"The BIG BOV thread" (Where all bov question threads get merged) - Page 731
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by bkallday27 if you get a blow off valve get a dual vented one. it still gives you ...
  1. #10951
    Moderator Donkey's Avatar
    Da boonies,Va
    Quote Originally Posted by bkallday27 View Post
    if you get a blow off valve get a dual vented one. it still gives you that signature sound but also keeps some boost into the engine
    Pretty sure hybrid "50/50" BOV has been mentioned a couple of times in the first 10,000 posts in this thread....
    2002 FORESTER S
    1998 FORESTER S
  3. #10952
    Palmyra, NJ
    Bump since we haven't touched this thread in over a month
    PSSSSSSSSSSSSSSSSSHHHHHHHHHHHHHHHHH!!!!!!!!!!!!
  4. #10953
    Registered User 2005sti's Avatar
    Jan 2010
    Trinity, NC
    Ive read about the BOV causing a wrx to run rich between shifts. I have an 05 WRX and want a BOV. I can get my car tuned to run perfectly fine with a BOV, correct?
    2005 Subaru Impreza WRX - FP 68HTA'd
    2007 Honda Civic Si (Stock) - Traded it for ^^^
    Blobeye Syndicate #728
  6. #10954
    May 2007
    behind the wheel
    you can't really tune for air that is lost.
    Rogan o_0
  7. #10955
    Jan 2010
    Trinity, NC
    so really, there is no way to vent my BOV to the atmosphere (in any shape, form or fashion) or get an aftermarket BOV, get it tuned, and have it run perfectly fine?
  8. #10956
    May 2007
    behind the wheel
    not unless you reconfigure it for blow-thru and run a non-stock EMS, and place the BOV pre-metered air, No.
    Or go Speed Density.
    Rogan o_0
  9. #10957
    Jan 2010
    Trinity, NC
    can you dumb that up for me a little? Im not all that great with cars and their fancy young, hip lingo. Please dont hate me, just trying to understand.
  10. #10958
    May 2007
    behind the wheel
    Quote Originally Posted by 2005sti View Post
    well, at over 40, you won't get the young hip lingo from me.
    In a nutshell:
    air enters through the filter, then into the intake tube/Mass Airflow Sensor. This reads the airflow rate, and then tells the ecu how much is coming in. Then the ecu fuels according to that 'metered' air that has passed through the MAS sensor, so the air/fuel mixture is correct. When a BOV dumps that 'metered' or 'measured' air, then the fuel that has been programmed to deliver now is more than is needed, throwing the air/fuel ration way to the RICH side. This can/does/will cause cylinder wash (where the gasoline removed the oil coating on the cylinder walls, because there isn't enough air to fully atomize the mixture. This also will cause a rapid change in piston/combustion chamber temperature, then back to hot again, and a super fast rate. At 5000+rpm, you can only imagine what this can do over a fairly short period of time. Some engine react more to this change than others. Some don't make apparent reactions to this, but the issue is still there, and happens across the board.
    The oxygen sensor reads this real rich situation, and tells the ecu to take fuel out, about the time you're back into the throttle. You just had a rich condition, now it goes lean, then back to rich, and so on.
    With a speed density setup (say, like a honda, with a MAP sensor), it reads the manifold pressure and makes fueling determinations from that. So a BOV opening up, drops the manifold pressure, and the ecu takes fuel out, making this no longer an issue.
    Same above goes for a blow-through setup, where the MAS semsor is downstream of the BOV, so the vented air hasn't been metered yet.
    A Subaru ECU and engine management system is very sophisticated and is quite sensitive to changes not programmed into it.
    If you're dead-set on the wooosh, cold-air intakes + stock BPVs will give you some sound. Not BOV style, but it will.
    At the outmost, 50/50 BOVs will not cause as much of a rich condition, but it still does. the stock BPV will handle up to 20psi easily, so it becomes a question of do you want performance, or 'hey, check me out! I drive a turbo cah!'
    How's that?
    For you, if you go turbo-back exhaust, CAI, and Stg2 Cobb or RomRaider OpenSource flash, you'll be surprised how much quicker/faster/stronger your WRX will be. 200-220awhp is an eye-opener over stock. Your old honda wouldn't be able to hold it's nutsak. LOL
    Cheers
    Rogan o_0
  11. #10959
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Well put Rogan.
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  12. #10960
    Jan 2010
    Trinity, NC
    okay thanks! Ill just stick with the stock one and put a nice CAI on. :P
    thank you!
  13. #10961
    Nov 2006
    Denver Metro Area
    thank you!
    K&N Short ram, APS CAI, SPT short ram...
    That's what you're looking at.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  14. #10962
    Feb 2010
    BOV on stock engine
    i got a 2.0l turbo 2004 wrx, and I wanted to get a HKS blow off on it, i know it bad for stock engine and stock turbo, but I was wondering if I could still do it, without messing up too much.
  15. #10963
    Registered User sccoby823's Avatar
    Dec 2009
    New Bedford, Ma
    it causes the engine to run rich, because it messes with the MAF
    ***Stink Eye Mob 169***
    Stage 2 WRX Tuned by Brendan at Brentuning
    296 awhp
    317 awtq
  16. #10964
    Registered User 2w0r0x9's Avatar
    May 2009
    LBI, NJ
    Quote Originally Posted by Arnelis View Post
    Dont waste the money..use the search function and search "intake silencer delete" this will get you the ricer pshhh sound you want
  17. #10965
    Da boonies,Va
    2002 FORESTER S
    1998 FORESTER S
