"The BIG BOV thread" (Where all bov question threads get merged) - Page 683
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; its 50/50.... has a small piston inside of it which has to have a certain amount of boost to open ...
  1. #10231
    Registered User STi-Guy85's Avatar
    Mar 2007
    Savannah GA
    its 50/50.... has a small piston inside of it which has to have a certain amount of boost to open it up and allow air to blow out.
  3. #10232
    Moderator Donkey's Avatar
    Da boonies,Va
    Quote Originally Posted by STi-Guy85 View Post
    but, performance-wise, it reduces boost lag like crazy...
    Any hard data to back that up or are you just going by your butt dyno?Read the BOV link in my sigature.......
    2002 FORESTER S
    1998 FORESTER S
  4. #10233
    Mar 2007
    Savannah GA
    nah theres nothing to really back it up....its a "feel" thing... haha
  6. #10234
    Registered User jimenezp's Avatar
    Apr 2008
    anyone know where i can buy a recirculation kit for a HKS ssqv my 02 wrx.
  7. #10235
    May 2007
    behind the wheel
    I've posted this before..
    go to google, and input 'hks ssq bov recirculation kit', and viola!
    Here, I'll do the hard work for you
    HKS SSQ BOV Recirculation Kit :: Universal Blow Off Valve Accessories :: Blow Off Valve :: Turbo Wholesale Distribution
    Rogan o_0
  8. #10236
    Palmyra, NJ
    Viola?
  9. #10237
    Jul 2008
    aurora, colorado
    now i understand that when you put on a atmo. bov in can cause you to run rich between shifts. now i live about a mile up,,,,will i even notice that cause the the extra fuel will make up for the lower oxygen?
  10. #10238
    Palmyra, NJ
    Quote Originally Posted by RedDragon89 View Post
    This might actually be the first legit good question I have ever heard having to do with BOVs
    Sadly...I am stumped and don't have an answer for you really on this one. I imagine that its still pretty similar for cars in your area as it is for the lower lying areas though...
  11. #10239
    May 2007
    behind the wheel
    how does extra fuel make up for less oxygen? wouldn't that make it "more" rich?
    Rogan o_0
  12. #10240
    May 2007
    behind the wheel
    Viola?
    voilà (vwä-lä')
    interj.
    Used to call attention to or express satisfaction with a thing shown or accomplished: Mix the ingredients, chill, and—voilà!—a light, tasty dessert.
    Rogan o_0
  13. #10241
    Jul 2008
    aurora, colorado
    see when you cant supply enough fuel for the amount of oxygen
    in the combustion chamber you will run lean and very hot. this could cause cylinder head damage and many other problems. when you run to rich you have to much fuel in the chamber. this is usally set on purpose at high boost levels to protect the motor. well because of my elevation i have less oxygen. i belive it 3% for every 1000ft. im not postive on that so you can correct me. but because i have less onygen the extra fuel will help cool the motor down and might get it close to running normal or at sea level.
  14. #10242
    Da boonies,Va
    Or because your already running factory ECU programming or a conservative tune the extra fuel from the BOV is causing "cylinder wash" and you are causing more harm than good.Too much fuel washes the oil away on the cylinder bores and ends up in the crankcase contaminating the rest of your oil.TONS of people have notice the smell of fuel when changing there oil.Plus the factory programing does have altitude compensation to some degree.More so for boost control but there is:
    *front oxygen sensor scaling compensation (closedloop)
    *CL/OL delay compensation atmospheric threshold
    *wastegate duty cycle compensation atmosheric
    Less dense air = less oxygen molecules = running much richer at WOT/Openloop
    2002 FORESTER S
    1998 FORESTER S
  15. #10243
    Palmyra, NJ
    voilà (vwä-lä')
    interj.
    yes I know Rick...I was just being my usual jackass self
  16. #10244
    Aug 2008
    West Jordan UT
    For everyone out there thinking about getting a bov for there subi dont do it, its not worth it. I just bought my 02 wrx and I just replaced my turbosmart adjustable bov with the stock bypass instant 3+ mpg!! It did take about 20 mins to get used not hearing it, but I would rather have preformance then the potiental puss from the hookers on the side of the road...
    **subarublue**
  17. #10245
    M16
    M16 is offline
    Registered User M16's Avatar
    Sep 2008
    Bay area(Cupertino), CA
    Noob Q!!
    I have seen those WRX's with those loud turbo noises when they change gears, and was wondering what mods would make my turbo sound like that, or do i just need a bigger turbo?
