"The BIG BOV thread" (Where all bov question threads get merged) - Page 753
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; stock or use the proper forge valve for our cars. Either way venting to atmosphere is just to show off.. ...
  1. #11281
    The Fruit mangostick's Avatar
    Oct 2009
    VB VA .. the ghetto on the sea
    stock or use the proper forge valve for our cars. Either way venting to atmosphere is just to show off.. has no benefit (if anything, as the thread dictates.. its more harmful than anything else).
    OBP 2010 5dr *traded*
    SWP 2013 FRS
    SUCH IS MANGO!
  3. #11282
    Mar 2011
    Seattle
    Quote Originally Posted by sjcurtis View Post
    I liked my Perrin bpv it was alot louder then the stock bpv and I had no problems out of it.
    Hm I never considered an aftermarket BPV being louder than the stock one, which I just realized I CAN actually hear a little when hammering from first to second.
    True words? Can you get a slightly louder BPV that sounds cool and won't screw up your fuel/air ratio?
  4. #11283
    Registered User sjcurtis's Avatar
    Sep 2010
    Selma, Alabama
    I had alot of people think that I was running a BOV because it was so loud but it was just a Perrin BPV and I had a CAI and the Perrin turbo inlet made it sound a little better also.
  6. #11284
    Palmyra, NJ
    yep...this is about the only "safe" combination to not see any issues with an aftermarket BOV...considering it still runs similar to how the stock system works, just with upgraded parts (this post intended for those in this thread that don't know what they are doing, as I know you know your stuff SJ ).
  7. #11285
    Sep 2010
    Selma, Alabama
    I have just ordered another one to go on my 2011 STI. I will try to get a sound clip of the BPV after I install it.
  8. #11286
    Oct 2011
    if i get a new bov do i need to take it to a shop to get it tuned or anything?
  9. #11287
    Quote Originally Posted by JakeReed
    No
    Sent from my Droid using Tapatalk
    2005 WRX STi (Mods | Virtual Dyno) - Weekend Warrior
    Resident Tuner @ WTF Tuning
  10. #11288
    Registered User Pylonpounder's Avatar
    Aug 2010
    Factoryville, PA
    The object is DON'T get a new BOV. Blow-OFF-valves are bad. BPV, or ByPASS valves, are fine. preferably 100%, 50% recirc still vents 50% to atmosphere and messes you up
  11. #11289
    Quote Originally Posted by Pylonpounder
    No, they aren't. They aren't ideal on a MAF-based car, but UTECs are cheap, which would eliminate any fueling issue with them.
  12. #11290
    Registered User Turb0Licious's Avatar
    Oct 2011
    NJ/PA
    Few Questions:
    Just got my '11 WRX after having my '04 PG GLI for years, and I had a Forge 007 DV on it, after getting rid of the XS I had on.
    1. Can you run DVs on WRXs? Will it still run rich?
    2. With a CAI and a new Bypass valve, will you hear it more, like you do when you have a CAI and a DV?
    3. Are there any safe BOVs for WRXs out there? What is the difference between 100% atmospheric and a recirculating Bypass Valve? Is one safer?
    Thanks for the feedback, new to BOVs sort of, and haven't tuned since 04' I'm sure things have changed.
  13. #11291
    Registered User GarrettKoonsman's Avatar
    Apr 2009
    CO
    Quote Originally Posted by Turb0Licious View Post
    Few Questions:
    1. Yes but they will be commonly referred to as BPV (at least thats my understanding of what a DV is). No you won't run rich but your car is already running a BPV so there is no reason to waste money replacing it.
    2. Yes, it will increase the sound. Just be sure to get an intake that is known to work well with your car and know if that intake requires a tune or not
    3. Not in 98% of cases. There are definitely "good" BOV's vs crap ones but you must be careful and they often are still a bad idea without an alternative tuning option such as UTEC or for guys not running of MAF's anymore (speed density). In short, they are for more specialty applications that stock or near stock ones most of the time
    Overall, your better off putting that few hundred dollars into other aspects of your car
    2003 Midnight Black Pearl WRX Sedan
    200.7 AWHP Protuned Stage 2 at 5400ft above sea level
    Bugeye Mafia Member #225
    Mods
    Pics
  14. #11292
    Palmyra, NJ
    Quote Originally Posted by GarrettKoonsman View Post
    Finally, someone asking good questions about BOVs...and Garrett comes through with some good answers.
    Keep in mind that the stock BPVs are generally considered good at holding/releasing boost until the 20-22psi range. Stock, you are only running 13.5 or so PSI on a WRX and only 17 PSI on an STI. So, reliability reasons, you just don't need one until you start increasing your boost (which is done through mods and specifically, tuning). My first STI was tuned to 20.5psi, stage 2 protuned...and would sometimes get up to 23psi or so during the cold season, and my stock BPV held boost fine. So ultimately TurboLicious, you don't really need one and as Garrett says, are better off using your money for better improvements.
    Where in the NJ/PA area are you located. I live in Philly and work in NJ. Welcome!
  15. #11293
    Oct 2011
    NJ/PA
    Thanks for the feedback, both of you.
    I did a little reading up on it, as I've been out of the tuning game for 7 years now (had an '04 PG GLI, modded) and only ran a Forge 007 DV on my GLI and with my Carbonio CAI I heard my DV a ton, but hardly at all without CAI. Will my stock BPV be a lot louder with a CAI? I like the sound, but of course won't sacrifice or harm my WRX by throwing on a BOV, so thats the only reason I was looking into aftermarket BPV.
    Currently I'm in Erie PA working up here, but I'm originally from Monmouth County NJ.
  16. #11294
    Palmyra, NJ
    You will hear the stock BPV rather audibly if you add a CAI. However, an intake is a part that needs to be tuned for on the 2011 WRXs to operate correctly.
  17. #11295
    Jul 2011
    I have a turbo xs rfl bov which is 100% atmosphere. I currently have this uninstalled because it was making my car run really ****ty and it would occasionally stall out. Anybody else have this problem?
