"The BIG BOV thread" (Where all bov question threads get merged) - Page 661
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by 02wrxdude This is pure speculation, and is based on my basic knowledge of the intake side of ...
  1. #9901
    Registered User JMack's Avatar
    Feb 2008
    Quote Originally Posted by 02wrxdude View Post
    This is pure speculation, and is based on my basic knowledge of the intake side of an engine, so go easy. My theory is that if the MAF is placed closer to the engine, and the BOV is placed before the MAF, wouldn't this help compensate for the incorrect signal being sent by the MAF? I was laying in bed contemplating this because as ricer as it sounds, I do like the sound of a BOV but I am completely unwilling to sacrifice performance for simply a sound. Feel free to point out the flaws in this argument.
    With a custom tune, possibly. Basically what everyone is saying in different ways is that the ECU has a "preset" amount of air that it assumes is going back into the Intake from the BPV. As the MAF is BEFORE the BPV, this has to be the case. When you vent your excess boost pressure to the atmosphere (via BOV), you are fux0ring your intake and motor out of the air that the ECU is assuming is there.
    CLIF NOTES:
    BOV's are bad... UNLESS you have the supporting tuning for the ECU to adjust for all of the changes you are making to the car.
    BOV's are NOT PnP on Subies
    Success is the ability to go from one failure to another with no loss of enthusiasm.
    - Winston Churchill
    Ah, the patter of little feet around the house. There's nothing like having a midget for a butler.
    I am free of all prejudices. I hate everyone equally.
    - W.C. Fields
  3. #9902
    Registered User Kmlacrosse's Avatar
    May 2008
    Illinois
    the solution
    This is simple; you must find a compromise between sound and performance. Yes there are bovs that are purely sound (for example HKS sequential, Turboxs Supersonic ex.), all of these create the problem of back flow and fail to release pressure at low psi. These are only smart to have on a largely modified system (500hp +) or to quickly install before a race because they work great at max boost. But as a daily driver big sound bovs can ruin your car, not to mention you want to kill your self after a couple hours of stop go traffic every 10ft hearing a PSH!!!!!!! Sound at 6am. That is why you have to go for a more performance oriented bov. I had the Supersonic bov and it caused low idle, backfiring, condensation, and with the massive loss of pressure each time a jerky ride (kinda like slamming the breaks each time you let off the gas.) Now I have an aps dual vent bov and it is perfect. No idle problems, no lagging, no condensation, no problems. It works just as it should, releasing pressure when it’s supposed to, even at low psi. It isn’t nearly as loud as the old supersonic (rfl) but when racing it is loud enough to turn heads.
  4. #9903
    Moderator Donkey's Avatar
    Da boonies,Va
    Yes,search "blow thru MAF" or "blow through MAF" on any Subaru site or Google it .This method is used on most MAF based cars.The other option is to switch to a "speed density" setup that uses MAP based fueling.
    2002 FORESTER S
    1998 FORESTER S
  6. #9904
    Oct 2005
    Ocean Grove, NJ
    Quote Originally Posted by wrxtreme06 View Post
    i have the I//S delete and it IS louder than stock. you will definitely recognize it.
    i've said this plenty of times though.
    *what is more important to you?*
    having a PSHHH sound? or the longevity/performance of your car?
    the serious effect of a BOV is basically this: your ECU will be injecting the WRONG AMOUNT OF FUEL into your cylinders. this can cause bucking and can even cause your spark plugs to foul. aside from that, it can CLOG your cat and cause it to even melt.
    so you chose.
    are you going to be dumb and put your cars health at risk just for a SOUND?
    seems pretty silly to fuccck up a 25,000 car (or a 30K+ if you have an STi) just for PSHHHHH
    +gospel
    If you want to put a BOV on the car, then go with a standalone engine management system and tune the car by MAP instead of MAF. That would be the right way to do it. However, most people can't justify that kind of expense, until they are highly modded.
    Hell, I'll admit that I have considered picking up a BOV that is adjustable to full recirc just to play with it. But the device isn't going to add ANY functionality or benefit over the stock BPV, other than a PSSH sound.
    Hell, I can make that sound on my own - watch.
    Waste money on the BOV??? PSSSH!
  7. #9905
    Registered User Tay115's Avatar
    May 2008
    Washington
    Parts Question
    Does anyone know what makes the wrx make the pssss sound when you shift? What would you have to do to make your car make that sound?
  8. #9906
    Registered User BigB007's Avatar
    Mar 2007
    PA
    Short Ram Intake
    Bugeye Mafia #141 Military Militia #007 Hawkeye Alliance #126 The Stink-Eye Mob #92
    03 WRB WRX - Sold
    07 WRB STi - Sold
    11 SWP WRX - Current
  9. #9907
    May 2007
    orlando flawduh
    its called a BOV and you DO NOT WANT ONE.
    http://www.clubwrx.net/forums/engine...ov-thread.html
    you can get a similar sound by doing an intake silencer delete. do a search to find out more info on it.
    desiree
  10. #9908
    Quote Originally Posted by Tay115
    OEM BPV
    Search for "silencer delete"
    That process will safely allow you to get that sound (for free)
    Resident Tuner @ WTF Tuning
  11. #9909
    May 2008
    Washington
    thanks.
    so does anyone know what you must do to the car in order to get the sound? Can i do it myself?
  12. #9910
    May 2007
    orlando flawduh
    Quote Originally Posted by Tay115 View Post
    thanks.
    Quote Originally Posted by BigB007 View Post
    Short Ram Intake
    Quote Originally Posted by idipskoalmint View Post
    OEM BPV
    desiree
  13. #9911
    Can i do it myself?
    Yes, but only the passengers inside the car will be able to hear you unless you use a megaphone.
    Have a close look at the links provided by the previous posters, all the info is there.
  14. #9912
    DUB
    DUB is offline
    Registered User DUB's Avatar
    Jul 2007
    SLT, CA
    It's refreshing to see such an extreme level of n00bness. I fondly remember back to when I had to search for what a BOV was. Tay115; you have a long and exciting journey of knowledge ahead of you.
  15. #9913
    Registered User aarond's Avatar
    Apr 2008
    Olympia, WA
    +1
    Definitely read the BOV thread (above). Says everything you prob want to know. The rich condition may make your plugs foul faster. And you'll def experience a lot of afterfire when running hard. Incidentally, you'll want to be running catless exhaust.
  16. #9914
    Oct 2005
    Ocean Grove, NJ
    Yes, read that 660 page long thread.
  17. #9915
    May 2007
    orlando flawduh
    someone should go through and delete all the BS posts and try to ORGANIZE EVERYTHING
    i love ORGANIZING. someone make me a mod of this thread only and give me supa powaaa's
    desiree
