"The BIG BOV thread" (Where all bov question threads get merged) - Page 73
Page 73 of 798 FirstFirst ... 23636465666768697071727374757677787980818283123173573 ... LastLast
Results 1,081 to 1,095 of 11961
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; RFL should be renamed T FL (TOO FREAKIN' LOUD!)... It doesn't sound good on a street car IMHO. The HKS ...
  1. #1081
    Registered User is2scooby's Avatar
    Jun 2002
    Honolulu, HI
    RFL should be renamed TFL (TOO FREAKIN' LOUD!)... It doesn't sound good on a street car IMHO. The HKS SSQV is SWEET though!
    Aloha, Richard...
    Retired Moderator
    TXS Stage 4 UTEC + TMIC + JoeP
    12.75 @ 105.67mph - 1.74 60'
  3. #1082
    Registered User NJwrbT-WRX's Avatar
    Apr 2002
    One Square Mile, NJ
    RFL stands for Really *****in' Loud-- nuff said.
    -joe
    '02 WRB Sedan
    Removed silencer w/ Akimoto Velocity Stack, Blitz Dual TT, Autospeed Prototype Up-pipe w/ Flex-joint, Autospeed Crank Pulley, Autospeed OEM Dead Pedal, Samco IC Hoses, Axxis Pads, Goodridge Lines, Neo Synth Brake Fluid, Speedbleeders, Eibach Pro-Kit, Perrin Endlinks and Rear Sway, 17" Sub Zeros w/ 225/45 ES100s, Crucial Racing Thermostat and 1.4bar Radiator Cap, Autometer Sport-Comp Oil Pressure, EGT, and Voltmeter on the A-Pillar, STI Hoodscoop.
  4. #1083
    Registered User ***biGRed***'s Avatar
    Oct 2002
    kawshon
    did the rfl make you have sluggish shifts? i want the HKS but i'm getting scared about these "sluggish shifts" i keep hearing.
  6. #1084
    Feb 2003
    Miami Beach
    I went through the same thinking process and choose the HKS. I've heard both but choose the SSBV. The sound is so mean. My car only has 400 miles on it and it doesn't feel any different. Wierd thing is my friend who helps out the skip barber racing school drove my car after the install and chirped going into second and I'm sure the blow off valve had nothing to do with it but it didn't do before that. As for the sluggish feel I can't say I am experiancing any problem just, I don't listen to the radio anymore because of the cool sound and turing heads every time I shift.
    03 Blk WRX
    COBB Stg 2
    60' 1.800
    1/4 13.4 @ 100mph (Before Cobb)
  7. #1085
    Registered User Initial-d~4life's Avatar
    Jun 2002
    miami/FL
    need some help with a hks ssq bov
    ok i purchased a use hks ssq bov but the guy who sold it to me had left the plug that come with the wrx kit in his wrx and had sold it with out taking it out so now iam stuck with a bov and no plug to close that intake hose. so my question is what do i do now? all your feed back helpful
  8. #1086
    Registered User Hybrid-X's Avatar
    Feb 2002
    WA for now, but CA will always be home
    Try contacting HKS USA to get a replacement. Or you can custom fab something yourself. Until then, keep your stocker on. Good luck.
  9. #1087
    Registered User kawshon's Avatar
    Jun 2002
    hawaii
    Originally posted by ***biGRed***
    kawshon
    I didnt have on the car long enough to really notice It's just too damn loud.
    But like I said before, the HKS on my car, made it feel sluggish, but on another WRX, it feels fine. I dont really know why either.
  10. #1088
    Oct 2002
    Originally posted by WRC_Obsessed
    i did quite a bit of searching and the only place other than ebay that sold them was rallyperformance.com and forgemotorsport.com
    where did you buy your forge bov from and how much? i looked at both links and was thinking scoobysport was better. could you let me know how the outcome is? i'm thinking of getting the 100% atmospheric bov. did you get the filler cap? thanks.
    eddie
  11. #1089
    Registered User WRC_Obsessed's Avatar
    Jan 2002
    Boston/NNJ
    i got my bov from rallyperformance for $197...
    i didn't get the oil filler cap...i'm all set with paying $50 for a damn cap....
    it should be here tomorrow or tuesday...i'll let you know how it goes...
    -Brian
    Twisty Monster - 335 ft/lb of torque @ 3600 rpm on a stock turbo. Is that possible? Yes it is.
  12. #1090
    Registered User RexMobbin''s Avatar
    Nov 2002
    zipity here, zipity there, i'm zipity everywhere...
    right on obcessed. make sure you fill us in.
    and the rest of you with the Forge, is it still working out nicely?
  13. #1091
    Aug 2001
    corpus christi tx
    Cool BOV
    well my GFB is set to 50/50.. been that way since new, about 13000+miles and two years.. no probs to report to date...wish it was louder just for sound of course...
  14. #1092
    Registered User PerthWRX's Avatar
    Feb 2003
    Perth, Australia
    A 100% atmospheric venting BOV will cause the occasional backfire and tends to run the fueling richer than it already is as the ecu compensates for air thats no longer in the system. A hybrid setup that vents a percentage of air back into the intake and the rest atmospheric tends to work best. On standard tune vehicles this is the case.
    GF8 Family Wagon, IHI VF22, MoTeC, Cypher Industries, Holinger Engineering
    www.perth-wrx.com
  15. #1093
    Jan 2002
    Boston/NNJ
    this true...however, it does seem that the forge doesn't have the issues that a typical 100% atm bov has...i will let you know if i run into any issues...
    i also have an uppipe and turboback exhaust enroute right now...once i get that installed i will order up an ecutek reflash and make sure that the forge is taken into consideration...
    so i should also see the difference between running the bov pre and post reflash...
    -Brian
  16. #1094
    Taz
    Taz is offline
    Registered User Taz's Avatar
    Feb 2003
    Those with TXS Type H BOV...?....
    Newbie here with a lil question...I just got a TXS type H BOV and would like to know how many spacers(washers) are you using.
    up to now its the only thing that I´m doing to the car since I´m waiting for my uppipe, downpipe and MBC to come in.
    all help is greattly appreciated(sp?)
  17. #1095
    Registered User jutus's Avatar
    Winnipeg, Manitoba, Canada
    I'm using 2. There is some flutter at low boost but otherwise it sounds great. It sounded much better after I put about 200 miles on it. At first there was a lot of flutter. Now it sounds just abou t perfect.
