valve closed. I even remember seeing a test someone did with the Forge BPV where they removed the spring entirely, and the diaphragm stayed closed at 20psi because of the pressure differential. Leaking is very common with aftermarket BOVs though. Most will leak even at idle.
  11. #11334
    Replacing the valve isn't the issue, I don't believe; it's an issue of recirculating vs atmospheric valves
    Resident Tuner @ WTF Tuning
  12. #11335
    Registered User GarrettKoonsman's Avatar
    Apr 2009
    CO
    Is this true?? I can't imagine the '11 valve is designed that poorly. 02-07 stock valves are good for more than that.
    If it is, do not put a cheap valve on, buy a VERY high quality 100% recirc valve.
    2003 Midnight Black Pearl WRX Sedan
    200.7 AWHP Protuned Stage 2 at 5400ft above sea level
    Bugeye Mafia Member #225
    Mods
    Pics
  13. #11336
            MainFrame's Avatar
    Austin, TX
    That's pretty much it. Although there are probably some poorly designed recirc valves that have problems. When most people talk about buying a BOV they're talking about atmospheric types, which we all know are prone to leaking, not to mention the fact that they dump air that has already been metered by the MAF, causing the car to run extremely rich for brief moments.
    I never had a problem with my stock BPV.. when I bought my second WRX it came with a TurboSmart atmospheric BOV, which leaked. I traded that for a HKS SSQV atmospheric BOV, which also leaked. Now that I'm running a Forge Recirculating Race type BOV I have no problems, even at 25psi.
  14. #11337
    Jan 2011
    Crofton, MD
    +1. This is what I have as well.
    Greg
    Build Thread
  15. #11338
    Palmyra, NJ
    Quote Originally Posted by GarrettKoonsman View Post
    I've heard the newer ones are worse due to plastic. My 07 STI held perfectly fine running 20.5lbs of boost. Never had a leak issue with that stocker.
  16. #11339
    Dec 2011
    Pottstown PA
    my friend gave me a turbo xs bov that was 5050 like atmospherical and recirculating, i had it on for about a day and theres no need unless u want the sound or have a built engine. i put an intake on and took the bov off and it still sneezes as loud with just the intake. save it for when u have a built engine
  17. #11340
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by Ruh Roh View Post
    Explain why it would make a difference if you have a "built motor." As far as I'm concerned, the demand for a VTA BOV will not change if you have forged internals or stock internals. The only time that a VTA BOV makes sense is if you have converted to a blow-through MAF system. Even then, compressor surge is a thing of the past...
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
