"The BIG BOV thread" (Where all bov question threads get merged) - Page 700
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by jeremy96gase Incorrect. Loosing that small amount of air does, in fact, make a big difference. Yes, that's ...
  1. #10486
    Registered User Cicatrize's Avatar
    Apr 2009
    Michigan
    Quote Originally Posted by jeremy96gase View Post
    Yes, that's what I was saying... with the STOCK tune, it probably presents problems. Sorry I wasn't very clear on that.
    2009 DGM WRX 5-door w/ STI short shifter. Stock...for now.
  3. #10487
    Dec 2003
    Dallas, TX / Sterling, VA
    Quote Originally Posted by Cicatrize View Post
    You cannot tune for a blow-off valve.
  4. #10488
    Apr 2009
    Michigan
    Quote Originally Posted by brfatal View Post
    You can adjust fuel.
  5. #10489
    When? Based on clutch disengagement? Do you have such a map handy?
    - Al Stewart
  6. #10490
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    Not in this case. The ECU would need a trigger to see the need to adjust fuel. Since it is seeing an measured air flow that doesn't exist, how could you then tell it to reduce fuel only at this specific point? Not to mention, the amount to be adjusted would have to be balance across the whole throttle position. Don't think it can be done. It would be easier to change the flow sensor type from MAF to MAP.
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
  7. #10491
    Apr 2009
    Michigan
    Quote Originally Posted by YBNormal07 View Post
    Aye. My bad. I'm new to this turbo game. I figured the ability would be built into the ECU to handle it.
  8. #10492
    Moderator
    Jul 2003
    Maryland
    This has been asked, answered, debated, and answered again. No need for another post here about it.
  9. #10493
    May 2007
    behind the wheel
    merge-o-rama
    Rogan o_0
    '97 Dodge 3500 CTD DUALLY built Auto - 40psi boosties - 750 lb/ft
  10. #10494
    Feb 2009
    Fountain Valley, CA
    so i haven't searched through this 700 pg thread but... just looking for a simple answer to a question. i have a hks ssqv for my speed3... and would like to put it onto my brothers 06' wrx. if i were to just buy a 06' wrx flange for the bov it'd work for his car right? and IF it was run in recirculating mode it'd be fine and hopefully not run rich because it wouldn't be VTA!? any help would be appreciated.
  11. #10495
    Registered User Oldfart Racer's Avatar
    Maryland
    Quote Originally Posted by fvMS3 View Post
    Yes, you can mount it with right flange. Is it a good idea, no.
    The only reason to swap the stock BPV is if it leaks, most will hold 20psi with out a problem.
    The only way to tell if it "will be fine" is to data log.
    In a nut shell BOV and intakes are bad for Subarus.
    A lot answers can be found here, Unabomber's Manifesto - NASIOC
    VF30 powered 02 wagon
  12. #10496
    Moderator Donkey's Avatar
    Da boonies,Va
    Why would it be?The car comes with a BPV not a BOV from the factory.Just assuming the car has such an abilit instead of knowing generally gets people into trouble (intakes,TGV deletes,bigger turbos with no EM.....)
    2002 FORESTER S
    1998 FORESTER S
  13. #10497
    May 2007
    behind the wheel
    Quote Originally Posted by Oldfart Racer View Post
    I wouldn't say it's a 'bad' idea, or a 'good' one, since the recirc BOV (wouldn't it be a BPV at that point? ) would do the same thing the stocker does?
    Rogan o_0
  14. #10498
    Feb 2009
    Fountain Valley, CA
    thanks for the info oldfart! and rogan i was thinking the same thing... if its run in recirc. mode it'd be a bpv? iono i could totally be wrong... but i also have the newest version hks which is auto adjusting... not sure if that matters or not. just thought i'd help my bro out and pass my bov/bpv to him as i wont be needed it anymore and will be getting another bov for my speed3 that is more stock-like because the hks hits the hood on the speed3.
  15. #10499
    Feb 2009
    Pay attention to what you're posting and where you're posting it.
    Last edited by Rogan; 04-12-2009 at 04:38 AM. Reason: This is not a wheel/tire thread
  16. #10500
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by joshwrx88 View Post
    quick question i was wondering if you could give me some advice i am looking to purchase 18 inch rims for my 2003 wrx and i was curious if they are too big and should just stick to 17 inch. i dont want to mess up the smooth ride
    Start a new thread pal. You're in the Blow Off Valve thread.
    And depending on the offset and width you can put 18" wheels on your wrx
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
