"The BIG BOV thread" (Where all bov question threads get merged) - Page 726
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; take off the BOV... Sorry man but that thing makes you run rich and is actually hurting your car. You ...
  1. #10876
    Registered User Findus11's Avatar
    Nov 2007
    Ketchum, Idaho
    You do get flames and a cool sound, but it actually makes your car slower by slowing down the turbo in between shifts. Try looking into a recirculating one if you really wanna keep the sound
    Hawk Eye #1991
    Dirty Crew #11
    Military Militia #1991
    I still don't know how I got this car...
  3. #10877
    May 2007
    orlando flawduh
    get rid of the BOV & the car will run properly..
    i'm hoping you have a tune for the DP?
    desiree
  4. #10878
    The afterfire (not backfire) is caused by the combination of the catless exhaust and aftermarket BOV. This will happen from time to time. You can keep the aftermarket valve; it's not going to hurt your car any, provided it isn't leaking and is setup properly.
    Resident Tuner @ WTF Tuning
  6. #10879
    Registered User Lavid2002's Avatar
    Oct 2009
    ive heard the bov akes the car run rich in between shifts, and by running rich more gasoline is added to the mixture : / sell the BOV
  7. #10880
    Quote Originally Posted by Lavid2002
    It swings on the rich side of the spectrum, but nothing to be concerned over. As long as it's a quality valve (read: doesn't leak), and is properly setup/maintained.
    If he purchased the aftermarket valve as a "performance upgrade" then he wasted his money, and would probably be better off selling it and spending the money elsewhere. If he purchased the valve because he likes the way it sounds, then he should keep the valve (given the two criteria mentioned above are met).
  8. #10881
    Oct 2009
    Quote Originally Posted by TheSpruceGoose View Post
    Yeah thats not because of your BOV...its because less back pressure in your exhaust system due to your downpipe. What code is it showing exactly?
    it says wastegate solinoid preformence/ range
  9. #10882
    Supporting Member yamaha_rider619's Avatar
    Jul 2009
    colorado is home, Kansas is the temporary home
    i know everyone says you should stick with the stock bov, but i didnt. I was wondering where i can buy a blanking plate for a tubosmart dual port bov, so i can run it recirc. I tried their website but they only gave me part numbers.
    Josh
    2003 Subaru Wrx Vf39'd
    Bugeye mafia #300
  10. #10883
    Registered User Impreza2.0's Avatar
    Nov 2008
    Maine
    Quote Originally Posted by yamaha_rider619 View Post
    Give 'em a call... you have a top-o-da-line part, I am sure they will support it...
    mmm, coffee... and a header tank...
    edit: you can also trace the plate off the valve body, then machine/drill it yourself... just gasket it, and it should support way more pressure than it will ever see... I'm a die-hard DIYer though...
  11. #10884
    Registered User JUSTINSNUTSWINGER's Avatar
    Jul 2008
    San Antonio
    ^^Boost spike. From running catless MTL. Even though you will spike WITH a cat as well.
    N-swinger
    2000 Escort
    Maintenance schedule and poke in the eyes:
    http://www.clubwrx.net/forums/genera...nce-guide.html
  12. #10885
    Quote Originally Posted by 09wrxbluedevil
    Quote Originally Posted by pzr2874
    Yep, nothing to worry about.
    Turn off the code and drive normally. If this happens a lot, you'll need to look into a custom tune and/or an EWG setup
  13. #10886
    Registered User subydude8's Avatar
    Aug 2008
    reno, NV
    bov question
    so ive read a decent amount about bov's and i know they are bad but for some reason i was wondering are there any good bov's or do they all just suck?
    2004 stage 2 REX!!!!!!!!!
  14. #10887
    May 2007
    orlando flawduh
    IBmerge
    there are some BOV's that are supposedly not as harmful as others but i still think they're a waste of money & for most applications, completely useless.
    desiree
  15. #10888
    Registered User Tinywagon's Avatar
    Mar 2009
    Fort Worth Texas
    ^ +1 read that FAQ.
    BOV's are mostly for people who run an FMIC setup where the standard piping doesn't allow for the use of the stock unit.
    The reason they're not that awesome is because they make you run rich between shifts if they are the VTA (vent to atmosphere) type.
    I know how you feel though, they sound cool, and you see some of them for sale and you think. "oh cool an upgrade!"
    Just remember, our cars are build real well, not like chebbys or Fords. So upgrading isn't necessary all the time.
    "if you are going to tell someone the truth you had better make them laugh otherwise they'll kill you" - George Bernard Shaw.
    Bugeye Mafia #214
    Dirty Crew #42
  16. #10889
    Moderator Donkey's Avatar
    Da boonies,Va
    God.........why couldn't this thread been the one to disappear instead of the Bugeye Mafia.
    The rich condition is not that big of a deal. And it has nothing to do with running a FMIC. The problem lies with the valve design and the fact that the end user needs to tune it/set it up for it to work properly. Full VAT's are much more problematic than the 50/50. In my opinion the best valves out there are hands down the APS 50/50, Worx DS2 fully adjustable and the Turbo XS hybrid.
    2002 FORESTER S
    1998 FORESTER S
  17. #10890
    May 2007
    behind the wheel
    Amen on the disappearance..
    Rogan o_0
