"The BIG BOV thread" (Where all bov question threads get merged) - Page 659
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by The Boxman when i'm in low boost, and i let off the gas, there is a fluttering ...
  1. #9871
    May 2007
    behind the wheel
    Quote Originally Posted by The Boxman View Post
    when i'm in low boost, and i let off the gas, there is a fluttering noise coming from the passenger side of my car.
    i have a GFB BOV, that is fully adjustable, and i took the intake silencer, and i'm trying to figure out what is wrong.
    YouTube - Engine Flutter
    that's my car. you can hear the flutter really good at the last shift.
    that's compressor surge.
    What it is, is the BOV spring pressure is set too high, or the vacuum signal to it, sucks (no pun intended.)
    Either way, it's not healthy, by any means, especially for your turbo. What's happening, is, air is being forced backward when you close the throttle plate (and the bov isn't opening), causing the pressurized air to make its way back through the IC, and to the compressor housing, pushing the wheel (trying to) opposite of it's rotation..
    Imagine the stress on the CHRA when the turbine side is still being turned the proper way, by exhaust gases, yet the compressor is trying to follow suit, but meets this backpressure resistance..
    Not healthy.
    Fix it. Soon.
    Rogan o_0
  3. #9872
    Registered User WRXDrummer's Avatar
    Dec 2007
    Cleveland, OH/State College, PA
    but it only happens in super low boost, and when i'm boosting really hard it blows off like normal, instead of making that weird noise, and sometimes it will blow off and then make the flutter.
    That is called compressor surge and it is REALLY BAD. That will kill your turbo. It happens only in low boost because it doesnt have enough pressure to trigger the BOV, so the air surges back into the turbo.
    Seriously, take it off asap or you will soon hear a lot more bad noises from the passenger side (ie turbo side) of your car.
    edit: I was beaten to the punch. Dang!
  4. #9873
    Would Never, Ever Say Something Bad About an Admin's Mom SonicWagon's Avatar
    Jul 2007
    Santa Cruz New Mexico
    TAKE OFF THE BOV
    "It is at our most challenging times that we must cheat our very hardest" - Eric Theodore Cartman
    Quote Originally Posted by Weasel 555 View Post
    so whose up for been banned?
    I is teh b1ggest douche evarrrr!~
  6. #9874
    May 2008
    Suwanee, GA
    BOV and MAF issue comment
    I'm not sure where to start this thread but feel free to move if needed.
    Let me start by saying I am by no way an expert in the WRX area but I do however know a lot about mustangs and how superchargers and turbos work on them so in theory they should work very similiar. On a mustang we have 3 different ways to monitor air blow thru MAF, drawl thru MAF and speed density. It's a big no no to put a BOV/bypass after the blow thru meter because of the unmetered air so what we do in the mustang world is switch to a blow thru MAF and put the meter up closer to the throttle body and put the BOV before the MAF therefore all the air is metered.
    That being said is it possible to switch a WRX/STI to a blow thru configuration rather then a stock drawl thru? If so that is a possible solution to the issue people are having with BOV.
    Let me know what ya think.
    Alain
    2008 Subaru WRX
    1998 Mustang GT 9.00@151mph
    Lots of Boost!
  7. #9875
    Apr 2007
    8000' up in Colorado
    No that wouldn't really work. The Subaru engines and computers are a lot more sensitive than the Mustang engines and computers.
    Scott
  8. #9876
    In Memoriam
    Feb 2004
    Evansville, IN
    wrong. Theres tons of people running blow-thru on bigger turbos.
    However, it would require going with a FMIC & a complete custom retuning of the MAF tables along with all the normal fuel, timing, & boost.
    1988 Celica Alltrac
    Hallman Pro, 15x7.5 +20mm Rota Slipstreams
    2005 LGT 315whp/340wtq@21psi - Sold
    VF52, Crucial P&P&C Manifolds, UP, DP, RP, Magnaflow CBE, Hallman PRO, ROMRaider
    2003 WRX 371whp/355wtq@24psi - Sold
    TD05H-20G-38mm Tial, Meth Injection, Hyperflow TMIC, ROMRaider
    Dyno Chart METH vs 93 oct
  9. #9877
    Registered User jeffmm06's Avatar
    Sep 2007
    Sacramento, CA
    Seems like a lot of work just a a PSHHH. Unless your running a setup that requires it of coarse.
    2005 WRB WRX "was" STAGE 2
  10. #9878
    May 2007
    behind the wheel
    Quote Originally Posted by 98SILVERSTANG View Post
    Alain
    That is correct, Alain. That layout would work.
    False
    Quote Originally Posted by testes1010 View Post
    I was gonna say the exact same thing.. See,, J, you can teach an old dog new tricks.
    Quote Originally Posted by jeffmm06 View Post
    That's usually the idea behind these thoughts.. I've tossed the idea around A LOT lately.. I've got a ton of little issues, that are likely the result of a big setup, BOV, draw-thru MAF, etc..
    Rogan o_0
  11. #9879
    Apr 2007
    You can do anything you want to an engine and make it work once you start modifying that much. You have to assume the OP was talking about a relatively stock setup.
    False
    Sorry, but I don't agree. If it were that easy, then why aren't people doing it? The fact is that you can do pretty much anything you want to an engine but either you need to engineer/test the heck out of it, or accept the problems that will be caused. So sure, you could do what the OP suggested, but it's not that simple. It'll require a lot of tweaking/engineering/testing. I have to assume the OP was talking about just bolting it up to a stock car.
    Scott
  12. #9880
    May 2007
    behind the wheel
    more people aren't doing it, because of just that: It ISN'T easy. It's a lot of work/time/tuning to get it to operate.
    And I rarely assume anything.
    And even in your reply:
    you basically said it wouldn't work, due to engine/computer sensitivity. It isn't that, at all; stock or modified.
    Rogan o_0
  13. #9881
    May 2008
    Suwanee, GA
    Thanks guys for the input.
    No it's not something your everyday person would do on their car but for someone looking to continue modding then it would probably be something that should be considered. IMO when ever you have a modified setup be it increasing Boost, supercharging a N/A combo or simply changing cams you should have a custom tune or map done for the car.
    I currently run a DFI Gen VII standalone in my mustang with hours upon hours of dyno/track time just to fine tune the current setup. It's not cheap but I don't think a car tuned in CA is going to act the same as a car in FL and that's essentially what your doing when you download a MAP from someone else.
    The computer maybe more sensitive but nothing a custom map couldn't correct. Believe me you can do alot with a stock computer.
    Alain
    2008 Subaru WRX
    Lots of Boost!
  14. #9882
    In Memoriam
    Feb 2004
    Evansville, IN
    Re-read his OPs post. He's referring to supercharged & turbo charged Mustangs using Blowthru setups & Speed Density....neither which are 'relatively stock setups'.
    1988 Celica Alltrac
  15. #9883
    Moderator Donkey's Avatar
    Da boonies,Va
    What doesn't take alot of tweaking?An intake?Bigger injectors?The problem is it's alot of $$$$ for most as they don't know how to tune for a blow throw.Lot of money to spend just to run a kazoo....
    2002 FORESTER S
    1998 FORESTER S
  16. #9884
    Registered User Kmlacrosse's Avatar
    May 2008
    Illinois
    Cant you ajust your bov to release pressure at a lower psi? after all if bovs break your turbo at low boost then why are they even on the market? secondly i used to have a turbosmart supersonic bov and it ****ed up my idle and casued excessive backfire. i switched to an aps bov and now im problem free. the only dif is its very very quit.
  17. #9885
    May 2007
    behind the wheel
    what's the APS one like?
    pic??
    Rogan o_0
