"The BIG BOV thread" (Where all bov question threads get merged) - Page 744
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; You aren't stalling because of the valve, you're stalling because of the giant vacuum leak you have created by leaving ...
  1. #11146
    Jul 2010
    Cincinnati
    You aren't stalling because of the valve, you're stalling because of the giant vacuum leak you have created by leaving that recirculating tube open. You could also be damaging your engine by running extremely lean by letting in all that unmetered air. At the very least, plug that tube up before you do further damage.
    Stink eye mob #727
    2011 WRX DGM Hatch, Protuned Stage 1
  3. #11147
    Feb 2010
    SL,UT
    Quote Originally Posted by jd92677 View Post
    This^
    lean A/F ratio + extra heat = Engine go boom
    Hawk-Eye Alliance #801
  4. #11148
    Registered User GarrettKoonsman's Avatar
    Apr 2009
    CO
    I really hope this car doesnt get driven until this is fixed.....or else we might have a thread titled "help my motor died - what are my options"
    2003 Midnight Black Pearl WRX Sedan
    200.7 AWHP Protuned Stage 2 at 5400ft above sea level
    Bugeye Mafia Member #225
    Mods
    Pics
  6. #11149
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Quote Originally Posted by spnkdrm View Post
    If your are looking for the vrrrooommmm PSH
    Look at an intake or a snorkus delete. Much safer and you can tune for the intake....
    Just my 2% of a dollar
    I was under the impression that the '08+ models didn't have a snorkus, otherwise I would have recommended that. Correct me if I'm wrong about that though.
    To the OP: On the 2002-2007 cars for sure (maybe the later models as well), there is an intake silencer box located in the right front fender in the intake line. Removing this intake component provides much of the "woosh" sound people look for in a BOV, without the risk of engine damage.
    2007 Outback 3.0R wagon
  7. #11150
    Registered User DoubleUarrEX's Avatar
    Dec 2010
    Connecticut
    50/50 bov
    hey i was looking into getting a 50/50 bov for my 02 wrx. looking for more noise, yeah i sound like a ricer idc. but i dont want to do more harm than good. i also saw somthing about removal of the intake resonator, but im concerned ill suck up water. any ideas?
  8. #11151
    Feb 2011
    Remove the air box resonator and replace it with a u tube, or you can mod your box just do a search or look in the DIY threads.
  9. #11152
    Registered User Pylonpounder's Avatar
    Aug 2010
    Factoryville, PA
    Use the search function, and stickies. BOVS are a bad plan. Sure, they sound "cool". They also release already measured air into the atmosphere, causing the engine to inject improper amounts of fuel, as it is the proper amount of fuel for if all that air was reaching the engine. Which it's not. So you tell me....if the noise still puts you 50/50 with that information, then feel free to install one, at your own risk. Messing with the a/f ratio is never a good thing. That's like getting an intake for a wrx. Why? Suck particulates into the engine, suck water into the engine, barely get any power gains....Just doesn't make sense why you'd mess with the a/f ratio for no benefit
  10. #11153
    May 2007
    orlando flawduh
    You can do an intake silencer delete. I've had mine for years with no issues
    http://www.scoobymods.com/intake-sil...=&threadid=113
    desiree
  11. #11154
    What modifications are done to the car? Going StageII+ with Speed Density (Group-N rom / UTEC) negates all the cons of an aftermarket valve (besides people thinking it's obnoxious) are negated.
    Just be aware that it's not a plug-n-play, set & forget part. If you take the time to properly setup/maintain it, a quality valve shouldn't screw things up too badly on a MAF system (like stock).
    Resident Tuner @ WTF Tuning
  12. #11155
    Apr 2007
    8000' up in Colorado
    Quote Originally Posted by Pylonpounder View Post
    You need to qualify this a bit. Your advice doesn't apply to anything other than an otherwise stock WRX, and doesn't apply to the latest models.
    1. Particulates will always increase versus a stock paper filter. I don't know of an aftermarket intake that filters the same or better. So that's true.
    2. Sucking water into the engine is an anomaly. It will only happen in rare circumstances if you hit a big pool of water, so just don't do that and you'll be fine.
    3. On older WRXs they didn't give much power, but on the newest models they seem to do a lot more.
    And you forgot two of the big reasons people get them:
    1. Sound
    2. Dress up your engine bay (which I think is a stupid reason, but that's just me )
    Scott
  13. #11156
    Apr 2007
    You're correct, the 2008+ models don't have the snorkus.
    Damn that's a funny word.....
    Scott
  14. #11157
    Oct 2010
    Portland, OR
    Ok, I thought so. I remembered reading that when I removed the snorkus on my bugeye. Yes, yes it is a funny word. It sounds like some creature from Sesame Street.
  15. #11158
    Registered User sjcurtis's Avatar
    Sep 2010
    Selma, Alabama
    1. Sound
    Is there anything that you dont think is stupid other then suspension upgrades?
  16. #11159
    May 2007
    orlando flawduh
    Quote Originally Posted by Rambo View Post
    08 wrx intake silencer delete
    Others have found a similar solution
    desiree
  17. #11160
    Quote Originally Posted by sjcurtis
    Really? Let's keep things civil...
