"The BIG BOV thread" (Where all bov question threads get merged) - Page 727
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; so a 50/50 on a 2009 wrx impreza sounds good??...
  1. #10891
    Registered User Jaysimpreza's Avatar
    Oct 2009
    Sunnyvale, CA
  3. #10892
    Registered User c2bcoolwrx's Avatar
    Mar 2008
    SFLA
    Quote Originally Posted by Jaysimpreza View Post
    Leave the stocker on. No reason to change the BOV unless you are running some serious boost (20PSI+)
    Please read the stickies at the top of the forum and do A LOT of research before you purchase anything for your car. WRXs are a bit more complicated than modding a honda.
    Also please read these:
    Hey everybody new to the forum: READ THIS! - NASIOC
    2008/2009 owners...please read.... - NASIOC
    You have quite a bit of reading/learning to do about your car. So please take it slow before you do something that could possibly damage your engine.
  4. #10893
    Registered User Impreza2.0's Avatar
    Nov 2008
    Maine
    Quote Originally Posted by subydude8 View Post
    so ive read a decent amount about bov's and i know they are bad but for some reason i was wondering are there any good bov's or do they all just suck?
    No, they don't suck, they just are wholly unnecessary in 99% of the applications asked about in this thread.
    Get a boost gauge FIRST. Then you when you find that you are still not nearing 18PSI, forget the valve. If you have a lot of turbo mods, and the support for those mods, and you ARE hitting over 18PSI, get a valve. 50/50 is OK, especially if you can alter the ratio, like the Go Fast Bits piece... best bet is to stay recirculating. It reduces turbo lag, and prevents premature bearing/bushing wear in the compressor.
    Our OEM valves are fast, light, well fitted, and can withstand up to 18PSI boost with no problems. Replacing it means you will have to match it's properties with an unadjusted valve, which is time consuming, and without engine management, tough to do accurately. It is possible to adjust it during test driving, and that is unlikely to hurt anything, but for $45 for the OEM piece, you could have 3 of those before an aftermarket one is payed for.
  6. #10894
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by Impreza2.0 View Post
    Can I ask where you got this information? In my 3 years here I haven't heard of bearings in a turbo going out because of a VTA BOV...
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  7. #10895
    Moderator Donkey's Avatar
    Da boonies,Va
    Ummm...........no.
    2002 FORESTER S
    1998 FORESTER S
  8. #10896
    Palmyra, NJ
    Yeah...interesting
    BOVs screw with the MAF readings...that's why it causes "problems" in our cars. The ECU is preset to allow for the recirculated boost to be included in the MAF readings, so if you vent to atmosphere, you don't get as much air in the mixture as the ECU thinks, therefore causing it to send the same amount of fuel with less air. Ergo...running rich during shifts.
  9. #10897
    Oct 2009
    Sunnyvale, CA
    are you still gonna have idle problems when the rpm drops if you run with the turboxs 50/50 bpv??
  10. #10898
    Registered User supranai's Avatar
    Oct 2009
    Michigan
    So basically you guys are telling me to ditch my hks ssbov and put the ugly plastic thing back on because the air needs to vent back into the system to not throw off the ecu. What would be the next best thing besides the ugly black thing that comes with the car. It's all plastic now. Will a metal unit from an older sti fit in there?
  11. #10899
    May 2007
    behind the wheel
    Ever heard the saying "function over form"?
    Apparently, you're in it for the material principal, as your only reference to it is whether it's ugly or not.
    If you want 'bling', get a billet bpv (Forge, etc.) and recirc it, call it done.
    Rogan o_0
    '97 Dodge 3500 CTD DUALLY built Auto - 40psi boosties - 750 lb/ft
  12. #10900
    Dec 2003
    Dallas, TX / Sterling, VA
    Quote Originally Posted by supranai View Post
    A full fledge recirculating bypass valve. No, the older ones will not fit if you're still using your stock TMIC.
    Huh?
    Quote Originally Posted by c2bcoolwrx View Post
    The plastic valves of the current generation WRX is not as good as the older metal ones. They leak sooner (~18 psi) so '09 owners who are +stage 2 are more justified in replacing the piece with an aftermarket one.
  13. #10901
    Oct 2005
    Late Devonian
    So how much do blow off valves suck?
  14. #10902
    Dec 2003
    so how much do blow off valves suck?
    14
  15. #10903
    Oct 2005
    Late Devonian
    Quote Originally Posted by brfatal View Post
    14
  16. #10904
    May 2007
    orlando flawduh
    Like… omg… my stock bpv is sooooo gross and plasticy… ATROCIOUS!!!
    desiree
  17. #10905
    Registered User Liquidr1's Avatar
    Oct 2008
    Greensboro, NC
    take your stock one off. go to walmart and by some chrome paint. Paint the dumb thing and call it a day.
    2009 Impreza WRX Hatch.
    Cobb AccessPort: Cobb Protune @ Draco Performance
    346 ft/lbs 289 awhp.
    Perrin CAI.
    Perrin Performance Catback.
    Perrin Performance 3" catted downpipe
    SPT boost guage.
