"The BIG BOV thread" (Where all bov question threads get merged) - Page 728
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; So I was given this bov and when I went to instal it the tube back to the turbo has ...
  1. #10906
    Registered User Stasharino's Avatar
    Jun 2009
    Buffalo, NY
    Bov
    So I was given this bov and when I went to instal it the tube back to the turbo has nowere to connect...do I need a recirculatory bov or is there something I can do...it's the same one I'm pretty sure as this one on ebay.
    TURBO BLOW OFF BOV VALVE SUBARU WRX IMPREZA 02 03 04 05:eBay Motors (item 230399392920 end time Nov-23-09 17:09:16 PST)
  3. #10907
    Oct 2005
    Late Devonian
    Quote Originally Posted by Stasharino View Post
    Yes, exactly. There is no good reason to install it.
  4. #10908
    Jun 2009
    Buffalo, NY
    Bov
    So how much do you think I would spend on the right BOV?
  6. #10909
    May 2007
    orlando flawduh
    what mods do you currently have? 9 times out of 10 your stock BPV will be fine and you dont even need an aftermarket one.
    desiree
  7. #10910
    Dec 2003
    Dallas, TX / Sterling, VA
    Several times what that valve cost.
  8. #10911
    Registered User lytlec's Avatar
    Jan 2009
    Central PA
    Quote Originally Posted by Liquidr1 View Post
    take your stock one off. go to walmart and by some chrome paint. Paint the dumb thing and call it a day.
    thats a hell of a good idea.....
    <-------- Taylor Swift.
    Hawk-Eye Alliance #137
    First Mods...what to do.
    Subaru Guide
  9. #10912
    Jan 2009
    Central PA
    I'm boosting about 22 psi....on stock BPV...I wonder if mine leaks....
    Subaru Guide
  10. #10913
    Registered User Impreza2.0's Avatar
    Nov 2008
    Maine
    You can actually go pretty far with making the OEM valve look good, if you want decent valving at a decent price, and still care about the fashion of your engine bay. It can be primed and filled, then painted with a base and metalflake, then a clear w/ color then another laquer of clear. You can make it look like a fine anodized piece of motor jewelry. It will outperform nearly anything else you will ever buy while using stock turbo, ECU and intercooler. If you leave it alone it will still do a lot better in bed than the ones made of billet do at the bar. If you want to put some make-up on it, it will be as good looking as any of those.
    at 22psi, yeah, you are way past OEM targets, so, get a stronger valve. Forge, GFB, there are a bunch. Many will swear by their brands, some are very hard to tune, not even worth the time, and some are stupid simple (Forge is precisely like the OEM piece in removal/installation, and can withstand boost up to some rediculous amount).
    These good valves are really expensive, and are a total waste unless you really need them. I think that is what this thread is supposed to gently educate, that there are builds that really need them, and there are some that will work better or worse with each engine. I had horrible luck with a GReddy RS valve, even though it was supposedly made for this car. It came down to the tune, and the stock valve was just as bad, so I ended up with a GFB triple-stack valve, and it's quiet, takes 18psi with no issue, and does not leak. I am on my way to a GFB Atomic controller, I will have pics of this mess when it's in. I am also rehosing my boost gauge...
  11. #10914
    May 2007
    behind the wheel
    Quote Originally Posted by lytlec View Post
    safe bet it is, at 22 LOL
    Rogan o_0
  12. #10915
    Jan 2009
    Central PA
    I guess its a good thing I'm not constantly trying to race people then! I should probably still get a better one though huh...I just want another recirculating valve...I will check out the forge and GFB
    Subaru Guide
  13. #10916
    Jan 2009
    Central PA
    Subaru Guide
  14. #10917
    Jan 2009
    Central PA
    I think I'm gonna go with the Forge Alloy Recirc...
    Subaru Guide
  15. #10918
    Palmyra, NJ
    interesting...I was boosting consistently at 22-24 (give or take on the weather in Philly, tuned to 20.5psi) and my stocker worked perfectly fine....or did it...
  16. #10919
    May 2007
    behind the wheel
    doesn't mean it wasn't pushing open
    Rogan o_0
  17. #10920
    Jan 2009
    Central PA
    So I'm guessing the Forge Recirc valve is good to go? I would think it would be hard to mess up one of those and have it leak....
    Subaru Guide
